6th Jan 2022, 8:04 pm | #21 | |
Re: TV22/24 metrosil
Helder Last edited by Helder Crespo; 6th Jan 2022 at 8:20 pm. |
6th Jan 2022, 9:08 pm | #22 |
Hi Helder, tempco of copper is about 0.4% per 100 degC, so not asa much as you have seen, that could be doen to poor insulation on the very fine wire.
Most of the TV 22 LOPTs that I've done had badly carbonised primary windings. These gave the fault of quickly reducing EHT over about 1/2 hour until the picture vanished. Ed |
6th Jan 2022, 9:43 pm | #23 | |
My first LOPT had a shorted primary (basically the carbonisation issue you mention) but was rewound. My second LOPT is original but was fully stripped and varnished; it has been running for 8 hours or so every other day since more than 1 year ago without any problems. I'm actually watching BBC news on my TV22 right now. I do get a reduction in EHT over a period of 1/2-1 hour with both LOPTs, but this stabilises at a relatively high value of around 7kV (vs. 8-9kV after a 5 minute warm up from cold). This is fine, I guess, and my issue is the much larger decrease in EHT with beam current - I have measured EHT down to 3kV or so when the brightness is set to maximum. Helder Last edited by Helder Crespo; 6th Jan 2022 at 10:04 pm. Reason: factor and typo |
7th Jan 2022, 9:51 pm | #24 |
Hi Helder, my Kaye & Laby and a couple of other books give it as 0.004 per deg C at 20C, so yes 4% per deg C.
I've just rewound a TV22 Lopt and with first light, raster only I have 7KV DC eht at full brightness and 7.5KV with zero beam current, measured on an electrostatic meter. The acceprable figure is, I believe anything above 5.5kv Ed |
7th Jan 2022, 11:29 pm | #25 |
I can't see how the losses seen, either due to load or heating of a decrepit winding, can be resistive in the classic sense. Even at 1mA of beam current - a huge amount - the loss across 800 ohms would still only be 0.8 volt. Yes, I know it's not smooth DC in the winding but am I otherwise missing something?
Steve
https://www.radiocraft.co.uk |
8th Jan 2022, 12:06 am | #26 | |
Helder |
8th Jan 2022, 12:11 am | #27 | |
Does your CRT have good emission? I'm asking this because if it's low emission, the load is not the same as for a higher/normal emission tube. Helder |
8th Jan 2022, 12:35 am | #28 |
Hi Helder
I will be interested to see if your treatment of the laminations will help. But this effect is also seen in transformers that have cores that are not laminated. I had a similar problem with the EHT transformer in a Ekco TSC48. The core in it was made from a material that looked like ferrite. Frank
8th Jan 2022, 12:53 am | #29 | |
In your case eddy currents are not an issue but there may be other losses, e.g., a failing insulation and/or water ingress in the EHT winding, which gives symptoms similar to a partially shorted turn, as mentioned by Heatercathodeshort and Panrock. The reason I suspect the laminated iron core is because such insulation related losses are highly unlikely in my LOPTs due to the treatments they have been subjected to (one of them has also been rewound). I will post my findings in the forum once I finish the laminations and test the LOPT. Helder |
8th Jan 2022, 7:15 am | #30 |
Yes, I agree that in your case the partial shorted turns effect in the overwind is not a factor (and as we have seen the effect of DC resistance on regulation will always be insignificant). Therefore, impaired hysteresis in the core could already be present when cold - as shown by the poor regulation v. beam current. Then, when it then heats up, this gets still worse - causing reduced EHT among other things.
I am not absolutely clear about the present condition of your internal (non overwind) windings? 'Carbonisation' here (as pointed out by Ed Dinning) could bring back the partial shorted turns effect with a vengeance, with consequent heating. You're doing sterling work here, Helder. I look forward to the results. Steve
8th Jan 2022, 9:01 pm | #31 |
Hi Helder, tube on this set is not brilliant, but should give a watchable picture when finished, emission showed as quite good on a crude tester.
The figures given were for max brill and tube cutoff. Measured on a 25KV EHT meter, so could be over reading a bit at 7KV. New valves fitted and this set has a PL81 LOP valve. Transformer had pri winding rewound; EHT as original. Some rust on the Lams but not cleaned off. Ed |
12th Jan 2022, 6:31 pm | #32 | |
1) my first LOPT (the original one on my set) was not treated in any away and developed a short between primary and secondary a few days after first light (not uncommon with untreated TV22 LOPTs); it was then rewound with new materials by Mike Barker and has been working since then. 2) my second LOPT came from a scrap chassis that I purchased for parts, and even though it was in a relatively poor state, all of its windings measured ok resistance and inductance wise, as did the windings in all remaining wound components in the same chassis (including the usually O/C frame blocking oscillator transformer). This second LOPT was dehydrated in white spirit and varnished prior to being tested in my set and has also been working since then. While it would be possible for the primary/secondary windings in this second LOPT to have a weak/damaged paper insulation, this usually only happens if you power up an aged LOPT without first treating it, or at least drying it thoroughly, which was not the case here. 3) I did a ring test to both LOPTs, including simulating a shorted turn with a wire loop around the core. The observed damped oscillations without the shorted turn are virtually the same for both transformers, and similar to other ring tests performed on TV22s and reported elsewhere. Below you have two scope screenshots of the ring test on my second LOPT (the electrically original one that has been varnished), without and with the "shorted turn". The third image is a photo of my first LOPT (with pitch removed) undergoing a similar test, where I shorted one of the secondary windings - this results in a shorter period of the fast oscillations under the damped envelope. These tests were performed with a 5V square wave as the excitation voltage, and so one cannot rule out the possibility of leakage for nominal operating voltages. In any case, such leakage would have to occur in both the varnished and the rewound LOPTs, since they both show exactly the same behaviour (poor EHT regulation with increased beam current), which is very unlikely since the two transformers have very different primary sections (new rewound vs. original+varnished). Once I manage to get some results with the treated core I may post them in a dedicated thread where I will start by giving a clear graphical description of the two LOPTs and their characteristics, to facilitate checking/understanding what they have in common as well as their differences. Even though I believe that core saturation issues may be behind the poor EHT regulation observed with both LOPTs, I think that a proper study should involve measuring/quantifying the different waveforms at various points in the line output stage, in the line of the approach and results given in Hugo Holden's detailed TV22 report. Helder Last edited by Helder Crespo; 12th Jan 2022 at 6:49 pm. Reason: typo |
12th Jan 2022, 6:39 pm | #33 | |
Helder Last edited by Helder Crespo; 12th Jan 2022 at 6:54 pm. |
