21st Mar 2021, 4:03 pm | #21 | |
Re: R1155 power supply unit
Andy |
21st Mar 2021, 10:17 pm | #22 |
I think that the power supply has the 'potential' to be suitable for the R1155.
It may be necessary to convert it to a 'choke input' type of power supply to reduce the output DC voltage. The original circuit was probably a 'CLC' type. Changing from the original valve to a solid state rectifier will give more output voltage options. |
26th Mar 2021, 11:00 pm | #23 |
I would find out what the normal load current would be for a working receiver then work out a load resistor and put that across your PSU and measure the output voltage.
If it's still high the make some changes to it before running your radio from it. |
26th Mar 2021, 11:53 pm | #24 |
I found this a moment ago,Les
16th Apr 2021, 6:17 pm | #25 |
I would to thank every one for their replies. I have decided not to use the PSU in question. My friend helped me construct a PSU with AMP from one of the schematics on the forum. The PSU has been completed, but the output voltage is 280 Volts DC. We followed the circuit to the letter and have rechecked everything, but still get 280 Volts DC.
What can the problem be, or is it safe to connect the R1155? |
16th Apr 2021, 8:02 pm | #26 |
Is that on load or off load voltage?
A circuit for the PSU or a link to the thread concerned would be useful.
17th Apr 2021, 11:34 am | #27 |
The voltage is off load, the circuit diagram in question is the one discussed on 3rd December 2018 , with a question about a connection on pin 5 sharing two wires.
Attached is a thumbnail of the circuit, on the same date is the reply from a member correcting the connection where the wire be connected to. I hope this helps |
17th Apr 2021, 1:17 pm | #28 |
This thread presumably?
https://www.vintage-radio.net/forum/...d.php?t=152000 The HT supply is unregulated, so the voltage will drop on load.
17th Apr 2021, 5:42 pm | #29 |
Thank you for your reply, my dad had one of these radios in the 1960's and he purchased a power supply and amp from a company called Laskeys, it was housed in a tin box will a lead complete with a Jones Plug. he plugged it into the R1155 and it worked perfectly. At the time he never thought of checking the voltage, so when I purchased mine and completed the PSU in Question, I was concerned with high voltage, that I had.
So thank you for putting my mind at ease, and thank you also to all members who took part. I will still monitor this site, it is so informative. |
9th May 2021, 7:32 am | #30 |
In such a situation I would use a Variac (Variable Voltage Transformer) and meter the HT while slowly bringing up the mains voltage from about half normal. You may find that the voltage when loaded doesn't go above the specified level. You would want to increase the input voltage slowly, to give the heaters time to get the valves drawing current. A light dimmer that uses a triac (rather than a thyristor) can be used as a poor man's variac in most cases. Be careful with those Jones Plugs, the cases can become live if not earthed. Better not to touch the metal cases.
