Old 8th May 2021, 10:29 am   #1
hayerjoe
hayerjoe's Avatar
Default BSR TC4 cartridge specs?
Hi everyone
I'm having problems tracing any specs about the BSR TC4 cartridge, can anyone help? I'm particularly after the output mV
I know it's a heavy unloved cartridge and indeed I am replacing it, but it was fitted as a retrofit (around 1954!) to my 1940s radiogram, and interestingly between the tonearm and the amp an extra potentiometer was added that allowed the output to be modified. I guess this was part of the retrofit kit so you could modify the cart to suits your amplifier (see photo). I put my new cartridge in and even with this potentiometer turned right up volume was a bit low, so I totally bypassed it and volume is great now, so just got me thinking that TC4 must have had a very high output if it needed such a reduction
Hope someone can help with specs
thanks
Joe
hayerjoe is offline
Old 8th May 2021, 1:29 pm   #2
Edward Huggins
Default Re: BSR TC4 cartridge specs?
Yes, it does have a high output of c.550mV. Don't attempt to play any Stereo LPs on it though! Production of these by BSR started around 1952.
Edward.
Edward Huggins is offline
Old 8th May 2021, 6:39 pm   #3
John10b
Take a look at the Sticky on cartridges, there is some information within:-
https://www.vintage-radio.net/forum/...d.php?t=119339
John10b is offline
Old 8th May 2021, 6:41 pm   #4
John10b
I should have said with thanks to Ben who started the sticky.
John10b is offline
Old 8th May 2021, 6:59 pm   #5
simpsons
Joe, it has taken some "off the wall" searching and hopefully what I have found will trigger the memory of others.
The BSR TC4 was used in the Dansette Bermuda record player circa 1960.
The TC4, which plays only mono recorded records, was designed to be used both in single output valve mono record players. Valves such as UL42, EL42 UL84 and EL84.
The BSR TC8H series of cartridges replaced it and a full description of this and other cartridges can be found as a sticky thread above this section titled "Ceramic and crystal cartridge specs." The Dansette record player is also a topic on this site.
Because it was a high output cartridge, the output would need to be reduced when used in a amplifier of higher gain, hence the added volume control and vintage resistor in series with the cartridge.
I am unfamiliar with 1940's radiograms and so it would be interesting to see what valves are used in yours.
Hope this helps
Chris
simpsons is offline
Old 8th May 2021, 11:12 pm   #6
ben
ben's Avatar
Interesting thread. I will have to update the sticky at some point with some new data, but glad you find it useful!
Ben.
ben is offline
Old 9th May 2021, 3:55 am   #7
hayerjoe
hayerjoe's Avatar
Thanks Edward, I'm loving the heft and simplicity of the GU4 deck but have already replaced the TC4 cartridge with one of those Banpa flip-under cartridges, seems to work well. See photo. I design and print the cartridge clip with a 3D printer (highly recommended tool for radiogram restorations) and behind the Banpa cart you can see my attempt at providing some tracking weight adjustment via a threaded bar and some nuts sticking out of my clip
hayerjoe is offline
Old 9th May 2021, 3:56 am   #8
hayerjoe
hayerjoe's Avatar
thanks, Ben's list is my goto PDF, but it was missing the TC4 values (as was the entire internet?!)
hayerjoe is offline
Old 9th May 2021, 7:54 am   #9
hayerjoe
hayerjoe's Avatar
Hope this helps
Chris
Thanks Chris very helpful, and what monsters resistors were in those days, certainly explains why portables of the day required serious muscles!
I found it strange that the pot even at max didnt pass thru 100% of the signal. As I said i totally bypassed it and the resister and volume is much much better.
My radiogram (see photo, lid not yet on) uses 6X5GT, 6V6G, 6S07,ECH85, 6U7G valves
In a bizarre coincidence I was watching James May's "Reassembler" program last night and he was assembling a Dansette Bermuda from scratch. It didnt use the TC4 though, but perhaps the TC8?
hayerjoe is offline
Old 9th May 2021, 9:08 am   #10
Edward Huggins
Hope this helps
Chris
This might cause some confusion. The BSR TC4 was never used in the Dansette "Bermuda". Production of this cartridge ended in early 1955, possibly earlier.
Edward.
Old 9th May 2021, 9:53 am   #11
Ekcoman
Ekcoman's Avatar
Dansette did use in their early models. My old Dansette Minor has one and still works well BUT definitely not for your precious discs. I've dated this model about 1954.
Name:	Dansette Minor (b).jpg
"I really am seriously downsizing "
Ekcoman is offline
