19th Aug 2009, 12:23 pm | #1 |
Philips Turntable
Hi, ive just found a Philips Automatic Turntable, says Type AK 591 on back (only identifying marks i could find), but i cannot find a power supply for it, it has a power cable coming from it but has the round pin on the end for a transformer or something, says 12v on the back of the player, i cannot find a 12v transformer with input for this so can i just use a normal 12v transformer from something else and splice it onto the existing cable on the turntable ?
19th Aug 2009, 12:40 pm | #2 |
Re: Philips Turntable
Well, you'd have to know whether it was 12V AC or DC; and if it was DC, which polarity the appliance was expecting and whether it was 12V regulated or unregulated.
Can we have some pictures of the inside?
20th Aug 2009, 12:42 am | #3 |
This is almost certainly part of a mini system or similar - very common in the late 80s- early 90s. in my experience the motors used in these record decks were 12v DC. if in doubt open it up and check the internal wiring and motor terminals.
Regards, Ben. |
22nd Aug 2009, 3:08 pm | #4 |
Hi, i managed to locate the turntables original hifi unit but the turntable is brocken, the turntable spins backwards so im gonna invest in a new turntable, Many Thanks for the help.
23rd Aug 2009, 10:18 am | #5 |
Are you running the T/T from an external power supply? If so, it sounds as though the polarity's wrong. Try reversing the connections, and it should run the right way!
23rd Aug 2009, 12:05 pm | #6 |
I thought exactly the same thing but was too shy to say so
