Old 24th Jul 2020, 2:18 pm   #1
ChinTong
Default Revox F36 main motor not spinning
My F36 main(play) motor stop spinning. All other functions work well. Appreciate help.
ChinTong is offline
Old 24th Jul 2020, 9:37 pm   #2
DMcMahon
DMcMahon's Avatar
Default Re: Revox F36 main motor not spinning
So just to be clear, capstan motor is not working so no drive in Play mode, but Fast wind in both directions is working OK from the reel motors ?
DMcMahon is offline
Old 24th Jul 2020, 9:56 pm   #3
ChinTong
Yes. It’s correct. Was working the day before. Motor spins smoothly when rotate by hand. Appears power supply problem.
ChinTong is offline
Old 25th Jul 2020, 12:01 am   #4
DMcMahon
DMcMahon's Avatar
Same problem in both tape speeds ?
DMcMahon is offline
Old 25th Jul 2020, 5:09 am   #5
ChinTong
Default
Yes
Also noted the rewind motor behave strangely. At times, it spins on play mode, and the spinning can be stopped by fingers. Rewinding is perfect. Just service the brakes!
ChinTong is offline
Old 25th Jul 2020, 6:14 am   #6
barrymagrec
Could be the motor cap.
barrymagrec is offline
Old 25th Jul 2020, 7:48 am   #7
ChinTong
Thanks
Is this capacitor suitable?
ChinTong is offline
Old 25th Jul 2020, 8:25 am   #8
barrymagrec
Probably, if 2uf is the correct value, but it`s easy enough to check for volts on the motor before making random component changes.
Old 25th Jul 2020, 5:32 pm   #9
Michael Maurice
Michael Maurice's Avatar
A voltage check may not give much information, unless you get near zero volts, because the capacitor is there to shift the phase of the mains by 90 degrees.
The supply motor will spin in play with low torque as that’s how back tension is effected.
Forum Moderator
Michael Maurice is offline
Old 25th Jul 2020, 7:55 pm   #10
DMcMahon
DMcMahon's Avatar
Originally Posted by ChinTong View Post
Thanks
Often not the Motor Run capacitor but only way to be 100% sure would be to change it.
2uF is correct according to schematic (double check the stated value of old part), this MRA PRO440 series seems to be suitable for Motor Run applications, not sure why the double contacts.
DMcMahon is offline
Old 29th Aug 2020, 11:48 am   #11
ChinTong
Default
Thanks for the inputs. I changed all the 3 capacitors. When I switch to play mode on first try, it turns😄. But on subsequent tries, it’s dead!
Anyone know the value of the resistor on a small fiber board attached to the solenoid
ChinTong is offline
Old 30th Aug 2020, 12:28 am   #12
Michael Maurice
The motor should run as soon as the machine is switched on.
You've replaced the motor run capacitor, the only other thing is the speed change switch. unless the motor itself is faulty.
Forum Moderator
Old 30th Aug 2020, 8:28 am   #13
ChinTong
Thank you Michael, check and service the speed switch, now the 71/2 speed works but not the 3 3/4!
ChinTong is offline
Old 30th Aug 2020, 8:43 am   #14
ChinTong
Found another problem, the rewind motor runs on play mode! Causing tape not running
ChinTong is offline
Old 30th Aug 2020, 9:19 am   #15
Ted Kendall
It should do, but at reduced power, to provide back tension. Is your pinch roller OK? If it's hard it won't grip well, and bear in mind that capstan wear is not uncommon on these machines.
Ted Kendall is offline
Old 30th Aug 2020, 1:30 pm   #16
ChinTong
Adjusted the brake tension and the machine works on 7 1/2 speed only. Still failed to get 3 3/4 speed to work. The sound quality is good considering the age of this machine. Has to replace the pinch roller.
ChinTong is offline
Old 30th Aug 2020, 7:20 pm   #17
Michael Maurice
There are 3 positions on the tape speed selector 7½, OFF 3¾ check that the 3¾ button is frully pushed down, otherwise check for broken wires and faulty switch tags.
Forum Moderator
Old 31st Aug 2020, 1:33 am   #18
ChinTong
Thank you Michael, will certainly follow your advice and update
ChinTong is offline
Old 3rd Sep 2020, 12:02 pm   #19
ChinTong
It works but stop working again after a few reels. Now the pinch roller solenoid not working. The tape end detection and brake solenoids are working fine. Appreciate help. Thank you in advance
ChinTong is offline
Old 3rd Sep 2020, 1:15 pm   #20
Ted Kendall
The shunting diodes across the solenoids and on the switchpack can give trouble with intermittent operation.
