31st Jul 2021, 9:29 am | #1 |
AVO CT160 Valve Tester Thumbwheel settings doc
I recently bought a AVO CT160 valve tester but having watched a video on-line I see that it would have had a document that lists all the thumbwheel settings and expected parameters for all valves.
I wonder if anyone has a electronic copy they could send me. I have bought the valve date USB from service-data.com in the hope that the settings may be there but as they're not I still need to find this info. Chris |
31st Jul 2021, 9:39 am | #2 |
Re: AVO CT160 Valve Tester Thumbwheel settings doc
Your probably looking for this :
https://frank.pocnet.net/instruments...R-20150222.pdf Cheers Mike T
31st Jul 2021, 4:09 pm | #3 |
Thank you very much Mike
That's exactly it. |
1st Aug 2021, 1:21 pm | #4 |
Administrator
That manual plus three others are on the DVD-ROM and USB, in the Avo Valve Testers section.
