Old 1st Sep 2020, 4:26 pm   #1
buggies
buggies's Avatar
Default Specification or manual for Solartron CR561 75 Ohm attenuator (1950s)
Had this attenuator for decades and thought it was time to test it before passing it on.
I suspect it is only usable at audio frequencies.
The diecast alloy box has .1" thick walls and the thing weighs over 2lb.
Note the tin whiskers on two of the screening plates.
The resistors are all Painton type 93 - would also appreciate any spec on them.
ID:	214719   Click image for larger version
ID:	214720   Click image for larger version
George
buggies is offline
Old 1st Sep 2020, 7:31 pm   #2
mark_in_manc
Default Re: Specification or manual for Solartron CR561 75 Ohm attenuator (1950s)
I have three of those which look just the same, but they are labelled 'Attenuator 600 ohms AT201'. Mine have coax sockets in and out. Given where they came from, mine were used for AF work. More than 30 years ago.
mark_in_manc is offline
Old 9th Sep 2020, 4:51 pm   #3
buggies
buggies's Avatar
I have now located a manual for the attenuator(s) - photographed the four pages and attached for anyone else.
My model uses type Painton 93 resistors not type 73 in the parts list - no idea what the difference is so will ask in another post.
Incidentally the manual was located in a box in the loft...
George
buggies is offline
Old 9th Sep 2020, 5:32 pm   #4
AC/HL
AC/HL's Avatar
Thread moved to Vintage Test Gear for archive.
AC/HL is offline
Old 16th Sep 2020, 9:27 am   #5
WME_bill
for buggies: AT201 - CR561 specification from 1960 attached. Thanks for posting manual. wme_bill
File Type: pdf AT201-CR561 attenuator -specification 1960.pdf (579.0 KB, 59 views)
WME_bill is offline
Old 16th Sep 2020, 6:53 pm   #6
buggies
buggies's Avatar
Thanks for that Bill.
The only catalogue I kept was the '73-'74 hardback (olive green) one which included too much other Schlumberger stuff for my liking.
George
buggies is offline
