Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps. |
26th Feb 2024, 10:47 pm | #1 |
More surplus items! Components, Tapes, etc - Have a look!
Hi All,
More stuff to go, all good quality items, reasonably priced as always. Postage: £2 - £2.50 (large letter items) £4.00 for packet sized items You know the drill chaps, I combine post, etc. Please leave anote in the thread and send a PM with your requests. No hat. 1. 15x Mullard/Philips 680uf 10V 108 Series long life capacitors. Measure excellent, great quality. £4 (or 3 lots for £10) +post (6 lots available) 2. Lot of mixed heatsink washers, TO3, TO-220 TO126 etc. Handy to have when building and repairing! £2 + post 3. 4x push grip Grounding terminals, panel mount. £2 + post 4. 5x RS 2N3819 classic FET transistors. Quality New Old stock originals! £3 + post 5. RS ZN1034E New old stock Precision timer/counter IC's Hard to find now! £3 each + post
...where on earth did that spring/screw go?? |
26th Feb 2024, 10:49 pm | #2 |
Re: More surplus items! Components, Tapes, etc - Have a look!
6. Selection of NOS Zener diodes, very useful voltages 5V1, 5V6 12V 15V. Quality New Old stock items. (packs on left have 4 diodes each, sealed packs on right have 5 each)
£3 + post 7. Set of 6 mini 'Dremel' type cutting/shaping tools for miniature work. Sealed in pack £4 + post 8. 100x BZX85C 7V5 1.3W Zener diodes, NOS. £3 + post (2 lots available) 9. 20x SRC 150pf silver mica caps. 200V working. New old stock £3 + post 10. 13pcs Wima 0.22uf 100V MKS2 5mm pitch polyester caps £2 + post
26th Feb 2024, 10:51 pm | #3 |
11. 10x RS 100pf 160V polystyrene capacitors in sealed RS pack. Interestingly, this pack has the wrong insert in it! (Says 10uf electrolytic caps!)
£2 + post 12. 32pcs ITT 0.1uf 100V polyester capacitors. Ex equipment. all good, fine to re-use. £3 + post 13. Mullard C280 0.022 & 0.033 caps in 'Seme' packs. (14x 0.033uf & 9x 0.022uf). £2 + post 14. 20x Philips 3300pf 160V 1% polystyrene caps. Extended foil design, the best! £3 + post 15. RS multiturn pot, 1K ohm. Very high quality, suits test gear etc. £3 + post
26th Feb 2024, 10:52 pm | #4 |
16. 4x 1960's Belling Lee 1.25" Fuseholders, panel mount.
Used, but good, sound condition. £4 + post 17. SONY Headphone amplifier module. High quality, based on the Mitsubishi M5218 IC which is very effective for driving a wide range of headphone types. Came out ofd posh CD player that was 'retired'. £5 + post 18. 4x NEW RS switches, 3x Push to make, 1x SPDT toggle. Really nice 1970's items ! £3 + post 19. 2x RS 6.8mH 2A Suppression chokes, new in pack. £3 + post 20. 7x New Sony 3.5" HD floppy discs, never used Reliable as far as floppies go! £3 + post
26th Feb 2024, 10:53 pm | #5 |
21. Mitsumi Tape head set. (Ex martantz tape deck)
Very good condition, complete with Erase head too. Wiring complete with headers attached, (check pinout) £4 + post 22. Aerial base for transmitter? Heavy, with a good run of RG58 cable £3 + post 23. Valve screening cans, all in good condition. B9A and B7G types £3 + post 24. Ice cream tub of mixed components I dont have time to sort out.. resistors, caps switches etc etc £4 +post, have a rummage! 25. 11x Vintage used cassette tapes, including a few SONY & a BASF chrome, and one TDK metal tape! Totally untested, but very clean and tidy overall. £5 + post
26th Feb 2024, 10:54 pm | #6 |
26. Lot of 100R (mostly) power resistors. Mostly new
£2 + post 27. 10x 10K 78W power resistors, New Old stock £2 + post 28. 2x RS LM317K, one new, one good pull with full leads. £2 + post 29. 3. 8x United Chemi-con 50uF 30V @ 125C, ultra reliable caps with Teflon end seals! These are the business for valve cathode bypass, etc. £4 + post ( 2 lots available) 30. 30x Mullard 22nf (0.022uf) Cermaic capacitors. Very popular handy value. Quality parts. £3 + post ** END OF ITEMS **
26th Feb 2024, 11:03 pm | #7 |
Could I have numbers 21 (tape heads), 24 (box of components) and 25 (cassettes), please?
Regards, Ben. |
26th Feb 2024, 11:33 pm | #8 |
Hi Rob.
Can I put my name down for one of the ZN1034Es (item #5) and the switches (item #18) please? Regards, Symon |
27th Feb 2024, 12:30 am | #9 |
Yes please to item 3, the grounding terminals. I have a piece of equipment with broken terminals of the same type!
Thanks, Scott
www.scottbouch.com |
27th Feb 2024, 7:24 am | #10 |
Hi Rob,
I'd be interested in numbers 4 and 11 please, thanks, Keith |
27th Feb 2024, 9:39 am | #11 |
Rob, I would like items 7 (Dremel type cutting tools) and 17 (headphone amp), will P.M.
David |
29th Feb 2024, 12:16 am | #12 |
Update, some have items sold
- The following items are still available: 1. 15x Mullard/Philips 680uf 10V 108 Series long life capacitors. Measure excellent, great quality. £4 (or 3 lots for £10) +post (6 lots available) 2. Lot of mixed heatsink washers, TO3, TO-220 TO126 etc. Handy to have when building and repairing! £2 + post 5. RS ZN1034E New old stock Precision timer/counter IC's Hard to find now! **One left** £3 each + post 6. Selection of NOS Zener diodes, very useful voltages 5V1, 5V6 12V 15V. Quality New Old stock items. (packs on left have 4 diodes each, sealed packs on right have 5 each) £3 + post 8. 100x BZX85C 7V5 1.3W Zener diodes, NOS. £3 + post (2 lots available) 9. 20x SRC 150pf silver mica caps. 200V working. New old stock £3 + post 10. 13pcs Wima 0.22uf 100V MKS2 5mm pitch polyester caps £2 + post 12. 32pcs ITT 0.1uf 100V polyester capacitors. Ex equipment. all good, fine to re-use. £3 + post 13. Mullard C280 0.022 & 0.033 caps in 'Seme' packs. (14x 0.033uf & 9x 0.022uf). £2 + post 14. 20x Philips 3300pf 160V 1% polystyrene caps. Extended foil design, the best! £3 + post 15. RS multiturn pot, 1K ohm. Very high quality, suits test gear etc. £3 + post 16. 4x 1960's Belling Lee 1.25" Fuseholders, panel mount. Used, but good, sound condition. £4 + post 19. 2x RS 6.8mH 2A Suppression chokes, new in pack. £3 + post 20. 7x New Sony 3.5" HD floppy discs, never used Reliable as far as floppies go! £3 + post 22. Aerial base for transmitter? Heavy, with a good run of RG58 cable £3 + post 23. Valve screening cans, all in good condition. B9A and B7G types £3 + post 26. Lot of 100R (mostly) power resistors. Mostly new £2 + post 27. 10x 10K 7W power resistors, New Old stock £2 + post 28. 2x RS LM317K, one new, one good pull with full leads. £2 + post 29. 3. 8x United Chemi-con 50uF 30V @ 125C, ultra reliable caps with Teflon end seals! These are the business for valve cathode bypass, etc. £4 + post ( 2 lots available) 30. 30x Mullard 22nf (0.022uf) Cermaic capacitors. Very popular handy value. Quality parts. £3 + post
29th Feb 2024, 9:00 am | #13 |
Could I have items 2, 6 and 9 please Rob?
Thanks Aub
29th Feb 2024, 2:45 pm | #14 |
Item two, the washers, could definitely use them.
Greg.
Picture, sound?, DOOR. |
29th Feb 2024, 4:13 pm | #15 |
Sorry Greg, Aub just clinched those…
I like your profile icon, having a fondness for Japan myself
29th Feb 2024, 5:12 pm | #16 | |
Greg.
2nd Mar 2024, 12:10 pm | #17 |
Item 29 for me please
Andy |
6th Mar 2024, 10:04 pm | #18 |
Items 12,13,16, 29. Please. I’ve just replied on your valve thread too.
7th Mar 2024, 10:03 am | #19 |
can I have item No. 15 pot please.
and how to I post have no paypal thank you gezza123 |
8th Mar 2024, 1:34 am | #20 |
Hi Gezza, I can't send you a PM as it says you have chosen not to receive Private messages when I try to send one....
