29th Nov 2009, 12:31 am | #21 |
Re: Strange plugs & sockets at Lewis's Liverpool
We have some at work which have the L&N of a standard 13 amp plug, but a ROUND earth pin, as you would expect to see on the old 15 amp size. They are fused and are identical to standard bs1363 plugs otherwise(in fact I suspect they have been modified from same)
We had some Walsall gauge in the school science lab when I was a lad. I think these were all protected by a 30 mA trip, or were isolated or something.
29th Nov 2009, 1:17 am | #22 |
There seems to be an infinite variety of non-standard 13-amp-like mains plugs. Our school science labs had some (made by Dorman Smith, if I remember rightly) which were exactly like 13-amp plugs but with the live pin at 90 degrees to its usual orientation. The application of a craft knife to the live holes of a cheapo 4-way extension lead allowed them to fit! They were all fed from an isolating transformer at the front of the lab. Good thing too, with that kind of bodgery around...
29th Nov 2009, 8:54 pm | #23 |
Hi all,
It looks like the plugs & sockets in my original post were Wandsworth types very similar to those in Russell W B's post no.16. In Lewis's I don't think they were for any special supply as they were everywhere including the floors & ceilings! I posted the same query on Electroteknica's forum too and a reply contained an illustration from an old catalogue showing something almost exactly the thing I was thinking of. All the other plugs discussed here are interesting too and I would be curious to find out exactly how many variants there are of the standard 13amp design. I think Britmac as well as Walsall were famous for those. Thanks for all your replies. Cheers de Pete
29th Nov 2009, 9:17 pm | #24 |
One of my schools (Ysgol Y Gader, Dolgellau) had a physics lab built in the 1960's, this had mains supply via Walsall sockets. As far as I know, these weren't fed via a big isolating transformer. My physics teacher commented to me that he'd never come across them.
Obvious question is: Who sells the mating plugs? (The school at that time - mid 1970's - had sufficient for its needs) |
29th Nov 2009, 11:14 pm | #25 |
RS sell a couple of versions - the round earth pin type, and one with a sort of T profile earth. I suspect that most of the big electrical factors carry a range.
BTW, I've come across these in hospitals too, for use with X-ray gear, and also for circuits intended for critical equipment (possibly to stop the cleaners unplugging it when vacuum cleaning, but more likely because they are maintained supplies, or have dedicated earths). |
30th Nov 2009, 1:07 am | #26 |
I recall seeing plugs with 90 degree rotated earth pins in old hospitals, too, as well as normal-looking BS1363 plugs with a notch in the earth pin. These were for use with sparkless sockets which were interlocked mechanically to prevent the plug being inserted or withdrawn with the socket live. The on-off switches were mercury-bottle tilt switches.
These were developed to prevent explosions and messy fatalities when flammable anaesthetic gases were used in operating theatres. Don't worry, ether and chloroform have been replaced by safer alternatives nowadays, but the anti-static precautions still remain. In the 1970s we still used to megger-test floors, rubber tyres on trolleys and rubber hoses, all made from conductive materials in those days of course.
30th Nov 2009, 9:55 pm | #27 |
Yes, I remember those mercury switched sockets at the hospital I worked at, They were made by Walsall. The matching plugs were marked "Theatre Use Only". The light switches were mercury types too. Also, there were special non-fused 13amp gauge plugs with standard pins and an extra large cable outlet for portable X-ray machines.
Cheers de Pete
30th Nov 2009, 10:16 pm | #28 |
30th Nov 2009, 10:44 pm | #29 |
Ok, I won't.
1st Dec 2009, 9:58 am | #30 | |
Of course, these are wildly different to what, at first glance, appears to be a normal domestic plug to BS1363, and I guess these are the ones you're interested in. To this end, I attach a photo of a fused 13A 'Walsall'-gauge plug, for the benefit of those who have never come across one. We use fused and unfused variants at work, with the unfused ones having sockets fed individually from suitably-rated fuses in a distribution board, and used on 'fixed' equipment, like 19" bays. Note the lettering on the plug: 'Not for Domestic Use'.
Regds, Russell W. B. G4YLI. |
