Old 10th Aug 2022, 12:47 pm   #1
Syrinx1
Default Light bulb Identification.
Hello,
Just wondering if anyone is able to Identify this old light bulb \i found among my stuff.
The only marking I can see are the numbers 403 on the base.
Thanks,
Jonathan.
ID:	262557   Click image for larger version
ID:	262558   Click image for larger version
Syrinx1 is offline
Old 10th Aug 2022, 12:54 pm   #2
Heatercathodeshort
Heatercathodeshort's Avatar
Default Re: Light bulb Identification.
At first sight I thought it was an old transmitter dummy load but I would say it is a photo cell? John.
Heatercathodeshort is offline
Old 10th Aug 2022, 1:08 pm   #3
Silicon
Have you tested it with a series resistor to see if it is a Neon?
What size is it?
Silicon is offline
Old 10th Aug 2022, 1:09 pm   #4
Ian E G7OLT
Ian E G7OLT's Avatar
I agree, it's a photocell.
Ian E
Addendum: See https://www.electricstuff.co.uk/Photocell.html "2nd row, 2nd tube from the left.
Ian E G7OLT is offline
Old 10th Aug 2022, 1:17 pm   #5
Syrinx1
Hi, thanks.
I haven't performed any testing on it yet. Looking at the construction of photo cells it does look structurally similar.
Syrinx1 is offline
Old 10th Aug 2022, 1:19 pm   #6
Refugee
Refugee's Avatar
I also agree that it is a photo cell.
Refugee is offline
Old 10th Aug 2022, 1:22 pm   #7
Syrinx1
It's about the same size as a domestic incandescent light bulb, and has two wire connections that feed into the side of the base.
Syrinx1 is offline
Old 10th Aug 2022, 4:20 pm   #8
The Philpott
The Philpott's Avatar
Does it's resistance change depending on how much light falls on it? If so...it works.
Dave
The Philpott is offline
Old 10th Aug 2022, 5:35 pm   #9
Heatercathodeshort
It may need an 'exciter' voltage to kick it off. Not sure. John.
Old 10th Aug 2022, 6:01 pm   #10
Syrinx1
I'll do some experimentation later tonight (no innuendo intended).
Syrinx1 is offline
Old 10th Aug 2022, 6:24 pm   #11
barrymagrec
https://www.pinterest.com/pin/7a-we-...9843843643850/
barrymagrec is offline
Old 10th Aug 2022, 6:45 pm   #12
Syrinx1
I managed to sneak off and test this, and indeed resistance does increase in the dark so this is definitely a phototube. I see these were used for "Optical sound" in film projectors among other things.
Would these also have been used in laboratory equipment - spectrometers etc?
I also had some photomultipliers in the same storage box.
Syrinx1 is offline
Old 10th Aug 2022, 6:53 pm   #13
Syrinx1
Ian E
Yes looks identical to the one indicated in your link Ian.
Syrinx1 is offline
Old 10th Aug 2022, 6:55 pm   #14
Syrinx1
Originally Posted by barrymagrec View Post
And identical to this one too in appearance.
Thanks.
Syrinx1 is offline
Old 11th Aug 2022, 3:39 pm   #15
Graham G3ZVT
Graham G3ZVT's Avatar
What PM tubes do you have?
I've got this 931-A
Graham.
G3ZVT
Graham G3ZVT is offline
