26th Feb 2018, 4:14 pm | #41 |
Re: Repair vs Replace; Wasted Resources
I'm not sure that labour is a finite resource, it's a renewable surely?
Steve.
26th Feb 2018, 4:18 pm | #42 |
I consider labour very finite, specially when it's mine! We only get the one life, and it's a shame to spend it all working.
26th Feb 2018, 4:28 pm | #43 |
Of course I mean world wide and over the span of humanity's existence. When viewed like that then labour is a renewable i.e. there is a renewable supply of human beings in a way that there is not (for example) a renewable supply of tantalum or other definitely finite resources.
Steve.
26th Feb 2018, 4:55 pm | #44 |
For me it's about the value to some extent you can get from the repaired item - chainsaws chains can be easily sharpened by non specialists such as myself for 4-5 times but once you have to reduce the lands I tend to replace. For many years I saved all the 'usefull' offcuts of small bits of wood for wedges, blocks etc until I realised they were the reason I could not move in my shed - so I dumped 80% and have not missed them to date. I got great pleasure out of fixing a Weston 1940's multimeter despite the fact a modern digital one would have cost under 5 pounds and been far more accurate. On the other hand I cannot be bothered with defunct toasters etc and they go asap. What really narks though is knowing you have the replacement item/bit stored away and simply cannot find it - of course the moment you throw the item requiring repair out it's bound to appear!
26th Feb 2018, 5:32 pm | #45 |
If I were stuck with a throwaway toaster I expect I'd throw it away if it failed, rather than embark on trying to repair something that wasn't designed with repair in mind. Fortunately there are still alternatives, and if the Rowlett Regent in the kitchen should need a new element or timer I'll not grudge it the little time required to restore full operation.
26th Feb 2018, 5:44 pm | #46 | |
26th Feb 2018, 5:44 pm | #47 | |
Stay safe. Lawrence. |
26th Feb 2018, 6:04 pm | #48 |
It has been said of me "oh he will like that, it's broken, something to fix". In these days of fleeting instant gratification I find an evening (time scales are variable) of repairing something much better. It is not financially viable taken simply as hours v.s. outcome, what does an evening out cost these days? Saturday cost nigh on £200 for a bit of afternoon pub with friends and (a glorious) dinner later, celebrating our 26th anniversary.
Doing a jigsaw is a total waste (of money) so is repairing a £2 bit of kit over an hour or so, it's all fun. |
26th Feb 2018, 7:31 pm | #49 |
Just to answer a couple of similar queries on this point: the timber in the skip that I referred to wasn't the old stuff out of the building being redeveloped, it was the off-cuts (many feet long in most cases) from the new timber being used to rebuild the roof. I asked again today, a different chap on site, and have come home with plenty of kiln-dried pressure-treated 6"x2", more than enough for all the required noggins.
The cement mixer that I inherited from my father, and was third- or fourth-hand when he had it, finally gave up the ghost today, the bearing shot to hell. The motor, gearing and pulley have been saved for future use; and the rear section of the bucket has been salvaged to make into a fire-pit. All good. Regards, Richard Last edited by YoungManGW; 26th Feb 2018 at 7:47 pm. |
27th Feb 2018, 12:36 am | #50 |
Result!
27th Feb 2018, 12:44 am | #51 |
Excellent Richard. I think you were unlucky to encounter a knob the first time but not one even of any use on a piece of vintage equipment!
27th Feb 2018, 1:44 am | #52 | |
27th Feb 2018, 2:22 am | #53 | |
No Longer a Member
27th Feb 2018, 9:17 am | #54 | ||
27th Feb 2018, 9:19 am | #55 |
Re post 23.
A fridge will be ok at 45F but modern fridge freezers with a single thermostat will not work at that temperature, min temp for most is 10C/50F, some are 15C. The fridge will be OK but the freezer will defrost.
Frank |
27th Feb 2018, 10:14 am | #56 |
My almost 10 years old Fridgemaster Fridge-Freezer of neccesity is opposite the south-east facing window in my small kitchenette, and has never suffered from the defrosting problem. However it has two seperate thermostats, which no doubt explains why.
27th Feb 2018, 10:25 am | #57 |
All the resources like tantalum, samarium, cobalt, copper still exist. It's just that mankind has mixed them up with all sorts of stuff and scattered them around, increasing their entropy and making them uneconomic to recover.
I expect that in the future, as supplies in handily mined concentrations get harder to find, old landfill sites will get re-processed. I also suspect that the large jail population could be seen as a labour pool for dismantling, separating and recycling junk. Weight and purity counting to reduced sentences. David
27th Feb 2018, 10:36 am | #58 | |
I agree this isn't the biggest problem facing the technology though ! VB
http://www.ampregen.com |
27th Feb 2018, 2:02 pm | #59 |
My thanks to Lawrence for his info about the lines on chainsaw chains - never realised they had guidelines on them!! Had the files but usually a couple of teeth go awol by the 5 or 6th sharpening so simply not bothered.
As for toasters, I was referring to the el cheapos - you have problems getting parts here in NZ for quality ones and although the law says the retailers must import a stock of spares, it's honoured more in the breach than the observance. |
27th Feb 2018, 3:35 pm | #60 |
Some of you will have noticed that one company makes the majority of kettle thermostats for the UK market. Replacements (presumably cloned pattern parts) can sometimes be found online, but if you approach the manufacturer direct they will politely tell you that they only deal with companies. A contrast with the supply of conventional capillary based 'stats for refrigerators, which are easily found.
When toasters start misbehaving i usually chuck 'em- though this could be a prejudice based on an offending toaster from my childhood which was caught moonlighting as a 240 volt mouse-o-cutor. |
