23rd Nov 2009, 9:31 pm | #1 |
Strange plugs & sockets at Lewis's Liverpool
Hi All,
When I was a kid my mum occasionally took me to Lewis's department store in Liverpool. I used to marvel at the escalators and it was the first time I saw a security closed circuit television camera. However, what stuck in my mind was that they seemed to have a type of mains socket I've never seen before or since. There were two twin gang sockets at the foot of every stone effect column and some in the ceiling too. The socket itself was a round pin affair with the earth pin much nearer the centre line than the usual BS546 sockets and I think it was the same size as the current carrying pins. The sockets were a circular bakelite insert about 2.5 to 3 inches in diameter on a metal oblong plate. They weren't Wylex or D&S but something quite different. The last time I visited Lewis's a lot of them had been changed to standard 13amp sockets. It's sad, I know, but when it came to plugs & sockets I was quite observant as a ten year old . Maybe a forum member was an electrician for Lewis's and has one in his or her bitbox Cheers de Pete
24th Nov 2009, 1:58 am | #2 |
Re: Strange plugs & sockets at Lewis's Liverpool
Now that brings back memories. used to always go to Lewis's, and Blackler's! long gone now, sadly.
Are you sure the plugs aren't just the smaller of the BS546,as shown here? even as late as the '90s, these were still used at our uni hall of residence!
Regards, Ben. |
24th Nov 2009, 2:14 am | #3 | |
More seriously, there were lots of nonstandard mains sockets around at the time you're talking about. The 13A mains socket rapidly became standard in commercial premises after WW2, but many buildings had separate ring mains for things like floor polishers and vacuum cleaners. It was considered desirable to keep these appliances off the 'standard' supply - maybe it still is. Paul |
24th Nov 2009, 2:52 am | #4 |
I have misty recollections of things like this. As Paul says, I believe it was something to do with permitting certain applicances to be connected only to certain power points.
24th Nov 2009, 10:00 am | #5 |
Ben - your link doesn't seem to work; Wikipedia cannot find it.
Mike. |
24th Nov 2009, 10:46 am | #6 | |
Oh, and I've fixed the link to the BS546 plug pictures: Try this one.
24th Nov 2009, 11:18 am | #7 | |
Regards, Ben. |
24th Nov 2009, 11:22 am | #8 |
Hello,
MK still make BS546 plugs and sockets in 2A, 5A and 15A the 2A socket is here http://www.mkelectric.co.uk/en-GB/Pr...s/K770WHI.aspx Yours, Richard |
24th Nov 2009, 12:31 pm | #9 |
I know the 15amp version of these plugs are still used in India and South Africa maybe a hangover from colonial days.
Mike |
24th Nov 2009, 12:41 pm | #10 |
Hello,
Yes, I had a 15A one in South Africa, it seems to have gone missing now. I also had a 5A one (and wall socket) in the UK, will have a rummage, but I think that is lost as well. Michael |
24th Nov 2009, 1:16 pm | #11 | |
I've seen lots of modern 5A and 15A BS546 sockets in theatres, and 2A ones are common in window displays, sockets for standard lamps switched by the main light switch in hotel rooms, and the like. Chris |
24th Nov 2009, 2:15 pm | #12 |
a friend of mine moved into a 4 year old flat and this had 2amp sockets fitted for standard lamps around the house, meant we had to change the plugs on his lamps before we could plug them in
"Oh yes I love television, all those wiggly lines"! |
24th Nov 2009, 3:26 pm | #13 |
Following on from Chris in #11, you often see 3A and 5A fittings used for lamps and other ambience - related items in places like restaurants and public houses. Instances seem to be becoming more common, almost like a revival of what many would see as vintage or outmoded technology. I suppose an added advantage is that it gets around the irritation of people putting 13A fuses into 13A plugs regardless of what the correct rating should be.
24th Nov 2009, 9:35 pm | #14 |
We had Lewis's (Lewis Bros, later bought by Owen-Owen) here in Hanley as well (not to be confused with John Lewis) and I also remember non-standard 13A wall sockets, however our branch had the ones with Horizontal earth pin and vertical L&N which I think were made by Walsall.
Kevin |
25th Nov 2009, 9:14 pm | #15 |
Hi All and thanks for your interest & replies.
True, Paul,- Scousers, eh? I've had loads of experience with BS546 plugs & sockets (I've even got a box of 'em the cellar including a 16amp South African one and a 15amp wooden adaptor!) and the one's in Lewis's were definately not those. The one's I'm thinking of had the N & L holes on the centreline of the circular bakelite plate and the earth hole (possibly the same diameter or smaller) was just a bit higher. Just to add to the confusion, my primary school had a smaller version for the 100volt line speaker system in each classroom to distinguish it from the BS546 mains socket alongside. Cheers de Pete
25th Nov 2009, 10:23 pm | #16 |
Would this be what you remember?
Regds, Russell W. B. G4YLI. |
28th Nov 2009, 12:01 am | #17 |
Slightly OT When travelling on the London Underground, I used to see different type of 13 Amp plug IIRC the earth pin was horizontal, and the live neutral were vertical.
Has anyone else seen these before? |
28th Nov 2009, 1:16 am | #18 |
28th Nov 2009, 9:56 am | #19 |
Yes. They're Walsall gauge, and were used in the BBC extensively. We used them at transmitter sites for maintained bay and rack supplies - still do, in fact. Studios (someone will confirm, no doubt) used them for different applications.
We have a drawer-full of them at work. Our are non-fused. Just the sort of thing to put on your granny's kettle lead for an April Fool!
28th Nov 2009, 10:23 am | #20 |
Its quite common for shops etc to use unusual sockets.
I did a couple of days recently installing seasonal tills for a well known retailer, all had unusual variations on the 13A socket. I asked my colleague why and he said that it is to stop the staff unplugging the till/chip n pin or other bit of kit and using the socket to charge their phone. J |
