4th Mar 2021, 5:00 pm | #2181 | ||
Re: The Audiophoolery Thread.
Maybe the VU meter distortion (generally increasing at high frequencies) adds that 'certain something' for the ears of the audiophool. Martin Martin
BVWS Member |
4th Mar 2021, 6:43 pm | #2182 | |
The irony is that, if you have the knowledge to make a decent mixer (i.e. understanding of ground current flows and PCB / signal routing to get decent crosstalk and fader cut), then by default you should know how to isolate the ground currents from the meter circuitry to the point where they are virtually impossible to see, even with modern analysers. Having 'invisible' meters takes mutliple strategies (just running a dedicated return alone to the PSU won't do it), but anyone who considers themselves a designer ought to know how. Isn't it odd that people are still marketing products today that have the same fault that you identified in the 70s? |
4th Mar 2021, 6:49 pm | #2183 | |
4th Mar 2021, 7:06 pm | #2184 | ||
4th Mar 2021, 11:16 pm | #2185 |
Seen a website where a guy is selling a power cable for $1500 to power Hi-Fi sound equipment.
He swears and reckons that it sounds better. H'mmmm Doe's batteries, mains, wind generated, or solar panels electric sound different? Confused. Dave? what have you done to us all ? The question needs addressed. OK, I have a thing called perfect pitch, but A=440 anoys me, for me, its a wee bit lower and a nicer resonance at about 436-438. out of concert tune I know. Tritone or dissonant collisions are stuff that we can all hear, but I cannot hear in my ears the difference of power sources supplying my equipment. OK, Now, I can hear differences between class A, AB, G, and D, but not how they are powerd up with different sources of our friend, called electricity. Last edited by tritone; 4th Mar 2021 at 11:40 pm. Reason: tweak |
5th Mar 2021, 1:08 am | #2186 | |
So although they were beautifully built, their ability to survive switch on was touch and go. Craig |
5th Mar 2021, 4:21 am | #2187 |
An expensive conflagration.
Class-A amps ought to be pussycats, they avoid a number of nasties of devices that get cut off. I'd rather use maths and engineering to design an amplifier any day over fashion and religion, but it's fashion and religion that sell the big bucks stuff. One thing I do in my power amps is not to let the forwards gain go uncontrolled-high towards DC. There is a load resistor and compensation capacitor where there is usually just the capacitor. Most people looking at the diagram think it's unnecessary, some say the amp would perform better at low frequencies without it, but it keeps the behaviour uniform, and it has very good advantages at turn-on and turn-off. David
5th Mar 2021, 11:42 am | #2188 |
Did the Krell not have soft start? I'm guessing muting relays would be out...audiophools can hear relays you know!
Soft Start wouldn't stop oscillation if the design is on a hair trigger, but I am intrigued as to why an amp would blow up on start. Surely, they could snaffle away a couple of relays and WW resistors (a basic SS) in a little enclosure somewhere without the hifi press realising that they were there. They could be disguised as AC filters. I don't imagine that the transformer would stay mechanically quiet for very long without SS, due to the inrush current from (what I assume would be) massive filter caps on switch-on. Something audiophools like to do is increase the size of filter caps without thinking too hard about it. Without soft start, this can lead to rectifiers flaming out and flying across the room... |
5th Mar 2021, 11:45 am | #2189 | |
5th Mar 2021, 12:03 pm | #2190 | |
So it had all the necessary features. But still died twice immediately on power up. All the characteristics of second breakdown. |
5th Mar 2021, 12:53 pm | #2191 |
Great protection, shame about the amplification circuit itself!
Funnily enough, in another thread here a few days back, I was reminded of when I bought my demagnetiser from a branch of the chain 'Laskys', in what must've been 1984. The more commercial tower systems were on the 1st floor, and the exotic stuff was upstairs. They had a line of TTs as long as the eye could see, starting with Dual and going up in price. Doubt I will ever visit such a store again in my life (maybe they exist in Japan?). The first time I saw a Krell was in this store, but in a dark corner, underneath a shelf - totally hidden away... It was in the most hidden spot in the shop, as if they didn't want you to see it. I found its position highly odd. I wonder if this predisposition towards instability had something to do with its low profile in the store? The sales persons were only too keen to sell other stuff - they'd swoop and whisk you into the demo room. Maybe they weren't keen on demo-ing the Krell? |
5th Mar 2021, 2:10 pm | #2192 |
This is a link to someone who stripped one of these Krell's, completely cleaned and reassembled http://home.ca.inter.net/~lloyd.maclean/Krell/Krell.htm
However, if you look at the main amplifier board, the straight heatsink has four mosfets on it. Everything else in the amp is bipolar. But there is no attempt at preventing mosfet oscillation; no grid stoppers, ferrite beads etc. Ugh. But it at least gives a good impression of the scale of the beast. The one you saw at the hifi shop hidden away had probably bitten the dust already. Craig |
5th Mar 2021, 2:34 pm | #2193 |
Bipolars can oscillate, too.
That link also has the Krell brochure for it, which makes a big thing about very low feedback - meaning overall feedback. Local degeneration is either invisible or doesn't count. These things made a big splash back in the day, but maybe they invented the boat-anchor class of amplifier. And not a fitting tribute to 'Forbidden Planet'. Robbie the robot could have done better! David
6th Mar 2021, 12:08 pm | #2194 |
I had no idea that Krell used MOSFETs. I wrongly assumed that, like most American amps, they'd have BJTs all the way. I tend to think of UK OEMs being more into MOSFETs and the US makers opting for bipolars.
In fairness to our American cousins, I ran some tests on Levinson's ML1 preamp and found that its noise spec and FR flatness puts many modern OEMs to shame. Like a lot of gear from the period, they are overpriced today - but at least there is some substance to the claim of quality (volume pot has exceptional L/R matching), and it's not just a nice front panel and a lot of dogma. If you consider Krell's fans, however quiet they could have been, unless you put the thing in a separate room, then I would've thought that the THD advantage to running the thing in pure class A to be somewhat obviated by the additional low-level fan noise... An A/B design of the day might have had more THD on paper, but if the fan noise is -50dB relative to your mean listening SPL, then the only real beneficiaries of the class A amp will be your pets on a winter evening. |
6th Mar 2021, 12:39 pm | #2195 |
The Mosfets are not the output devices; they are the second stage of the input amp. Then after that bipolars for the voltage amplifier, drivers and output stage.
Why mosfets in the middle of the amp? Who can say. |
7th Mar 2021, 4:35 pm | #2196 | |
The main problem turned out to be failed smoothing capacitors on the PX25 DC filament supplies. These accounted for the 'tizz' which came from the 200Hz, 300Hz, 400Hz etc harmonics out of the bridge rectifiers. Once they were replaced the remaining hum turned out to be at 50Hz. There was ~2mV RMS of it across each of the 8ohm speakers. The customer has a very high sensitivity horn speaker system which makes 2mV RMS very audible. The amp is very nicely laid out and constructed. The chap who designed and built it has long experience and knows a good deal about the subject. So I was surprised that the hum level was so high. My usual experience of 50Hz hum is that it comes either from the small-signal valves' heater supply, or from poor layout of the input stage wiring, or from a signal grounding problem. I spent some time checking all of these out, but none seemed to be the cause of the trouble. Eventually I tracked it down to 50Hz ripple on the PX25s' HT supply ! It turned out that although the amp designer is very experienced, his experience clearly doesn't cover the fact that directly-heated rectifiers, like the 5U4G, will impose a 50Hz component on their HT output if their filament's fed from a 50Hz supply and the output is taken from one end of the filment, as it was in this amp. The situation is worse if the subsequent filtering is also a bit light in capacitance, again as it was in this amp. Given the care that's gone into the rest of the design I can only assume that the amp was only ever tested into insensitive speakers, and the actual output was never measured. If it had been then the 50Hz would have shown up and a pair of 'centring' resistors could have been used to connect the HT rail to the rectifier filament. Doing this eliminated the 50Hz almost completely. Cheers, GJ
http://www.ampregen.com Last edited by GrimJosef; 7th Mar 2021 at 4:52 pm. |
7th Mar 2021, 5:39 pm | #2197 |
That does seem a curious oversight in a type and design of amplifier where a need for awareness of safeguards against hum is prominent throughout. I'm accustomed to seeing rectifier heater winding centre-taps in bigger vintage HT transformers where the 5V winding is of around 3A or greater capability (i.e. 5U4 and beyond in filament heating current)- I can't claim to have done the sort of statistical analysis that would let me claim that the majority are so equipped but it's certainly not an unusual feature. Extracting the HT from the rectifier filament winding centre-tap also cuts the HT current gradient along the rectifier's filament. Admittedly, a fixed winding centre-tap can't be adjusted for minimum hum in an overall circuit but it's surprising that even the resistor centre-tapping scheme wasn't provided for. Perhaps it illustrates how some of the science and art of valve amplifier design has faded into the background over the years.
8th Mar 2021, 3:24 pm | #2198 |
Ah, maybe I’m different in the world of audio electronics, as I usually do a sweep of the output between 20Hz and 50KHz down to -120dBV on the lookout for noise on the output. This lifts the stone on all sorts of creepy crawlies A common creepy crawly seen on early spins of a PCB is errant charging pulses emanating from the reservoir capacitor ground layout in the power supply. When I was doing the EF184 "bits ‘a this and that" amp it showed fairly early on the EF184 heater had to be run off a DC supply! Regards Terry Last edited by Valvepower; 8th Mar 2021 at 3:26 pm. Reason: Add something |
12th Mar 2021, 6:23 pm | #2199 |
Part of me thinks this:
https://www.telegraph.co.uk/luxury/t...four-ferraris/ is complete and utter audiophoolery. Another part of me thinks "OK, if that's how you want to waste your money, feel free, and kudos to someone for making a fat profit as a result". |
12th Mar 2021, 6:54 pm | #2200 |
I heard that system, or maybe an earlier version, at an audio show a couple of years ago. It sounded fine. As always though the 'sound' was dominated by the original recording (as it should be), the speakers (they were seriously expensive and also seemed to work well enough) and the room (well, it's a hotel, I guess they did the best they could with it).
I think with a little care it would have been possible to assemble an amp + preamp + CD player using brand new components for about 0.5% of the cost of that system and not be able to find anyone who could have distinguished the two in a properly conducted double-blind test. At another audio show, nearer 10 years ago now, a group of enthusiasts were challenged to assemble and demonstrate the best system they could using second-hand bits and pieces bought at sales and on eBay. The budget, if I remember rightly, was £250 or so and that had to include everything - source, amplification and speakers. The result sounded very creditable indeed. Cheers, GJ
http://www.ampregen.com |
