22nd Jan 2022, 5:09 pm | #1 |
You photoshop experts
This scan of two tuning scale dials are reversed in preparation for printing on to clear sticker paper. However, a test print onto paper shows that the yellow cast (as result of the original scale having yellowed with age) is causing a problem. Basically I want a 'clean' black and 'clear' scan that I can print from. I've tried to remove the yellow cast using contrast and brightness but you can only do so much before the lettering itself starts to get affected. If I send the scan to someone who is adept at Photoshop, could they remove the yellow cast so that it prints just the black lettering please? Cheers.
NB, the image below is a screen grab (not the original hi res scan) for reference only.
22nd Jan 2022, 5:36 pm | #2 |
Re: You photoshop experts
For this sort of thing, I use the "line art" option of my Epson scanner that produces pure black and white images directly.
On my Win 98 and XP computers, it is possible to change the attributes of an image file from colour to monochrome, thereby removing the colour information. 1 bit monochrome is an option. Last edited by emeritus; 22nd Jan 2022 at 5:47 pm. Reason: typos |
22nd Jan 2022, 5:48 pm | #3 |
Can you just convert to monochrome, then increase the brightness and contrast to lose the light grey background? I don't use Photoshop so can't give detailed instructions.
22nd Jan 2022, 6:21 pm | #4 |
Something like this?
Steve
https://www.radiocraft.co.uk |
22nd Jan 2022, 6:52 pm | #5 |
Personally I use GIMP. One way of doing it would be to select the colors>levels option. Then select the black dropper and click on what should be black then select the white dropper and click on what should be white.
You can also just convert the image to black and white by adjusting the corresponding threshold. You need a high res image for that or the edges can be a bit ragged.
Stuart The golden age is always yesterday - Asa Briggs |
22nd Jan 2022, 6:54 pm | #6 |
Exactly Steve. If the lettering starts to degrade it can easily be touched up pixel by pixel.
As Stuart suggests, there are lots of ways of achieving the result. |
22nd Jan 2022, 7:01 pm | #7 |
On the version of Photoshop I have, Image, Adjustments, Black and White, then boost yellow looks like it might be worth a go.
22nd Jan 2022, 7:07 pm | #8 |
On the low definition image above, I first converted to monochrome, then changed the brightness and contrast, applied a little gamma correction, and finally some coarse and fine sharpening. I use a twenty-year-old edition of Paintshop Pro.
Steve
22nd Jan 2022, 8:41 pm | #9 |
It was a while ago that I did this, try the curves function, this lets you map any original value to another by wiggling a line. Instant feedback too.
22nd Jan 2022, 9:13 pm | #10 |
