Old 9th Sep 2020, 9:14 pm   #1
yakxx21
Default R1155 Resistor wattage?
Whilst I have a list of R values required to replace many of the resisters in an old R1155 ( which all seem to be miles out) I cannot find any data to tell me the wattage required...and I find it hard to calculate as some power supplies seem to be at 270v Ht+ to Ht- whilst others seem to be much lower .... .If I take the screen grids for instance...they say they should be approx 60-80 volts.... mine are nearer to 110 V ....and the screen resister network works out that I need resisters of over 1 watt.....ie.. 240 volt Ht to earth , 23K and 27K in series for screen voltage .
Is there a rule of thumb for wattage for all the resisters ( other than R1) or is there a list some where....
yakxx21 is offline
Old 9th Sep 2020, 9:32 pm   #2
M0FYA Andy
Default Re: R1155 Resistor wattage?
Are you replacing them with modern resistors? If so, just use 2 watt or greater types as they will then also be physically large enough to look 'at home'.
Andy
M0FYA Andy is offline
Old 9th Sep 2020, 11:33 pm   #3
yakxx21
Yes ... Modern metal film I guess..... so 2 watt will be good for all...thanks
yakxx21 is offline
Old 10th Sep 2020, 8:51 am   #4
lesmw0sec
Andy
Worth doing in any case - the disspation in resistors fitted to valve equipment can be surprisingly high. It is easy to forget this after working extensively on low-voltage, low current semiconductor stuff!
lesmw0sec is online now
Old 10th Sep 2020, 9:08 am   #5
CambridgeWorks
CambridgeWorks's Avatar
Quote OP : .and I find it hard to calculate as some power supplies seem to be at 270v Ht+ to Ht- whilst others seem to be much lower ....
I thought the R1155 was around 210V ht?
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is online now
Old 10th Sep 2020, 10:18 am   #6
HamishBoxer
HamishBoxer's Avatar
Think you are right ,around 210V.
HamishBoxer is offline
