19th Jan 2022, 8:08 pm | #1 |
Bush DAC90A - volume pot way out of spec
I see my volume pot is more like 200k than 500k.
Given the volume appears to be very acceptable even at low settings, and that the pot (including a DPDT 250V switch) is hard to find, I was minded to simply put a resistor in series with the top leg of the track. Probably 150k or so. Anyone see a problem with that? |
19th Jan 2022, 8:17 pm | #2 |
Re: Bush DAC90A - volume pot way out of spec
It will reduce the gain of the AF stages, but that may not matter.
If it sounds OK as it is, I would leave it alone. |
19th Jan 2022, 8:19 pm | #3 |
It will reduce your available volume quite a bit.
If you leave ir as it is it will do no harm. It might be worth measuring again with it out of circuit in case there are any parallel paths Ed |
19th Jan 2022, 8:29 pm | #4 |
Thanks chaps.
The 'available volume' is probably excessive, hence my temptation to put something in series. As you might well expect, down the lower end of the control I bump into the switch mechanism a bit too quickly also. |
19th Jan 2022, 8:54 pm | #5 | |
20th Jan 2022, 1:46 pm | #6 |
I can't see how the volume pot can reduce in value. Something weird is going on unless the 500k pot has been changed, or the wrong track put in during manufacture - something I've never heard of.
I'd disconnect two of the connections and check again resistance if you haven't done this already. Maybe the cap across it is very leaky, although at 100pF that too seems unlikely. Or maybe it's got covered in conductive dirt, but if that were the case I'd expect other problems elsewhere. Last edited by Ian - G4JQT; 20th Jan 2022 at 1:59 pm. |
20th Jan 2022, 2:21 pm | #7 |
It does say 500k LOG on it and appears original.
It's been cleaned. I will double-check in case of unexpected leakage, but I assumed same re the bypass. My suggestion as to why is: these radios appeared to be quite loud and so I imagine the pot has spent 70 years scrubbing around the low end, which will have thinned the carbon track and therefore 'lost' resistance where it had most. |
20th Jan 2022, 2:52 pm | #8 |
I have found very large variations in the measured resistance of some NOS vintage potentiometers when compared to the markings stamped onto the housings.
I have read that distortion is increased if the load on the standard diode demodulator circuit is reduced. I would prefer to add a resistor to the potentiometer if there is plenty of volume available. If a potentiometer is worn and conductive material has been removed from the track, the end to end resistance of the potentiometer should increase. |
20th Jan 2022, 6:23 pm | #9 |
It is something that is often overlooked as a wide variation in resistance appears to have little effect and does no harm. I have had 500K pots read over 2M mostly in TV receivers. If it works ok best leave it alone. Think of Pandora's Box. J.
20th Jan 2022, 6:37 pm | #10 |
From Radiomuseum: A common Problem is: Volume doesn't go to zero on a strong signal if Potentiometer is at the CCW stop. Remedy: a 330 picofarad capacitor between Grid and Kathode of the UBC41. Short leads are important, and perhaps replacement of the big 100k resistor to the grid by a smaller sized one of the same value.
20th Jan 2022, 8:49 pm | #11 |
Possibly... And in that case, there'll be even more of the control range crammed into the first quarter-turn!
22nd Jan 2022, 11:49 pm | #12 |
It seems unusual for the track to lose resistance, it usually goes the other way.
A relatively cheap way to temporarily fix things is with a HB pencil on the track, a minute of scribbling can bring things back to where it should be but this only applies to a pot that's got crackly low end. I usually test things with the valves removed, never had major issues doing meter checks this way.
Rick, the annoying object roaming the forum. |
23rd Jan 2022, 9:57 am | #13 |
Yes, was incorrect in my thinking re track changing resistance.
I have measured it fully out of circuit and sure enough 200K. 150K now in top leg and seems to work fine. |
