Old 9th Feb 2018, 2:24 pm   #1
jimpezz61
Default Help to identify test equipment.
Hi been given this unkown Cambridge Instruments model R test Eqiument .Could any one tell me what its use was please? made in the USA runs on 110 volts. regards Jim.
Name:	Picture e bay 4949.jpg
ID:	157078   Click image for larger version
Name:	Picture e bay 4947.jpg
ID:	157079   Click image for larger version
Name:	Picture e bay 4948.jpg
ID:	157080   Click image for larger version
Name:	Picture e bay 4950.jpg
jimpezz61 is offline
Old 9th Feb 2018, 2:28 pm   #2
Refugee
Refugee's Avatar
Default Re: Help to identify test eqiupment
It looks like a bridge with a standard cell. A posh volt meter tester from old times.
Refugee is offline
Old 9th Feb 2018, 2:58 pm   #3
G6Tanuki
G6Tanuki's Avatar
The Plexiglass bit with a motor on it looks like it's part of some sort of sampling setup: it doesn't look like it was part of the original instrument.
Could it be some sort of pH-measuring device?
G6Tanuki is offline
Old 9th Feb 2018, 3:08 pm   #4
Goldie99
Default Re: Help to identify test equipment.
I'm inclined to agree - https://pubs.acs.org/doi/abs/10.1021...nalCode=ancham
Goldie99 is offline
Old 9th Feb 2018, 3:14 pm   #5
ms660
ms660's Avatar
Me too, R = "Research Model"?:
https://books.google.co.uk/books?id=...2ph%22&f=false
Lawrence.
ms660 is offline
Old 9th Feb 2018, 6:02 pm   #6
jimpezz61
Thank you very much people, the model in Goldie99 link bullentin 911, is the same model. The plexiglass and motor are add ons. Thanks again regards, Jim.
Old 9th Feb 2018, 6:19 pm   #7
TonyDuell
The 'buffer solution' would generally refer to something of a known pH (acidity/alkalinity) an would be used to calibrate a pH meter. So I think G6Tanuki's suggestion is correct.
TonyDuell is offline
