5th Jan 2022, 6:56 pm | #1 |
Small diameter gramophone needles?
I had a look inside the pickup of the RC49 today. It appears to take an old fashioned gramophone needle, but one of reduced diameter - my standard ones are too big. Does that make sense? Any ideas as to where to source?
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
5th Jan 2022, 7:23 pm | #2 |
Re: Small diameter gramophone needles?
Looks like it employs the HMV Silent Stylus or Columbia '99' type special needles. Note the lack of a needle screw. John.
5th Jan 2022, 9:55 pm | #3 |
6th Jan 2022, 12:42 am | #4 |
Thanks Barry. Are they smaller in diameter than standard, do you know?
6th Jan 2022, 1:58 am | #5 |
I too would like to know the diameter of the semi-permanent type referred to, e.g. the Columbia '99' as I don't have any examples here and I'm doubting what I thought I knew.
Conventional (single-play) needles came in three typical sizes: Loud tone / extra loud / full tone: 1.5mm Medium tone: 1.3mm Soft tone: 1.0mm The traditional multi-play needles (10-20 plays in acoustic or 'heavy' magnetic head) were normally 1.5mm. But the semi-permanent type in question (c.100 plays in lightweight magnetic head only) often black with a silver point, were IIRC similar to soft tone diameter, but I am not now sure if they were actually 1mm so don't quote me on that one. |
6th Jan 2022, 2:18 am | #6 |
Those HMV needles shown in the advert are definitely not suitable, I've got a pack here in front of me right now and they're a thick stem gold plated type. I used to have a part full pack of the Columbia 99 type, but I seem to have lost it several years ago, but they are a special, short and very thin needle, not anywhere near the same as those HMV ones.
6th Jan 2022, 10:13 am | #7 |
I have a couple of HMV "Silent Stylus for use with HMV Hyper Sensitive Pickup" needles here. They are 0.86mm wide and 10.86mm long
Paul |
6th Jan 2022, 10:41 am | #8 |
The difference in size of the soft tone needle compared with the Columbia 99 miniature needle.
Originally designed for the HMV lightweight Hyper Sensitive pick up it will play a large number of 78s without reduction in quality. Note the black paint around the shaft that can just be seen on your picture. I hope your pick up coil is OK. They go O/C, wound with thousands of turns of 50 gauge wire. Good luck with it. John. |
6th Jan 2022, 11:15 am | #9 |
Just for completeness, HMV 'Silent Stylus' packet with reverse information. Note they have a black painted shaft often confused with the chrome long play needles that play 10 records designed for the early autochangers. Their shafts are usually painted red. Any attempt to force any other type of needle into the HS pick up with ruin it. John
6th Jan 2022, 11:28 am | #10 |
I have these needles, 0.033in diameter, if they are any use PM. Only 8 left in pack.
Alan |
6th Jan 2022, 11:39 am | #11 |
6th Jan 2022, 1:26 pm | #12 | |
6th Jan 2022, 1:32 pm | #13 |
PM sent to Alan. Thanks to all - very helpful. I hadn't realised the significance of the differing needle dimensions. This old Collaro is so gorgeous that, all being well, it will be my main 78 player.
6th Jan 2022, 4:02 pm | #14 |
Aren't these needles for microgroove records? The SHURE head on my Collaro deck used them.
6th Jan 2022, 9:51 pm | #15 |
No B. These were introduced around 1937/38 together with the Hyper Sensitive pick up extensively used by the BBC and a large range of EMI grams just before the war for 78 RPM records. The Collaro 33/45 used a miniature sapphire stylus similar in appearance to the steel C99/HMV SS.
There was a sapphire that could replace the SS for 78. I have a couple somewhere. J. |
7th Jan 2022, 6:31 pm | #16 |
when i had a marconi table top radiogram it used very thin steel needles but shorter than a standard wind up gramophone, i used to purchase new steel needles Extra Soft Tone and with wire cutter trim them to size, worked a treat and would play numerous sides as well , im pretty sure theres a gramophone needle seller on ebay who does all the "tone" versions
7th Jan 2022, 9:57 pm | #17 |
I posted this link in another recent thread but for completeness will repeat it here in case the original poster hadn't seen it. Miniature needles tipped with a sapphire are still available from musonic - both ones suitable for 78's and also ones suitable for mono long playing records. These will fit the head under discussion. Here is the link:
https://www.musonic.co.uk/?s=hmv+min...&type_aws=true Last edited by Phonosandradios; 7th Jan 2022 at 10:02 pm. |
8th Jan 2022, 1:15 am | #18 | |
23rd Jan 2022, 2:39 pm | #19 |
I have 5 of these needles for the supersensitive pickup,thin,black on the blunt end.PM me if you would like them,FOC.Les
