Old 15th Apr 2023, 5:03 pm   #1
FRANK.C
FRANK.C's Avatar
Default Hedghog L Standards Converter
The FPGA's needed to build the previous Hedghog's have become very difficult if not impossible to get. The Hedghog L is in response to that.
The Hedghog L uses a iCE40HX1K FPGA and a PIC microcontroller. The FPGA is very small compared to the Cyclone FPGA's used in earlier Hedghog's. So much so that before I tried I did not know if even the most basic converter would fit in it. It was chosen mainly because at the time of starting this project there was a good number of them in stock.
As much as possible of the workings of the converter was farmed out to the PIC so as to leave as much room as possible free in the FPGA. Even after doing that the converter had to be pruned back hard in order to get it to fit.
It uses a 2 line interpolater as it was all that would fit.
It has an option of equalising pulses and also can do aspect ratio of 4:3 in to 4:3 or 5:4 out.
Doing 16:9 in to 4:3 or 5:4 out would need little more space but would not fit.
One way of obtaining more functionality is to use a multiple boot system to programme the FPGA. With a number of programme images stored in flash memory. Each image can have a totally different function to each other. Depending on which function is required the appropriate image can be loaded into the FPGA.
To this end I have used 4 programme images.
1 is a 405 line converter with 4:3 input 4:3/5:4 output.
2 is a 405 line converter with 16:9 input 4:3/5:4 output.
3 is a 405 line test card.
4 is a 819 line converter4:3 input 4:3 output.
It also has a programmable multi standard modulator
The PIC now does the programming of the modulators and the video decoder. It also provides the 4 MHz clock for the modulators, drives the LCD and reads the encoders.
It's performance isn't up to that of previous Hedghog's but that said it still does a reasonably good conversion.
Details can be found here
Frank
Name:	HEDGHOG L PCB BOTTOM.jpg
ID:	276903   Click image for larger version
Name:	HEDGHOG L PCB TOP.jpg
FRANK.C is offline
Old 15th Apr 2023, 9:08 pm   #2
slidertogrid
slidertogrid's Avatar
Default Re: Hedghog L Standards Converter
Are they available ready built? I have the previous model but would like another.
Rich
slidertogrid is offline
Old 15th Apr 2023, 9:14 pm   #3
FRANK.C
FRANK.C's Avatar
Hi Rich
I don't supply them. But forum member Freya does built them.
Frank
FRANK.C is offline
Old 16th Apr 2023, 10:58 am   #4
af024
Hello Frank,
Thank you for your update.
Does program image 2 - '405 line converter with 16:9 input 4:3/5:4 output', do a 4:3/5:4 centre grab or does it 'squash' the entire 16:9 image into 4:3:5:4?
Cheers.
Now where on earth did I remove that from?
af024 is offline
Old 16th Apr 2023, 11:47 am   #5
FRANK.C
FRANK.C's Avatar
Hi
This Hedghog operates the same as others with this feature.
If you were to use it in 4:3 to 4:3 mode and the input was 16:9. The entire 16:9 would get squashed to 4:3.
When used in 16:9 to 4:3 the appropriate amount gets cropped off each side to leave the centre so it will fit in 4:3 with the correct aspect ratio.
I hope that answers your question OK.
Frank
FRANK.C is offline
Old 16th Apr 2023, 1:32 pm   #6
af024
Thank you Frank, yes it does. Kind regards,
Andy
af024 is offline
Old 16th Apr 2023, 4:34 pm   #7
murphyv310
murphyv310's Avatar
Hi.
Great work as usual Frank.
I wonder if they will be priced cheaper? I suppose that's a question for Stephen!
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 16th Apr 2023, 6:57 pm   #8
FRANK.C
FRANK.C's Avatar
Hi Trevor
Stephen would be the best person to ask about that.
But I couldn't see them being any cheaper. Components have gone up in price.
It is a while since I ordered PCB's but back then they were around 30 euro.
The last ones I got cost 42 euro. This mostly down to some country's outside the EU are now collecting VAT and duty for the EU at the point of sale.
That may not be the case in the UK.
Frank
FRANK.C is offline
Old 25th Apr 2023, 5:41 pm   #9
slidertogrid
As Frank suggested I contacted Stephen for a ready built converter. It arrived today and I am very pleased with it. Easy to use, comprehensive instructions are supplied. I connected it to my faithful Dynatron and it works very well!
I have taken a couple of pictures. This is a slightly early birthday present to myself it will be my bench converter and means I won't have to keep unplugging the other Hedghog each time I want 405 on the bench.
Thanks Frank thanks Stephen ! Much appreciated!
Rich.
ID:	277368   Click image for larger version
ID:	277369   Click image for larger version
ID:	277370   Click image for larger version
