Old 7th Sep 2020, 11:54 am   #1
Michael Maurice
Michael Maurice's Avatar
Default Tandberg TD20
I've been asked to look at a Tandberg TD20 which at some stage was modified for 110V 60Hz
The owner wants it converted back to 240V 50HZ.
I presume the motor pulley will need changing unless of course it has two steps, one for 50Hz one for 60Hz.
Does anyone know if that's the case or do I have to get a new pulley?
Forum Moderator
Michael Maurice is offline
Old 7th Sep 2020, 2:13 pm   #2
ms660
ms660's Avatar
Default Re: Tandberg TD20
So far as I can make out from looking at various pictures I would say that the capstan motor pulley needs to be changed, and if the original conversion was done properly the mains VDR along with all the motor capacitors and depending on the PROM IC colour code the three feed resistors for the supply and take up motors (two for the DC supplies to the supply and take up motors and the one for the AC supply to the take up motor when in playback/record mode)
Lawrence.
ms660 is offline
Old 7th Sep 2020, 2:24 pm   #3
unitelex
Hi Maurice,
Assume it is the 20A ?
I believe it has a tapping on the transformer to select 115/230V
While this user guide says refer to qualified technician for voltage configuration, it does state in the specification at the end of the document both 115, 230V
http://sportsbil.com/tandberg/td-20a-om-english.pdf
The schematic shows the transformer has two primary windings in series, so I would assume this is the means for 115/230 configuration
http://sportsbil.com/tandberg/td-20a-se-circ-align.PDF
All three motors seem to be fed from the secondary of the transformer through speed regulators/switches etc
So seems to be just the changes to the transformer tapping
Best Regards
Chris
unitelex is offline
Old 7th Sep 2020, 2:33 pm   #4
unitelex
There is a table of resistor/cap changes on the schematic (Table 2)
This shows different values for 115/230
Assume this motor is regulated by AC frequency so it will need a pulley change.
There is also a varistor to change on the AC input.
Best Regards
Chris
unitelex is offline
Old 7th Sep 2020, 2:55 pm   #5
Michael Maurice
Thanks everyone
I wonder where i can get a pulley from? I doubt the owner would have it.
Forum Moderator
Old 7th Sep 2020, 10:37 pm   #6
unitelex
If you can measure the motor shaft diameter and also the diameter of the portion where the belt runs then there must be somebody on the forum who has a lathe and some aluminium bar who could make one for you (with 20% increase on the diameter).
Best Regards
Chris
unitelex is offline
Old 13th Sep 2020, 6:19 pm   #7
Paulus.d
Would the pulley be the same on the series12 or 15?
Regards Paul
Paulus.d is offline
Old 13th Sep 2020, 10:50 pm   #8
Michael Maurice
No.
The owner has decided not to go ahead with the conversion.
Forum Moderator
