9th Sep 2020, 9:14 pm | #1 |
R1155 Resistor wattage?
Whilst I have a list of R values required to replace many of the resisters in an old R1155 ( which all seem to be miles out) I cannot find any data to tell me the wattage required...and I find it hard to calculate as some power supplies seem to be at 270v Ht+ to Ht- whilst others seem to be much lower .... .If I take the screen grids for instance...they say they should be approx 60-80 volts.... mine are nearer to 110 V ....and the screen resister network works out that I need resisters of over 1 watt.....ie.. 240 volt Ht to earth , 23K and 27K in series for screen voltage .
Is there a rule of thumb for wattage for all the resisters ( other than R1) or is there a list some where.... |
9th Sep 2020, 9:32 pm | #2 |
Re: R1155 Resistor wattage?
Are you replacing them with modern resistors? If so, just use 2 watt or greater types as they will then also be physically large enough to look 'at home'.
Andy |
9th Sep 2020, 11:33 pm | #3 |
Yes ... Modern metal film I guess..... so 2 watt will be good for all...thanks
10th Sep 2020, 8:51 am | #4 |
Worth doing in any case - the disspation in resistors fitted to valve equipment can be surprisingly high. It is easy to forget this after working extensively on low-voltage, low current semiconductor stuff!
10th Sep 2020, 9:08 am | #5 |
Quote OP : .and I find it hard to calculate as some power supplies seem to be at 270v Ht+ to Ht- whilst others seem to be much lower ....
I thought the R1155 was around 210V ht? Rob
10th Sep 2020, 10:18 am | #6 |
Think you are right ,around 210V.
