4th Mar 2024, 6:52 pm | #1 |
Bell Set 64D connection to hub?
Hello, can anyone help with what connections I need to connect the bells to the BT hub, I've removed the centre link in an attempt to get them to ring. Do I need to add a 3k3 resistor anywhere as with other bells? I've attached a pic of the bells. Tia.
4th Mar 2024, 7:46 pm | #2 |
Re: Bell Set 64D connection to hub?
Without the centre link, they will be open-circuit. If you feel the need for a resistor, you can place it instead of the link. You will, however, need a 1.8µF (or thereabouts) in series with the bell coils, either by placing it within the bell enclosure and connecting the combination across the A and B legs of the line, or if using an external capacitor such as in an ADSL filter, between the A leg and the ring wire.
edit: I should add that the above assumes your hub has a telephone socket.
4th Mar 2024, 8:14 pm | #3 |
Thanks so much Dave, extremely helpful. I'll get onto this soon.
4th Mar 2024, 10:05 pm | #4 |
By the way, the forum appears to have changed my mu (in microfarad) to a question mark.
4th Mar 2024, 10:19 pm | #5 |
Alt+230'd
5th Mar 2024, 9:10 am | #6 |
Thanks for that. I'm just puzzled why my "µ" (from character map) didn't remain as one. I'll use the ALT+number approach in future!
5th Mar 2024, 10:38 am | #7 |
I initially tried pasting one in from elsewhere, but it appeared as a question mark.
Back on topic please. there's a thread some where about how to type µ etc.
5th Mar 2024, 7:43 pm | #8 |
British Telecom used a master socket, and 3 wires in the house, one common, one line, and one ringer-line trough a 1.8 uF capacitor.
All the ringers were without capacitor. If one ringer had to high load compaired with the others it did "steal" too much of the energy. That might be compensated with series resistors (or capacitors). It is actually no easy way to calculate the right values, but 3k3 resistors are often used with an OK result. |
