14th Jul 2022, 10:50 am | #1 |
Old coil switch thing. Identified as a Ruhmkorff induction coil.
Hello all, just bought this because I’m not sure what it is (it’s becoming a habit!)
Its base is about 50mm x 125mm, the coil connects to two terminals at the top of the bobbin (one is broken off/missing) It is not a solid base, it has a removable wooden base (not yet removed) There is a ‘trapezoidal?’ switch at the bottom (broken and screw missing) I would have thought that when the coil was energized it would break the connection between the vertical posts, one with spring and one with adjuster, but they are permanently connected. I was told it was a Morse key, but obviously not Any ideas? Many thanks Philip |
14th Jul 2022, 11:10 am | #2 |
Re: Old coil switch thing
Looks like an induction coil and interruptor. If the insulation is still good it should produce some good sparks.
14th Jul 2022, 11:11 am | #3 |
I would say its a morse receiver. It would have "buzzed " on receipt of a signal.
I am probably wrong, but that rings bells in my head. Joe |
14th Jul 2022, 11:24 am | #4 |
Definitely not a morse key.
Might be an electric shock coil.
14th Jul 2022, 11:38 am | #5 |
Looks similar to a Ruhmkorff induction coil as in this link.
https://antiquescientificgadgets.com...on_coil_2.html Dave
14th Jul 2022, 11:44 am | #6 |
Looks like an early 20th century medical coil (shock treatment machine).
14th Jul 2022, 11:49 am | #7 |
It's certainly an induction coil and may be an electric 'shocking coil' - once believed to be therapeutic. It looks rather small to be a sparking induction coil, but it's difficult to be sure from the photos. Comprehensive info at https://en.wikipedia.org/wiki/Induction_coil .
I'd be undoing those brass wood screws and whipping off that wooden plate from the base to see what connections lie within. The coil itself will have a primary winding - probably fairly robust wire, and a secondary of many many turns of fine wire. You'll be very lucky if the secondary is still complete. The primary circuit is completed through the contact breaker just like a traditional electric bell trembler and is probably designed for a battery from 3V to 6V. I'd first work out which connections go the primary and try wiring it up via the contact breaker (needs cleaning with fine sandpaper). Once you've got it buzzing, see what comes out of the secondary. Martin
BVWS Member Last edited by Hartley118; 14th Jul 2022 at 12:11 pm. |
14th Jul 2022, 12:44 pm | #8 |
Yes, definitely a Ruhmkorff induction coil.
I think they may have been used in school science lessons, perhaps in the 1930s. I went to an inner city secondary school in Nottingham from 1950 - '54. All of the text books and equipment were pre-war cast-offs from the Grammar School. I recall the science teacher demonstrating a Ruhmkorff induction coil, in part, to to explain how an induction coil is used to create a spark to ignite compressed gases in the 'Otto cycle' of a four stroke internal combustion engine. The underside of the coil was stamped 'Mundella Grammar School', so I guess it dated from the 1930s. I picked a Ruhmkorff coil up from the NVCF in 2015 for a couple of pounds. It needs re-wiring and a new base, which I've never got round to making. It does work, and boy does it tingle if you're minded to hold the output terminals! Some pics attached, and a diagram showing how - when the trembler vibrates and induces a stream of low voltage pulses in the iron cored primary coil - that in turn induces a much higher spiky voltage in the induction coil, which appears at terminal marked 'G'. (Fully explained in the Wiki article linked in the previous post). It would have had two metal tubes about 15mm diameter, and 7.5cms long connected by wires to the terminals. A party trick was for several people in a circle to hold hands and the end two to hold the tubes, causing the current to flow through the group. Didn't take long before someone let go!
14th Jul 2022, 1:26 pm | #9 |
Thank you everyone, Yes it certainly looks like a Ruhmkorff induction coil, so far I have resisted the urge to take the screws out of the bottom as I have too too many things in bits at the moment, But I think it has earned it place for a bit of restoration and a search for a suitable terminal for the one that is missing.
I never cease to be amazed at the knowledge and help on this forum. I may be coming back for advice on rewinding the coil! many many thanks again Philip |
14th Jul 2022, 1:40 pm | #10 |
Here's my small collection.
Ideally run from a 6 volt accumulator - that's a 6 volt lead acid battery. Don't try to run one from a modern power supply - the back EMF will likely blow it into next week! |
14th Jul 2022, 4:53 pm | #11 |
Well I suppose it had to be done.
I've got period accumulators, but I'm not filling them with acid at this point in time, so I got a car battery and a hefty ballast resistor to limit the current and we had high voltage sparks. They were running a bit over voltage and the larger induction coil should really be capable of performing better, but at some point in its life it's been left connected to a supply with its contact breaker in the fully closed position, causing overheating and quite a lot of wax has run out, as can maybe be seen. The smaller coil isn't encased in wax. Photos below show the spark discharge from both coils, which is continuous. Shown in a darkened room, and also with curtains opened to show the setup. |
14th Jul 2022, 6:11 pm | #12 |
That seems like fun, certainly on the to-do list!
14th Jul 2022, 8:23 pm | #13 |
Re: Old coil switch thing. Identified as a Ruhmkorff induction coil.
Yes, it's certainly fun - filled the room with ozone yet again!
I'll expect yours to be up and running, producing a stream of sparks with pictures to prove by this time next week at the very latest - no excuses! The same with David's example. It just needs a bit of fettling (like these things always do) to get it sparking - just so long as the secondary winding is still in tact. I can't remember if I've ever removed the base from either of my examples, but David's example should be fine with that original wiring - it's all spaced out enough not to short out. It looks like it's lined with hardboard, unless it's made of hardboard with a wood veneer on the outside. It's years since I've 'played' with mine in anger, and I thought that the gap that the spark could jump on the larger coil was bigger, but having looked at the spec. it seems like it's performing near enough correctly, with it being not far off the quoted 30 mm. They were still being made in that style in the early 60s. |
14th Jul 2022, 9:08 pm | #14 |
Hi Philip, make sure you dry it out well before attempting to operate it.
It looks a lot like some of the home made units described in some of my Model Engineer booklets from 1910 Ed |
5th Aug 2022, 3:41 pm | #15 |
One thought/note of caution. In my 1890's 'Boys Modern playmate' book which has instructions on how to build one of these coils (and how to make the Potassium Bichromate cells to run them), the suggestion is to use the hollow rectangular base to hold 40 sheets of tin foil (inerleaved at alternate ends), interspersed with oiled paper 'to form a simple capacitor which will 'greatly improve the performance'. How good such an item would be after 100+ years is a moot point BUT you might just get a hefty belt off it if you've run the coil.
5th Aug 2022, 4:28 pm | #16 |
Attach a few tens of feet of wire to the output and you will easily wipe out the neighbours digital TV reception...
