17th Sep 2020, 3:57 pm | #1 |
JVC 3060UK Tape deck running slow, how can I increase the speed?
Hi all, I am having some issues with my tape deck. I don't know how to identify it but images are attached. I am assuming it was made in 1967 because that's what it says on the motor, it looks likes all made of heat treated steel. The motor is quite substantial but I don't see any adjustments on it for the mechanical governor. I don't think any of the pot's inside change the speed. I have attached a picture of the motor, do I have to take it apart for the speed adjustment? I am not aiming for accuracy, I have a prerecorded tape and I am going to compare it to the same song on YouTube. I have a feeling that the screw located on the aluminium base of the motor would be it but I don't want to just go ahead and turn it in case it's holding something important together.
TLDR: The motor is running slow, I want to know how to adjust the governor of the motor. I have suspicions that the screw on the side of the base "cap" is it. Can anyone confirm/correct me? Thanks -Nathan |
17th Sep 2020, 4:58 pm | #2 |
Re: JVC 3060UK Tape deck running slow, how can I increase the speed?
Usually through the covered small hole on the motor, thats just a membrane type seal for dust etc, a small jewellers screwdriver will do, I tend to wrap some heatshrink or insulation tape on the screwdriver blade so it doesn’t short out on the motor casing.
Alan Last edited by stacman; 17th Sep 2020 at 4:58 pm. Reason: Extra information |
17th Sep 2020, 8:28 pm | #3 |
You can adjust it but normally it doesn't go out. More likely slow speed is from some mechanical issue such as a binding bearing.
17th Sep 2020, 9:03 pm | #4 |
When was the belt last changed? In my younger days I spent ages messing around with the speed controls on cassette motors until I realised that the belts stretching was the real problem.
22nd Sep 2020, 12:42 am | #5 |
If it's running slow, the belt may be too tight, in which case you'll damage the bearings if you continue to use it like that.
22nd Sep 2020, 1:11 am | #6 |
That date is 1976. As said check belt is not too slack. Looks okay but who knows? A slight tweak of the pot may be all that's needed.
Regards, Ben. |
