Old 18th Jan 2022, 6:30 pm   #81
Philips210
Default Re: Haigh Wobbulator is there sufficient interest for a PCB?
My kit arrived today. Look forward to building it when time permits. Thanks Peter.
Regards,
Symon
Philips210 is online now
Old 18th Jan 2022, 6:55 pm   #82
Andrewausfa
Andrewausfa's Avatar
Thanks Peter, a nice package in the post today.
Regards - Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 18th Jan 2022, 7:23 pm   #83
Trevor
Thanks Pete
delighted to receive my unit today
Well worth the money
Trev
Trevor is offline
Old 18th Jan 2022, 10:04 pm   #84
turretslug
turretslug's Avatar
Mine turned up today, too- very pleased and impressed, a great project for the near future!
Thanks, Colin
turretslug is offline
Old 18th Jan 2022, 10:27 pm   #85
cathoderay57
Hi Peter, mine's here too. Many thanks for such good work.
Jerry
cathoderay57 is offline
Old 19th Jan 2022, 8:40 am   #86
steve102
I received my kit yesterday thanks. Is there a list of the additional components that I need to obtain?
steve102 is online now
Old 19th Jan 2022, 9:03 am   #87
Sundog-
Sundog-'s Avatar
Hi Peter, the kit arrived yesterday, it looks great!
Thank you.
John
Sundog- is offline
Old 19th Jan 2022, 11:07 am   #88
Andrewausfa
Hi Steve, there's a schematic (v2) a couple of pages back called Kincad Wobbulator and Timebase which has all the components listed on it.
Andrew
BVWS Member
Old 19th Jan 2022, 1:42 pm   #89
steve102
Andrew
Thanks Andrew, I'd missed that.
Old 19th Jan 2022, 3:00 pm   #90
Boulevardier
Hi Peter
My kit arrived safely this morning. Excellent documentation included, and a superb quality PCB. Many thanks again for your generous and dedicated efforts on this project.
Mike
Boulevardier is online now
Old 22nd Jan 2022, 5:45 pm   #91
cathoderay57
Hi folks, I've assembled my kit. It worked first time. It's only run up on the bench and I've been testing it on the scope. Haven't tried to wobbulate anything yet. The outputs all seem to be doing what they are supposed to. Here's the frequency ranges I'm getting on the counter:
1. 342-644 KHz
2. 1.0-2.1 MHz
3. 2.9-6.1 MHz
4. 5.2-16.9 MHz
On Range 4 above about 10.4 MHz the frequency setting is unstable but I think this is because of the long wires to the range switch. Grabbing them together with my hand stabilises things so hopefully when I get it in the box I might be able to shorten them a bit and/or position them to avoid this problem.
Cheers, Jerry
Old 22nd Jan 2022, 6:34 pm   #92
Electronpusher0
Thanks for the update Jerry, glad it works!
I think you are right about the switch wires.
Peter
Electronpusher0 is offline
Old 26th Jan 2022, 11:43 pm   #93
GeorgeChristofi
I would certainly be interested if a second batch comes into fruition. Sure, I have a commercial sweep generator but there is something inherently satisfying in using home builds.
GeorgeChristofi is offline
Old 27th Jan 2022, 10:27 am   #94
eddie_ce
eddie_ce's Avatar
George,
it is for the same reason that I have asked for my name to be put down for a second batch if there should be one.
I don't need one as I have several other options, but there is something satisfying in home build.
Eddie
BVWS Member.
Friend of the BVWTM
eddie_ce is offline
Old 27th Jan 2022, 1:54 pm   #95
Electronpusher0
There probably will be another batch, see post #76.
Peter
Old 28th Jan 2022, 11:37 am   #96
Vintage_RC
Vintage_RC's Avatar
Hi Peter, just to let you know my kit arrived yesterday.
Thanks, Alan
Alan G6PUB, BVWS
Vintage_RC is offline
Old 31st Jan 2022, 11:09 pm   #97
Andrewausfa
I started building the wobbulator tonight and came across a small issue, R11, I can't see it on the circuit diagram! Could someone point out if it's just my eyes or is it missing and if so, what value?
Thanks - Andrew
BVWS Member
Old 31st Jan 2022, 11:31 pm   #98
bc312
bc312's Avatar
Andrew
R11 is 1 megohm, and is connected to the junction of C7 (270pF) and the Gate of Q2, to Ground. It is missing from the schematic but is on the pcb.
Mike
Leave me alone - I know what I'm doing.
BVWS member, EUG, G-QRP
Radio Bygones/Radiophile
bc312 is offline
Old 31st Jan 2022, 11:41 pm   #99
Andrewausfa
Super thanks very much! Sometimes you can't see for staring and doubt yourself
Andrew
BVWS Member
Old 1st Feb 2022, 2:15 pm   #100
Electronpusher0
I thought I had posted the schematic with the missing resistor but obviously I didn't.
Final Schematic attached.
Sorry about that.
Peter
