2nd Aug 2021, 7:13 pm | #1 |
Garrard 2025 skating.
Hi all.
i recently fixed up a lovely Garrard/Dansette 2025. I was playing some Nick Drake this afternoon when the LP cover fell onto the platter/tonearm, and now the arm won't seem to track without skating across the LP in one big slide. I'm not sure what to adjust or reset! It's not a matter of the type of LP or anything, something seems to be locked/tripped. Best, Mae. |
2nd Aug 2021, 10:13 pm | #2 |
Re: Garrard 2025 skating.
Almost certainly, you’ve just damaged the stylus, replacing it should cure your problem.
2nd Aug 2021, 10:15 pm | #3 |
If the arm skates across the record it sounds as if the stylus has either been knocked out of place or got damaged on the impact. Do you know what stylus is fitted? A photo would be good.
22nd Aug 2021, 6:03 pm | #4 |
apologies for delay in replying,
thank you very much! i switched stylus and that's all it was. i thought i might have tripped something in the mech, but not at all. crisis averted. best, mae |
