26th Sep 2019, 10:12 am | #61 |
Re: Your first experience with LEDs?
I think the sales boom for LED watches was more due to Kojak.
Not many could afford the Omega one! |
9th Oct 2019, 6:37 pm | #62 |
Some early tri colour leds, a cds photocell, and a couple of nice military standard panel indicators, on with an nve filter
9th Oct 2019, 6:41 pm | #63 |
I remember those DIL-packaged sets-of-LEDs - I built a battery-condition indicator for one of my cars using one of those and a chip - LM39something - that was specifically designed as a driver for such applications - there were 2 versions, one log, the other linear; the log ones were invariably used as level/drive-indicators in recording applications and transmitter modulators.
9th Oct 2019, 6:48 pm | #64 | |
9th Oct 2019, 6:51 pm | #65 |
The chinese are all over them
9th Oct 2019, 6:53 pm | #66 | |
I remember that you could even at one time buy those DIL "Bar-graph" LEDs which had the first 6 or 7 LEDs green, then a couple of orange and finally one red, specifically for use with the 3914/3915 chips. |
9th Oct 2019, 7:12 pm | #67 |
Definitely, we had test sets with lm311 comparator and resistor chains to do a similar thing
10th Oct 2019, 4:46 am | #68 |
Wasn't there also an LM3916, which was a similar bargraph driver with yet another response curve?
You could also get at one time little PCBs with the LED and LM3914 dice directly on the board and bonded out to each other. A dozen or so external connections to the LM3914 connections other than most of those for the LEDs. RS did them, I still have the datasheet. I have one used as a battery condition indicator in a piece of telecoms test equipment (Tester 301B), one of the LEDs or its connection has failed alas. It's not important (it's used in bar rather than dot mode, so the missing LED simply appears as a gap in the bar and I can still tell when the battery needs charging) but I'd like to replace it. But finding a replacement is hard, it pretty much has to be the original module to fit in the space. |
10th Oct 2019, 6:31 am | #69 |
I've seen cassette decks where one bargraph driver IC was multiplexed to drive two rows of LEDs alternately.
The design confused me at first, because there did not seem to be an oscillator controlling the switching, nor any transistors that looked good for the full current .....
10th Oct 2019, 8:31 am | #70 |
I built a power amp a good few years back using a pair of LM39** to drive a couple of bar graphs as VU meters.
Cross-linking the cathode from LED 1 to anode of LED 2 and so on, up the chain gave a wonderful fade effect, where the upper-most LED would be dim, the next one down, slightly brighter and the 1st LED nice and bright, for example. At full tilt with a hearty beat the effect was obvious, too loud and the whole bar graph would flash. Mark
Slowly turning the 'to-do', into 'ta-dah' |
11th Oct 2019, 2:49 pm | #71 | ||
24th Oct 2019, 9:41 pm | #72 |
My first LED was in a watch of which I was mightily proud as it seemed to futuristic. One point about car/bike ignition systsm is I have allways wondered why they do not use some variant of the pizeo electric ignition buttons as on gas torches or barbecues. Surely some sort of drive off the car timing belt and cam operating a pizeo button could achieve the spark with using a battery or electronics (save for the pizeo circuit) at all.
24th Oct 2019, 10:48 pm | #73 | |
For ignition in an engine, many millions of operations would be needed rather than a few thousand. |
24th Oct 2019, 11:07 pm | #74 |
Think I'm going to have to dig out the vintage LED collection, it's been while since I last looked.
27th Oct 2019, 3:10 pm | #75 |
First one was a 3mm red in the '70's sometime, from RS. It was used in a logic probe - a design from one of the magazines that used a 7400 as a flipflop to extend the pulse.
Later I got some of those claw-shaped monsanto 7-seg displays referred to earlier with the intention of making a DVM (never completed, though I may still have the display board). |
