Old 15th Nov 2020, 6:20 pm   #1
LA9CHA Thorvald
Default FT290R problems
Hello, can any please tell me where due I find Q05, an ICL7660 voltage converter from +6,8v to -6,8v. Output on the -6,8V is only -1,7V. I can not find any "Reg Unit PB-2239".(Perhaps my eyes need update!)
LA9CHA Thorvald is offline
Old 15th Nov 2020, 6:27 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: FT290R problems
Hi not sure what your after is at a source of the ICL7660?
If so there seem to be many suppliers including https://www.cricklewoodelectronics.c...waApNHEALw_wcB
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 15th Nov 2020, 9:32 pm   #3
LA9CHA Thorvald
Thanks Mike, my problem was where to locate the item on the unit, but I finally now found it and had it checked. All is ok! The vu meter went to full deflectionas soon as the unit was switched, but I had that fixed!
Old 15th Nov 2020, 10:16 pm   #4
SiriusHardware
For future reference I believe the 7660 negative-from-positive voltage generator IC is made by several manufacturers each with their own prefix, so as well as the ICL7660 there is also the LMC7660 and MAX7660, for example.
SiriusHardware is offline
