31st Jul 2021, 9:38 am | #21 |
Re: What is ripple current?
I've just done a straw poll of large can electrolytics on Farnell. And all of them have data for 120Hz and 10kHz.
120Hz because most of them are from the US; Epcos, Vishay, Kemet etc Craig |
31st Jul 2021, 2:00 pm | #22 |
If the capacitor is used to couple the speaker to a single rail transistor amplifier all of the current delivered to the speaker is ripple current no matter what.
The frequency is the full audio range too. This application has been about for many years and we have not had too many fail. |
1st Aug 2021, 1:00 pm | #23 | |
Lawrence. |
1st Aug 2021, 5:13 pm | #24 |
I'd have generally said that a higher value cap will have a higher ripple current rating (assuming the case size is the same) - it's the voltage rating which will fall. Higher capacitance implies bigger electrode surface area, thinner electrodeposited oxide film, both of which will give rise to lower ESR. And it's ESR which determines the ripple current rating.
