Old 26th Jul 2021, 5:08 pm   #1
Big Al...
Default Plessey Avionics boat-anchor.
Does anyone recognise this transceiver made by Plessey, It appears to have a solid brass chassis with fans blowing air through a central matrix for cooling purposes. It is currently waiting for me to scrap it for parts plus the brass. But can anyone tell me where it was used, surely not on board an aircraft!
Regards Big Al
ID:	238238   Click image for larger version
ID:	238239   Click image for larger version
ID:	238240   Click image for larger version
ID:	238241   Click image for larger version
Big Al... is offline
Old 26th Jul 2021, 5:27 pm   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: plessey avionics boat-anchor
Plessey Avionics & Communications is just the name of the firm, they also made ground equipment and ship based stuff. If you can read the frequency range off the synthesiser knobs it'll tell you what service it was for, the photos don't show enough.
Radio Wrangler is online now
Old 26th Jul 2021, 5:32 pm   #3
G6Tanuki
G6Tanuki's Avatar
A quick bit of Google-fu shows:
http://www.commsmuseum.co.uk/transmi..._04/1203_4.htm
and a PDF at http://www.commsmuseum.co.uk/transmi.../pdfs/1203.pdf
There's mention of a 'low magnetic signature' version - presumably for use in aircraft where they are also using magnetometers to detect the magnetic-anomaly created when a submarine or surface-vessel interacts with the Earth's magnetic-field.
That would explain the brass....
G6Tanuki is offline
Old 26th Jul 2021, 6:00 pm   #4
Big Al...
Thanks for the quick replies and info, I wondered why they would machine it out of brass rather than Aluminium. I could not make out the frequency range but include a few more photo's for you information.
ID:	238249   Click image for larger version
ID:	238250   Click image for larger version
ID:	238251   Click image for larger version
ID:	238252   Click image for larger version
Old 26th Jul 2021, 6:32 pm   #5
G6fylneil
The colour and weight suggest it's naval equipment, and navies like their ships to have a low magnetic signature, especially their submarines and minesweepers. They also need stuff to keep on working when something explodes nearby, hence the substantial mechanical construction.
G6fylneil is offline
Old 26th Jul 2021, 6:49 pm   #6
ParcGwyn
ParcGwyn's Avatar
That's a blast from the past, I used to work on these in the 1980s, used by the Navy and RAF.
Dave
GW7ONS
ParcGwyn is offline
Old 26th Jul 2021, 6:53 pm   #7
Andrew Sinclair
There is a rack of this equipment in the museum at HMS Collingwood (at least until Monday!).
i think it was used in warships for communications to other ships, and also aircraft. UHF was considered to be more secure than HF, as the groundwave range is smaller and skywave propagation is unusual.
Aircraft had much smaller and lighter radios!
Andrew Sinclair is offline
Old 26th Jul 2021, 7:02 pm   #8
Graham G3ZVT
Graham G3ZVT's Avatar
I've never seen anything rated at 264v AC before.
Will that be 50Hz, or something else?
Graham.
G3ZVT
Graham G3ZVT is online now
Old 26th Jul 2021, 7:31 pm   #9
Radio Wrangler
Expect all sorts of power arrangements. I had to redo a modular spectrum analyser so that its power supply ran from 275v DC for large US warships.
They really really want to minimise magnetic signature for anything going on a minesweeper. THe ships themselves being GRP (The tupperware navy), and the Napier Deltic engines must have been the biggest problems. They prefer brass to aluminium for seawater corrosion resistance.
The base used to be not far from here.
Old 26th Jul 2021, 8:07 pm   #10
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: Plessey Avionics boat-anchor.
Off topic (sorry).
What about HMS Collingwood & Monday please?
Jon_G4MDC is offline
Old 28th Jul 2021, 12:08 pm   #11
Andrew Sinclair
The main museum at HMS Collingwood is no longer required by the navy. I think the building it currently resides in is to become a tea room for new recruits. The collection has been catalogued over the last few weeks and is being put into storage by the National Museum of the Royal Navy. Movement of the exhibits starts on Monday. All very sad...
I think we need to be careful that this does not go off topic. I think we need a new thread to discuss the museum.
Old 28th Jul 2021, 1:23 pm   #12
HamishBoxer
HamishBoxer's Avatar
Not too far off, boats have anchors! Sorry, temptation got me.
HamishBoxer is offline
Old 28th Jul 2021, 4:04 pm   #13
Jon_G4MDC
Jon_G4MDC's Avatar
Thanks for info
Old 29th Jul 2021, 4:16 pm   #14
David Simpson
Big Al, rather than scrap a decent vintage military UHF Tranciever, perhaps(as this is, after all, a Radio Repair & Restoration Forum) you might consider flogging it to someone in the "For Sale" section - someone who sees merit in saving such sets. There is also VMARS - whose membership might reveal a keen Plessey collector. VMARS have a Forum site similar to this one.
I had a similar bit of kit - an ex RAF PTR175 which I donated to the Shackleton (WR963) restoration project at Coventry Airport.
There is also the Moravia Aircraft Museum at RAF Kinloss near Forres(now an Army base), which might welcome your set. Likewise, the RAF Montrose Museum. Then there is my Alma Mata - RAF Cosford - which houses a large Aircraft Museum.
By the way, very sad news about HMS Collingwood - - a pox on the MoD, and more pox on them for closing RAF Henlow & threatening to close the Communications Museum housed there.
Regards, David
David Simpson is online now
Old 29th Jul 2021, 7:07 pm   #15
Big Al...
Hi Dave
I have in the past donated a search receiver to Duxford, as it was used in ww2 for detecting enemy radar frequencies, was rather rare and was of significance to the museum.
The lump I have is in fact a rather small part of a very heavy rack mounted system. it is too heavy for me to lift into the car, in one piece, and no one has expressed an interest in owning it, but if anyone is interested in taking it off my hands as part of a restoration project, feel free to contact me via PM and it could be yours but be aware it is very heavy. I will give it a reprieve from its appointment with the scrap man of 7 days. So all you weightlifting naval restorers please get in touch
Alan
Old 29th Jul 2021, 7:54 pm   #16
David Simpson
Right enough Alan, the sheer size of some ex military stuff puts a lot of V/R folk off. 1154/55, its successor - STR18, AR88's & so on.
Maybe an ex Navy "Tiffy" will read this thread & be hit by nostalgia, and take your equipment off your hands.
For a while I was enamoured with big lumps of ex marine AM R/T's (Sailor, Woodsons, etc.), but my arms & my shelving complained too much, so have downsized now that I'm past 3 score years & ten.
Regards, David
