Old 24th Jun 2019, 9:41 pm   #1
Biggles
Default Don't fall into the trap...
Just a note to share a recent experience which may save others from making the same mistake. I had a piece of speaker cloth saved from a scrap set which had been stored in the workshop for a number of years. I needed some for a home constructed set and cut it to the correct size. As it had one or two minor rucks in it I thought I would iron it on a cool setting, sandwiched between two sheets of kitchen roll. That worked and I was left with a nice smooth cloth. Unfortunately it had shrank a little and would no longer fit. Luckily I had just enough left to do the job, which I ironed first before cutting to size. I suspect the cloth had some kind of plastic weave mixed in but it wasn't obvious (to me anyway).
Alan.
Biggles is offline
Old 24th Jun 2019, 10:22 pm   #2
vidjoman
Default Re: Don't fall into the trap...
We used to tighten the speaker cloth using a hairdryer on a low setting and it caused it to shrink just enough to give a smooth unwrinkled finish.
vidjoman is offline
Old 25th Jun 2019, 6:06 pm   #3
Biggles
I was beginning to wonder if this was an intended property of the cloth, to give a nice taut finish after the cabinet was built. I don't often work with speaker cloth to be honest. I am happy to get the set working and don't usually pay much attention to cosmetic detail.
Alan.
Biggles is offline
Old 25th Jun 2019, 7:47 pm   #4
John M0GLN
John M0GLN's Avatar
When I built a speaker cabimet in the 60's with 2 WB Stentorian HF1012 speakers I used Tygan cloth and the recommended way was to gently heat shrink it taut.
John M0GLN is offline
Old 25th Jun 2019, 10:56 pm   #5
McMurdo
McMurdo's Avatar
Heatshrinking tygan - that must be the tip of the month!
PS Nothing's new!
https://www.vintage-radio.net/forum/...27&postcount=1
Kevin
McMurdo is offline
Old 26th Jun 2019, 8:11 am   #6
vidjoman
That's how we did it in the 1950's. Normally fixed Tygan with an office type of stapler (I actually had a proper staple gun) to a wooden baffle and gently heated with a hairdryer.
vidjoman is offline
Old 26th Jun 2019, 1:08 pm   #7
Yes I remember using a hairdryer to 'tauten' speaker-cloth after Evo-Stikking it to baffle-boards. You had to get the amount of heat just right or the cloth shrunk differently in different places giving a most-unpleasant appearance!
[In times-past I also often sandwiched a piece of metal mesh or chicken-wire between the baffle-board and the speaker-cloth to provide some protection to the speaker-cone - because roadies were never excatly careful where they put their feet!]
Old 11th Dec 2019, 2:25 pm   #8
rontech
That takes me back! I made a speaker pair with HF1012s. I got the heating tip for Tygan from a Gilbert Briggs ( of Wharfedale ) article
Time flies like an arrow, fruit flies like a banana
rontech is offline
