3rd Aug 2021, 7:17 pm | #1 |
AVQ 47 Weather Radar Unit Help
Hello all!
I recently came into possession of a AVQ 47 Weather Radar Unit (links to pics below) - I imagine it was a pull from a craft many years ago, shelved and forgotten about until a recent clean out. It's of no use to me but I thought it would be fun to see if I could get it "working" - or lit up as an interesting office item. There is a connection labeled J101 - I've googled around but there doesn't appear to be a surplus of that particular connector - or old harnesses. I thought I could rig up a power supply to one and use it to at least the screen. Any thoughts on this project - or got a line of a J101 connector source? Thanks! Daffydd Last edited by Station X; 3rd Aug 2021 at 9:04 pm. Reason: Linked images converted to thumbnails. |
3rd Aug 2021, 7:23 pm | #2 |
Re: AVQ 47 Weather Radar Unit Help
I would think J101 was the designation of the connector, not a part number.
3rd Aug 2021, 7:46 pm | #3 |
Thank you, sir. You must be right as I've had no luck with that as a part number. One of our engineers mentioned that he's seen that type of connector with RF components - tho this one appears to be keyed so that may make it harder to locate.
Thanks again! |
3rd Aug 2021, 8:58 pm | #4 |
That looks like a 62GB connector, one of the favoured military jobs 38999 is the other common one.
3rd Aug 2021, 9:52 pm | #5 |
Yes, the 62GB looks spot on! Thank you!
I'd like to rig up a bit of power to light the screen. It looks like a CRT screen - might take 110v? I've seen some manuals for the unit on the net - but damn expensive for this lark. |
4th Aug 2021, 2:17 am | #6 |
That bit is only the display - usually fitted in the centre of the cockpit instrument panel. There would have been a large receiver/power supply box somewhere in the avionics bay and the scanner behind the nosecone.
Cheers - Martin ZL2MC |
4th Aug 2021, 4:46 pm | #7 |
Hey thanks, majoconz - I figured there was at least a dish or scanner somewhere.
8th Aug 2021, 11:40 am | #8 |
What I, and I think the OP would like to know, is how would one go about powering the display and emulating a target blip on the screen?
I know these are not designed to display a scanned raster like a TV. I used to think that the circular axis was done with magnets and a motor, but I remember reading it can be done none-mechanically.
-- Graham. G3ZVT |
8th Aug 2021, 12:10 pm | #9 |
Driving the 2 deflection axes with sine waves of the same amplitude in quadrature (90 degrees out of phase) will produce a circle. Changing the amplidute of them (both together) will of course change the size of the circle.
So I guess if you have relatively slow sine waves for the 2 axes and control their ampltiude with a much faster ramp you will get the rotating line display. I have a TDMS5 (Telegraph distortion measuring set) which displays a single circular trace on a CRT screen. This is generated electronically, not by rotating deflection cols. I think the manual, including the circuit is on Sam Hallas's telephone web site. |
8th Aug 2021, 1:00 pm | #10 |
The usual 'timebase' on those displays was a vertical line which appeared with the bottom end anchored at the 'pointy' part of the display and which then swept from side to side to create a fan-shaped display. The 'straight up' position of the line represented the aircraft's heading and the sides of the fan showed what weather was at different angles either side of the current heading; recreating this electronically could be a fun exercise!
The distance 'up' the line from the base indicates how far ahead the particular weather events are. |
8th Aug 2021, 1:51 pm | #11 | |
Glad to see more activity on this thread - I think getting this unit lit up, and moving, would be so cool! Thanks everyone! Daffydd |
8th Aug 2021, 7:59 pm | #12 | ||
It's then a matter of synchronising your servomotor to it and applying the returns to the "Z" axis. Are RADAR experiments allowed in appropriate amateur bands? In the 50 odd years that I have been licenced I've never been aware of any.
-- Graham. G3ZVT |
8th Aug 2021, 9:15 pm | #13 |
Only communication with other licensed amateurs is allowed. 'Broadcasting' in the literal sense of the word is specifically forbidden, so spraying RF around is not allowed
- Julian It's good here |
8th Aug 2021, 9:24 pm | #14 | |
9th Aug 2021, 2:08 am | #15 | |
FT8 is little more than secondary RADAR
-- Graham. G3ZVT |
9th Aug 2021, 5:44 am | #16 | ||
The power limit dramatically limits range, and this means the time scales are dramatically shortened, so the sweep time the CRT deflectors are built for will be out by orders of magnitude. So even the display unit is specific to high powered radar. Power levels unsafe for anyone to enter the beam near the dish. David
9th Aug 2021, 6:35 am | #17 |
I would have thought a circuit diagram of the display is the place to start. Inventing a B52 simulator to light a screen is outside the scope of the ORIGINAL question. "CAN I MAKE IT WORK", as I remember.
I "suspect" it's just the screen and associated controls, don't think it has scanning motors, OR transmitters, or transponders as may be appropriate. IMHO it's just the EHT, brightness, focus anti-stigmatism controls. The rest would be in the receiver/power supply, transmitter and radar control. That display is "most likely" DC which means JUST the display part. It would have horizontal and vertical amps, perhaps a power supply. Its almost most likely to be 400Hz or even 1Khz supply if it does contain transformers. Joe |
10th Aug 2021, 5:30 am | #18 |
Here's a quick pic of a typical medium light aircraft installation - it looks like all the gyros are in there too.... I don't think you'll need to duplicate all this Here's everything you really wanted to know...... quite interesting for nerds like us!
http://aea.net/AvionicsNews/ANArchiv...borneRadar.pdf
Cheers - Martin ZL2MC Last edited by majoconz; 10th Aug 2021 at 5:41 am. |
10th Aug 2021, 6:46 am | #19 |
I must say its nice to see someone who knows the Beechcraft King Air aircraft. The RFDS has hundreds of them. ( RFDS = Royal Flying Doctor Service ). I am still asking for a circuit diagram of the said
" Display Unit". I would think that Dodger57 also needs such an article. with respect to all, Joe |
10th Aug 2021, 3:44 pm | #20 | |
That would give the needed relatively long interval between TX pulse and RX return. Of course you need to get the display unit itself powered up and working first, if only with a 'dot' in the middle of the screen to begin with. |
