3rd Mar 2018, 10:30 am | #1 |
Valve has gone to air, 'my vacuum has escaped!'
Hi folks,
I'd been cheerfully using a set over the Christmas period & up until recent days with no issues at all, she's been great. Yesterday, I fired her & she lit up as usual but not a peep to be heard, not even the usual gentle hum from the speaker. Removing the back revealed the original Mullard UL84 has a white top with a 'V' crack emerging from one of the heater pins. Gadzooks the vacuum has escaped! (As a colleague once amusingly exclaimed). Has anyone else had this? This is my first true valve failure, normally I see low emission or poor valve to valve base contact, but this took me by surprise. I can only imagine the indifferent materials (valve pin vs glass envelope) change temperature at different rates, add some fatigue into the mix & she's a gonna! The room is a stable/sensible temperature, around 68 degrees. Would welcome anyone's thoughts on this. Many thanks, Mark |
3rd Mar 2018, 10:37 am | #2 |
Re: Valve has gone to air, 'my vacuum has escaped!'
I cannot spell the word correctly but, conduedual flaw comes to mind. It does happen to glass and the defect has been there a while or some stress in the past.
3rd Mar 2018, 10:37 am | #3 |
I've had various glass-base valves develop those sorts of cracks: one thing to check is that the contacts in the valve-base are clean and tight. If there's corrosion or poor contact causing a significant resistance on the heater-pins in particular, you can get a significant amount of the 'heat' being delivered to the heater-pin rather than the heater, which over time doesn't do the metal-to-glass seal much good.
3rd Mar 2018, 10:50 am | #4 |
Somewhere in the distant past, at Technical Collage we were told that the valve pins were made of a type of metal which had the same heat coefficient as the glass. Mick.
3rd Mar 2018, 10:52 am | #5 |
If the vacuum had escaped from the valve it would be in the cabinet.
It has simply ceased to be, it is an ex vacuum. I have had a few B9A valves do this but mostly rimlocks I suspect because the glass is thicker and hence the pins create more stress. |
3rd Mar 2018, 10:55 am | #6 |
There was a thread here some time ago about valves doing this while in storage. I don't remember whether any firm conclusion was reached about the cause(s).
3rd Mar 2018, 11:31 am | #7 |
Make sure you don't breathe in the escaped vacuum, it'll do you no good at all.
3rd Mar 2018, 11:34 am | #8 |
It happens, but surprisingly not very often, at least it was a UL84, easily obtainable for now.
Frank |
3rd Mar 2018, 12:00 pm | #9 |
Many thanks for the replys thus far chaps, seems a combination of conditions could cause this, I can also see how a poor valve base contact would increase the amount of heat on the pin, particularly for the heater as it'll be consuming a bit of current.
We still humour our fellow colleague about 'vacuum escaping'. Could the same be said of some transistors, they only fail when the compressed smoke escapes! I shall hunt around for a replacement valve, in the meantime, & having re-strung my daughters guitar, the old guitar strings prove very useful passing through valve sockets & removing the tarnish, they come up lovely. Just make sure any residual HT decays first! Mark |
3rd Mar 2018, 12:03 pm | #10 |
Back in my distant youth, I had a Bush TV43 14" B&W telly. Of all the valve holders within, only one was ceramic. It held the ECL80 frame osc/output, and I must have gone through at least four as they used to crack across the base at odd times. I'd switch it on from cold, and be greeted with a white line! Cheers, Pete.
3rd Mar 2018, 12:17 pm | #11 |
Langrex have 72 in stock.
https://www.langrex.co.uk
Frank |
3rd Mar 2018, 12:41 pm | #12 |
They do very occasionally fail like this. The cold temperatures and low humidity over the last week may have been a factor.
3rd Mar 2018, 1:20 pm | #13 |
Shouldn't that be magic smoke? Though I guess that given the amount that comes out it's probably well compressed to get it in during manufacture.....
3rd Mar 2018, 1:54 pm | #14 |
You can get replacement "magic smoke" although this is car smoke which may be different to transistor smoke.
http://www3.telus.net/bc_triumph_registry/smoke.htm Keith |
3rd Mar 2018, 1:57 pm | #15 |
Your vacuum has escaped?
Vacuum hunters will be converging on Royal Berkshire once they know there is some on the loose. They are easily recognised by their weaponry, a blunderbuss end attached to a solder-sucker barrel. They'll catch it before the public is endangered. David
3rd Mar 2018, 4:22 pm | #16 |
During my servicing days it was quite common to find a value had gone “soft”.
We never looked for a reason, just replaced valve, tested set (Radio or TV) and away on next call. Cheers John |
3rd Mar 2018, 4:33 pm | #17 |
It gives pause for thought that a once-common and relatively inexpensive technology is usually able to retain a hard vacuum so reliably.
3rd Mar 2018, 4:33 pm | #18 |
I've had a couple of valves spontaneously go to air, with a crack starting at a pin. Really upsetting when this happens. It's always been button bases, I have never had this problem with a pinch seal.
3rd Mar 2018, 6:08 pm | #19 |
I've always suspected stress cracks started when someone wiggles them trying to get them out. If so it can take years to show up.
3rd Mar 2018, 6:40 pm | #20 | |
"What a depressingly stupid machine." [Marvin: HHGTTG] |
