Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
7th Sep 2020, 6:31 pm | #1 |
What standards converter?
Having collected and restored many vintage TVs in the 70s and early 80s including quite a few pre-war ones and the rest that were all no later than 1950 models (nothing bigger than 9"), I now have a solitary TV22a that has awaited restoration for some 30 odd years. That day may be coming soon and so I am starting to consider a standards converter. The role of the unit will be, simply, to enable me to watch off air TV programmes on the TV22 (only) in the UK.
What SCs are currently available that fulfil my criteria and what are the pros, cons and prices of each?
7th Sep 2020, 7:21 pm | #2 |
Re: What standards converter?
Steve, I can highly recommend the ‘ Hedghog’ converter designed by Frank Cuffe.
Stephen (Freya) of this forum can supply a pre assembled unit ready to plug in. Might be worth sending him a PM. Cheers. SimonT.
The honesty of imperfection.......... |
7th Sep 2020, 7:25 pm | #3 |
Unless the Aurora is still in production, this is probably your only option in the absence of something becoming available on the second-hand market.
7th Sep 2020, 9:30 pm | #4 |
There is Another Way.
Why convert from another obsolete standard (625) You can generate 405 line composite video directly with a graphics card in a PC and a handful of passive components to mix the VGA R G B and sync signals. Then you will probably need a System A modulator, I use this one https://www.earlytelevision.org/405_modulator.html here it is in action https://youtu.be/ahzdx4KgWBg
-- Graham. G3ZVT |
7th Sep 2020, 10:07 pm | #5 |
I can also supply Franks VOL modulator ready built.
https://electronics.frankcuffe.ovh/vol
8th Sep 2020, 8:35 am | #6 |
Have Aurora given up on standards converters? Their website now seems to be focused on vintage car audio with the converters listed under 'legacy'.
8th Sep 2020, 9:01 am | #7 |
Thanks for the input so far. Some suggestions are going over my head as I'm not computer/software savvy in the least (if that's what they're about?!). I need a ready made, black box that will perform the task as stated. I don't want to build anything, just hook it all up and channel hop. Cheers.
8th Sep 2020, 9:36 am | #8 | |
In that case, a ready built 'Hedghog' converter as supplied by Freya will be perfect for your needs. I built two of them just for the fun of it, but Stephen (Freya) can supply them fully assembled and cased and all ready to go. Just feed video & audio in and you get 405 line out on RF bands 1 & 3. They have useful front panel switches to select various options such as equalising pulses, inbuilt test pattern, input from a 16:9 source, output in either 4:3 or 5:4 format and output channel selection. They work very well and I have been very impressed so they certainly get my vote! Hope that helps, All the best Nick |
8th Sep 2020, 10:16 am | #9 |
I’ve had the pleasure of using both the Aurora, and the Hedghog, they are both excellent converters. The Aurora is the smaller of the 2, and is just a black box with AV in and RF out, it switches to the test card with no input signal, and if you want to you can change the test card to whatever you want. Downside is that all the option switches are hidden inside it.
The Hedghog has all its options available on the front panel, and is also a simple AV in, RF out. Test card has manual switching, rather than auto. It’s hard to choose between them really, picture quality is excellent through both! Regards Lloyd |
8th Sep 2020, 11:21 am | #10 |
May I ask a few questions on the aurora/Hedghog/HedghogII, am I correct in thinking that these all need the correct composite Video signal input i.e. 625 line PAL in to be converted conversion to 405 line. This done in the boxes like a video store and forward. Does it need positive or negative sync video input?
In the case of the VOL modulator, I am assuming it needs to have the video input already as 405 line format again would this be positive or negative sync video input? I like the idea of using output from a computer with any device, so I am wondering if anyone has used the HDMI to 3 RCA CVBS Full HD Video 1080P AV Scart Composite Converter Adapter's on Ebay at around £6 to drive the converters as video out is getting a bit rare on the cards. Thanks for any clarifications. Adrian |
8th Sep 2020, 12:43 pm | #11 |
Hi Adrian,
I’m currently using one of the HDMI converters to run YouTube through my Aurora with no problems, I can’t remember if I’ve tried it on the Hedghog, but I see no reason for it to not work. Both converters require 625 line composite video as available from the SCART socket on VCR’s, Freeview/Sky boxes, DVD players, and I’ve also used a video iPod and a Sumvision cyclone media player with both converters. I can’t be 100% sure about the modulator, as I don’t have one, but I guess you will need a source of 405 line material for it to work. Regards Lloyd |
8th Sep 2020, 12:53 pm | #12 |
Thank you Lloyd for your response, that is good to know, I will get one on order at the price, it may be useful for other things if I do not get a 405 TV.
Adrian |
8th Sep 2020, 2:23 pm | #13 | |
You have the right idea on how the converters work. They all need a composite 625 line input 1Vpp. The syncs will be negative. Vol is a standalone 13 Channel Band I/III System A modulator. It needs a 405 line composite 1Vpp input. Again the syncs are negative. Unlike Hedghog Hedghog II can be used as a modulator only. Frank
8th Sep 2020, 2:26 pm | #14 |
From my own past limited searches for info I see that there's a a Mk2 Hedgehog. What's that about? Mk2s of anything always leave a question in my mind that the 'Mk1' version may not have been designed correctly in first place. Not that there's anything wrong with correcting it! So what's the improvement?
8th Sep 2020, 2:33 pm | #15 |
So set top boxes the likes of which came out at the time of the launch of digital TV are suitable for feeding the required signal into the SC?
8th Sep 2020, 4:26 pm | #16 |
Any set-up box that has a SCART socket is suitable. You just need a SCART to phono (RCA) cable. If it only has HDMI you would need a converter.
-- Graham. G3ZVT |
8th Sep 2020, 5:29 pm | #17 |
Hi Steve
The original Hedghog used a EP2C5T144 FPGA development board. I got reports from constructors that the boards that were on the market were of varying quality and that it was a bit of a lucky dip if you got a good one or not. That coupled with the fact that it was probable that at some point the boards would be no longer be made lead to the development of Hedghog II. Hedghog II doesn't use a development board instead it has has the FPGA mounted directly on the PCB. It uses a more modern Cyclone IV FPGA were Hedghog Mk1 used a Cyclone II. There are some circuit changes but nothing major. The only difference in features is that Hedghog II can be used as a System A modulator. There is no real difference in performance between them. Now that there is a Mk1 and Mk2 a constructor can choose between constructing a Mk1 which is a little easier to construct and chancing their luck with the FPGA board or construct a Mk2 and purchasing all the components from a reliable source. Constructing a Mk1 or Mk2 is no small task and I take my hat off to all those that have done so. In their shoes I am not so sure that I'd be brave enough to take it on. I use a set box all the time with a standards converter but not for off air. I use it with a USP stick and record what ever I need to the stick. A stick can hold a lot of film's. I also have a range of test cards on it. Frank
10th Sep 2020, 8:57 am | #18 |
I have recently taken delivery of a HEDGEHOG Mk2 standards converter from Freya.
It is excellent in every way and I would suggest anyone purchasing one of these super units will be happy with it. The Aurora has done us proud allowing these vintage receivers to live again and in my honest opinion the Hedgehog is a very worthy successor. Regards, John. |
10th Sep 2020, 12:04 pm | #19 |
I have bought, yet to be delivered today, a Hedgehog 2 from Freya.
Thanks everyone for your much valued inputs, appreciated.
11th Sep 2020, 7:54 am | #20 |
Received my Hedgehog, super quick service from Freya - thanks.
Can someone supply a link to suitable scart lead with the necessary plugs to connect between set top box and Hedgehog 2 please?
