Old 23rd Jan 2022, 11:16 am   #1
greencroft
Default Pye P76F
Anyone ever used the pickup connection
at the back of this set or any other set for Bluetooth connection.
If so any recommended products. Thanks
greencroft is offline
Old 23rd Jan 2022, 7:43 pm   #2
Ed_Dinning
Default Re: Pye P76F
Hi, the PU connection was normally fed from a quite high output pickup. I would have thought a bluetooth device should have enough output to drive it, but on one set I found I had to use a small 4:1 step up transformer to get good volume. Give it a try and see what it sounds like.
If there is a radio/ gram switch that may have oxidised contacts so worth giving it a good clean
Ed
Ed_Dinning is offline
Old 24th Jan 2022, 4:00 pm   #3
JoshWard
JoshWard's Avatar
Yes, I fitted a Bluetooth module to a P76F. I just bought a cheap generic unit from eBay. I powered it via a seperate transformer to avoid interference (and it needs to a proper transformer rather than a switch mode power supply!). It works very well, the P76 is a lovely sounding set.
JoshWard is offline
Old 25th Jan 2022, 11:21 pm   #4
greencroft
Thanks for the reply. Can you recommend a transformer?
Old 26th Jan 2022, 8:22 pm   #5
Ed_Dinning
Hi any small transformer of about 3 or 4 to 1 ratio should do, it only needs to be small.
RS used to do small intervalve transformers like this. I posted an earlier thread on this about 2 or 3 weeks ago.
If you are out towards Newcastle I may be able to find you one if you PM me
Ed
