10th Jun 2021, 2:36 pm | #1 |
Select model 8208 no output
Hi I have got hold of a old 8 track player with no sound output on opening it up there were 4 transistors in a bag inside.
My problem is I don't know what way they go in the board. The transistors in the bag were cracked. I have replacements just need help as there are 12 holes . Any help or if anyone has service manual for this it would be very helpful. Barry |
10th Jun 2021, 2:42 pm | #2 |
Re: Select model 8208 no output
A picture of the old transistors.
10th Jun 2021, 4:12 pm | #3 |
Barry I tried to find info back in December without success.
https://www.google.com/url?client=in...xybwaMYkRFvVhl David |
10th Jun 2021, 7:28 pm | #4 |
It's my fault for removing them and not taking any pictures of them in the board.
10th Jun 2021, 7:32 pm | #5 |
Do you still have it if so are the transistors in place on the amp board.
10th Jun 2021, 10:05 pm | #6 |
At the time I was looking at buying it but never did.
No help but pretty sure those transistors will be 2SA509 & 2SC509. Are there any identification markings around the 12 holes ? Seems strange they have got cracked in that way, maybe thermal or voltage stressed ? A real shame you did not photo them before removal, would have made replacement hugely easier. David |
11th Jun 2021, 8:44 am | #7 |
Hi there are no marks on the board what so ever.
So maybe one day I'll pick another one up for spares. |
11th Jun 2021, 10:37 am | #8 |
Reverse engineer for a skeleton schematic around where the transistors fit, you should then be able to figure out which is EBC.
Lawrence. |
11th Jun 2021, 10:53 am | #9 |
I've also noticed that it was made by Senn- Sound with the same model number 8208
11th Jun 2021, 1:58 pm | #10 |
I was wondering if it was a clone/rebadge of a more well known make that may have a schematic available but like Select, Senn-Sound is not really known to me.
David |
11th Jun 2021, 2:15 pm | #11 |
Senn Sound looks like a Swiss company under Auto-Senn AG.
No obvious sign of any documentation. David |
11th Jun 2021, 2:35 pm | #12 |
I was assuming that it is a desk model for home use rather than a car model.
Just wondering because if it is a car player, then because of its age it possibly could be +ve earth. If so then if tried on a modern car with -ve earth it would not work and possibly could get damaged ? David |
12th Jun 2021, 9:43 am | #13 |
Hi David it's a home model sorry for not making that clear at the start.
13th Jun 2021, 7:59 am | #14 |
Are there any other transistors on the board or just these 4, some basic players may only have 2 transistors per channel.
These transistors appear to be a PNP/NPN complementary pair which to me is unusual in a basic player amp, when used typically would be in an output stage driving a speaker, (although these particular transistors are not really power output type) in that case there would be other transistors. Does this player have internal speakers ? A photo of the player and its PCB would be interesting to see. David |
13th Jun 2021, 8:10 am | #15 | |
Lawrence's suggestion of reverse engineering a schematic is only practical way forward if you have the technical ability to do it. David |
