Old 5th Mar 2021, 12:26 pm   #1
vinrads
Default It's nice when a plan comes together.
I had this idea of building a speaker/ power supply for a Telefunken three valve set, the power supply consists of an LT TX for the 4 volt heaters regulated, a 9 volt neg adjustable for the o/p valve grid bias, and HT 120 volt full wave smoothed. the pot on top of the chassis is for adjusting the HT on the detector for best results surprising how low it is around 30 volts. the o/p TX was kindly supplied by Chris (Herald) .
The case was made from a sheet of aluminium, grill all cut out by hand, the lid on the power pack was from a Gecophone purchased from eBay just the case, no innards, I had to reduce it in length, the bottom was made from scratch, an octal socket was fitted on the rear. I am very pleased with the end results. It is just as I envisaged. Mick.
ID:	228295   Click image for larger version
ID:	228296   Click image for larger version
ID:	228297   Click image for larger version
vinrads is offline
Old 5th Mar 2021, 12:50 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: It's nice when a plan comes together.
Very nice job Mick.
paulsherwin is offline
Old 5th Mar 2021, 1:49 pm   #3
Uncle Bulgaria
Uncle Bulgaria's Avatar
That's very smart! A particularly good job on getting it to look the part.
Uncle Bulgaria is offline
Old 5th Mar 2021, 3:41 pm   #4
Petedox
Petedox's Avatar
Well done Mick. I find it hard to keep up with all your projects!
Pete
BVWS Member
Petedox is offline
Old 5th Mar 2021, 7:48 pm   #5
wd40addict
wd40addict's Avatar
Also marketed by GEC:
https://www.radiomuseum.org/r/genera...r_3_model.html
Advert claims 'made in England', hmm...
wd40addict is offline
Old 5th Mar 2021, 8:15 pm   #6
vinrads
It could well be under licence , the case on the Gec one is 8. 3/4 " long where as the Telefunken one is 7.1/4" must have a different paxolin chassis . Thanks for the positive comments Mick.
vinrads is offline
Old 11th Mar 2021, 2:45 am   #7
FStephenMasek
Very nicely done! How well does that radio work?
FStephenMasek is offline
Old 11th Mar 2021, 7:06 am   #8
Gabe001
Nice job Mick, looks great
Ps, particularly enjoyed the title from the "A-team" too
Gabe001 is offline
Old 11th Mar 2021, 9:05 am   #9
vinrads
Hi Stephen How does it perform ? well for a trf it's quite well behaved you do need a good aerial , I think one of the valves is a bit low, if I change the first two valves around that is the detector and first af amp I works better one way round than the other ,I don't have another valve, plus they are very expensive ,It may look like there are no tuning coils they are under the paxolin chassis laying flat .
Thanks all for the positive comments. Mick.
vinrads is offline
