6th Mar 2023, 9:55 pm | #1 |
Amplifier for Beocord 1900 tape deck
Hello
I've got a Bang & Olufsen Beocord 1900 tape deck and so I'm looking for speakers and an amplifier to work with this and I wondered if anyone could give me some pointers of what types to look for that would work best with this. Looking to spend up to £150 for both and besides function, I'm looking for something with a similar look to the Beocord 1900 i.e. wood and/or silver. Thanks in advance for any help. |
6th Mar 2023, 11:31 pm | #2 |
Re: Amplifier for Beocord 1900 tape deck
The obvious solution is to go for a Beomaster 1900 from the same period, though these are pricey in good working condition.
https://beocentral.com/beomaster1900 |
7th Mar 2023, 1:05 am | #3 | |
7th Mar 2023, 10:09 am | #4 |
You could use any amp or receiver from the second half of the 70s that you like the look of. You should bear in mind that 70s amps tend to be less reliable than those made a few years later.
7th Mar 2023, 10:32 am | #5 |
Oh good to know I'll keep that in mind, thank you! Currently I can connect it to my old radiogram and it works well so maybe I'll hold out for a Beomaster 1900. Are there any speakers that you might recommend to use along with that?
7th Mar 2023, 10:51 am | #6 |
Again, Beovox speakers from the 70s are the obvious choice, but any good quality speakers from that era from people like Wharfedale or Goodmans would be ideal. Some vintage bass drivers are prone to rotting surrounds, so always check this before spending any money (though repair is possible).
https://beocentral.com/original-beovox https://beocentral.com/beovox-uniphase |
7th Mar 2023, 11:12 am | #7 |
I have got various amplifiers and speakers from that period, some B&O but they would cost you a lot more than £150.
PM me if you're interested. |
7th Mar 2023, 5:06 pm | #8 | |
7th Mar 2023, 8:24 pm | #9 |
7th Mar 2023, 10:43 pm | #10 |
You just take the front cover off and have a look at the condition.
8th Mar 2023, 9:30 am | #11 |
i.e. there will be gaping holes visible.
e.g. https://audioimprov.com/AudioImprov/...apeimage_1.png or https://hagensieker.com/wp-content/u.../IMG_9203.jpeg Or they'll crumble if you touch them. |
8th Mar 2023, 10:10 am | #12 | |
Choose speakers which work best with your room, its acoustics and where you want to or have to place them. They have a much larger effect on the sound than amplifiers. Then, choose an amplifier capable of driving those speakers. Some speakers really can't be driven to their capabilities by just any amplifier. The flexible surrounds to the cones of many bass and midrange drivers can go crumbly or rot over the years, as said earlier in the thread. You really need to check before buying. Also people have tis tendency to use hifi gear whenthey have a party, and they wind it up to eleven. This has the unfortunate result of burning out tweeters. Curiously, it's too-small amplifiers which are the biggest risk here. This sounds counter-intuitive but there are plenty of speakers out there with one or more tweeter units not working. So you need to listen carefully. Human hearing degrading from high level exposure, age, disease etc. the owners of these speakers may not even be aware. Tweeters can often be replaced, but rarely with the exact original type. Fitting something else may be fine, or may not suit the equalisation tricks in the crossover network. There are some excellent amplifiers out there on the second-hand market. The 1980s were a high point. There are good designs from the seventies, but you have to look a bit more carefully to find them. By the nineties things were less easy again. Cheaper amoplifiers were just that, along with a switch to designing them around commodity power output modules which can't now be replaced (Look up STK modules) B&O amplifiers mostly didn't have electronics up to the standard of their aesthetics. Amplifiers make heat, so cramming a powerful amp into a highly elegant cabinet is going to yield problems. It means that they are both likely to need repair and are not fun to work on. David
8th Mar 2023, 12:50 pm | #13 |
8th Mar 2023, 5:30 pm | #14 | ||
Thanks for this information it's really useful. I'll have to do a bit of research then. I've been more of a headphones person over the years (Audio Technica) and I've never had to buy speakers before. And with this info I'm more concerned about buying something that might break down in a few years. I'm tempted to go down the brand new route instead to save me the headache but none of the new ones have the look I go for. I found a pair of beautiful STE-MA speakers on Facebook Marketplace but I'm glad I didn't buy them because this is all very complex. In order to choose speakers for the room I'd have to learn more about acoustics etc! I want good quality but I'm far too novice to be able to pick up on any imperfections in the sound of the speakers! Thanks for this info though it's a great starting point! |
8th Mar 2023, 5:34 pm | #15 | |
8th Mar 2023, 11:53 pm | #16 |
I might be able to help, I have sent you a PM.
Chris Wood BVWS Member |
9th Mar 2023, 9:28 pm | #17 |
It would be a crime to use a Beocord 1900 with anything other than a Beomaster 1900 in my opinion!
Beovox S35 or S45 speakers would complete things perfectly. |
13th Mar 2023, 5:30 pm | #18 |
https://www.hifiengine.com/manual_li...a/ua-900.shtml
This one or a very similar in this style rumoured to have been designed by Tim de Paravicini, and be pretty decent. |
