28th Apr 2021, 12:44 am | #41 | |
Re: Crompton 60W bulb
I used to have 60 watt orange lamps that were in a couple of wall lights in the house I used to live in over 20 years ago - they were still there and working when I moved, probably long gone by now! However, seeing these orange and pink looking lamps seems to be ringing bells with me, so I need to have a look next time I'm in the loft to see what I can find - you never know! |
28th Apr 2021, 1:58 am | #42 |
There were red or orange night lights in my boarding school dormitory.
-- Graham. G3ZVT |
28th Apr 2021, 6:49 am | #43 |
I remember those from a bed warmer we had when I was a kid, the warmer was made of pressed sheet metal in a bar of soap type shape, my Mum slipped it under the sheets before I got in bed. This'd be early 70's before central heating.
Andy.
28th Apr 2021, 10:25 am | #44 |
I have got a pink bulb in storage and can remember testing it with a multimeter last time I spotted it.
28th Apr 2021, 3:13 pm | #45 | |
No particular dedicated use.
Oh I've had that for years dear!! |
28th Apr 2021, 6:04 pm | #46 |
Because orange or amber fireglow lamps were used in electric fires, there arose a widespread and erroneous belief that such lamps were "more warming" than other colours .
Use in electric bed warmers as described a few posts back was very common, when in fact a standard clear or pearl lamp would have worked just as well and been cheaper. Red or orange lamps of low power were widely used as nightlights in school dormitories and similar places, minimum sleep disturbance but enough light to safely walk around if need be. |
28th Apr 2021, 6:35 pm | #47 |
I hope this isn't drifting too far OT, but the mention of woolies in regards to lamps takes me back. I looked after the light fitting displays. On display, fittings were always equipped with 15W bulbs to avoid the big electricity bill from so many being in use. But the life was noticeably rubbish, so I was forever replacing them. Now I know we would have only been paying 'cost to the store' as they were treated as shrinkage. But I wonder if the significantly longer life of say 40W would actually have been cheaper? Might even have saved a bit of money on other heating for the store?
28th Apr 2021, 7:54 pm | #48 |
My modern electric fire in the lounge has a white candle bulb which lights up a red faux coal and log effect the flame effect us done by an electric motor driving the wheel round
29th Apr 2021, 12:16 am | #49 | |
5 pence a unit was about the going rate for many years, so saving 25 KWH was saving about £1.25 in 1000 hours. The lamps were probably about 10 pence each, cost price, not retail. The electricity cost therefore exceeds the lamp cost. And remember that the 15 watt lamps might well have lasted their 1000 hours. If 100 lamps are lit for 12 hours a day, then at least half a dozen failures each week are to be expected. |
29th Apr 2021, 8:01 am | #50 |
These bulbs are still available from https://www.lampwise.co.uk/crompton-...ight-bulb.html
I use one in my HMV fan heater instead of fireflow bulbs which tend to shed their red coating when warmed up. |
2nd May 2021, 12:16 pm | #51 | |
Sold them to elderly ladies that didn't like the idea of being fried alive by an electric blanket. The Belling was of course removed before retiring. Maybe it also reminded them of the ancient version that was filled with hot coals! John. |
2nd May 2021, 12:46 pm | #52 |
Thinking about it the coloured lacquered fireglow lamp was probably one of the most widely used coloured lamps of the electric fire era, namely the 1950s and 60s.
I pulled this Belling 'Adam' fire, Cat No 743B off the tip many years ago. I believe it's quite a late example of a much older design that remained unchanged for decades. It still gets used from time to time just to take the cold air off the room. 2 X 60W lamps are used, the heat of which creates a warm air flow that turns the deflector wheels. The patterned glass completes the effect. J. |
26th May 2021, 1:42 am | #53 | |
Cheers - Martin ZL2MC |
26th May 2021, 8:18 pm | #54 |
On Air light?
26th May 2021, 10:22 pm | #55 |
My gran used to work as a cleaner at the local ODEON she would bring coloured bulbs like this home .Would they have been used in the concealed lighting perhaps and possibly used with dimmers ? .Some of the bulbs had three prongs on them instead of the usual two
26th May 2021, 11:40 pm | #56 | |
It was common practice to replace all these lamps, working or not, either after a set time, or when a certain percentage had failed. The used but still working lamps would likely have been a staff perk. 3 pin bayonet caps were used for various special purpose lamps, including 75 volts (railway trains), 160 volt, 80 watt (ballast lamps in series with fluorescent tubes), smaller mercury vapour lamps (shop window lighting), and twin filament lamps (railway signals, operating theatres) Don't think that I have ever seen a coloured but otherwise standard lamp with a 3 pin cap. |
