3rd Nov 2019, 9:57 am | #41 |
Re: How do I age stainless steel screws?
How about heat - real heat?
All the stainless fixings we use on exhaust systems very quickly discolour and change to a dark grey/brown shade. (these are A2 and A4 grade bolts) A good thrashing with a blowtorch should sort this out.
3rd Nov 2019, 12:17 pm | #42 |
Attacking the problem from a different angle - I don't recall seeing what size and style you need ? Just a thought, but maybe someone here knows where to find them in a normal steel grade, as opposed to stainless.
Alan |
3rd Nov 2019, 8:30 pm | #43 |
Ha Ha, I didn't think of that
No4. 2.9mm Dia 6mm long slotted and flat(ish) head, in mild steel. As per the picture in one of the earlier posts. Nick G0HIK |
3rd Nov 2019, 8:31 pm | #44 |
I always thought Stainless steel went a blueish colour, but I'll give one a blast tomorrow and see what happens.
Nick G0HIK |
3rd Nov 2019, 8:35 pm | #45 | |
When you buy online you dont expect the quality of the items to be great, unless you use a trusted source.
These said they were A4 Marine grade, but I've heard this before and had things rusting outside in no time. On this occasion they seem to be living up to their name. https://www.westfieldfasteners.co.uk...ess_Steel.html I did not buy from this company on this occasion, this is just for reference. Nick G0HIK Quote:
3rd Nov 2019, 8:40 pm | #46 | |
You might just be right, sometimes life is just too short, I want to get this project off the work bench.
Those shiny new screws will be annoying me though till they dull down. Nick G0HIK Quote:
3rd Nov 2019, 8:53 pm | #47 |
Plumbers flux will also discolour stainless, but I'd go for high heat as it's fast.
3rd Nov 2019, 9:32 pm | #48 |
Grit blasting
4th Nov 2019, 5:24 am | #49 |
The "A4" designation is the same as type 316, which is one of the more corrosion resistant. Looking at some websites, it appears that many fastener companies are now offering to supply electropolished parts (not at all common when I was a boy!), which makes them even more resistant.
B
4th Nov 2019, 7:31 pm | #50 |
I had two screws in Plumbers flux today, one in good old fashioned "Fluxite" and the other in the modern stuff, but showed no signs of discolouration.
This evening I've just used a blow lamp, this is certainly the quickest and best. Like anything else there is a technique, some have discoloured better than others, I dont know what the technique it yet It's also difficult putting a load in the vice as it takes the heats away, so I need to work out a way of doing several at a time. The picture shows :- Top two original middle two heat treated. bottom two as received from the supplier. Nick G0HIK |
4th Nov 2019, 7:57 pm | #51 |
Glad it worked for you
4th Nov 2019, 9:18 pm | #52 |
The discoloured ones certainly fit in better than the shiny ones!
