28th Feb 2009, 9:39 pm | #81 |
Re: Ekco CT101 is alive (Actually a CT100(M))
Thanks Trevor, Lee, Tas, Trevor and everyone for your kind and encouraging comments. I've been very busy with work recently and haven't had much of a chance to do anything major to the set, but I'm hoping to get back to it soon. Attached is a picture of the set as it is working now. One odd problem is that the vertical shift is at the far end of the pot and the picture is still too low. I think that will be the next problem to look into.
Thanks everyone. Kind regards. From Mike.
G7TRF |
28th Feb 2009, 11:42 pm | #82 |
Hi Mike,
I think you've done a brilliant job so far. It's great to see a colour set of this type working. Fifties styling with a colour picture, that's something you don't see everyday. Cheers Des.
www.freewebs.com/405tv |
1st Mar 2009, 1:28 am | #83 |
Hi mike glad you got it going ive been hiding just incase things went bad . if you remember when i got the two sets thay both had broken tubes . the phillips set ended up in italy .The tube was supplied by good old gerry he was glad to rehome it. all i done to the set was fitt the tube. so the dud valves wernt my fault and will remain a mistery or was the set over run at some time?. Oh and dont forget i have the spare scanning yokes. Danny
1st Mar 2009, 8:24 am | #84 |
Brilliant stuff Mike, the picture is looking good!
Isn't that "willow the wisp?"
I'd just like to say "Good luck, we're all counting on you" |
1st Mar 2009, 1:58 pm | #85 |
Really good , look forward to it getting better .
1st Mar 2009, 4:36 pm | #86 |
Superb Mike! The colour looks good, Is that just running through the video stage still or is the signal passing from the tuner?
Cheers Lee
Lee |
1st Mar 2009, 5:10 pm | #87 |
Just to Ekco everyone else's comments, it's certainly looking pretty good now Mike. Nice to see the cartoon that spawned Evil Edna being displayed.
All the very best, Tas |
24th May 2011, 8:04 pm | #88 |
Hi all again.
After a long break without doing anything further to the old Ekco, work has once again commenced in earnest. As reported previously, after replacing a disproportionate number of duff valves and sundry other components, there were still a fair number of faults to get sorted out. These included a frame-shift fault, line jitter, very poor saturation, an I.F. / R.F. fault, Hanover blinds from the simple-PAL decoder and flickering brightness. Added to that are a couple of other faults which have manifested since then – intermittent frame collapse and the R-Y flickering badly and the red background changing in sympathy. First things first – The frame shift “fault” was cured by a mate of mine who roams this forum in the depth of night (Tony G8KBG). Tone came up with a suggestion to reverse the sense of the frame shift control, even though there was no obvious way shown anywhere in the slightly odd circuit. Following Tone’s advice and readjusting the shift control meant that the picture was now nicely centred. The line-jitter turned out to be intermittent contacts on the line oscillator valve holder. A nice simple fault, although one I have yet to completely cure with Servisol and a fibre-pen on the valve pins. Maybe a new valve holder is in order. The intermittent frame collapse turned out to be a very odd fault too – It was the ECL85 valve not making proper contact, but it wasn’t that the pins were dirty – it was that the pins were microscopically narrow. They’re like sewing pins, and they even finish at a sharp point. Another new ECL85 is in order I think. The very poor saturation was caused by the Anode resistor in the 4.43MHz oscillator circuit. It was supposed to be 10K but had slithered all the way down to 63 Ohms. The saturation still isn’t wonderfully good but it’s much better than it was. Still a reasonable amount of work to be done on the decoder yet. The flickering R-Y and changing red background was yet another duff valve - This time a 12BH7 valve. I purchased a new one and the problem has gone away. Tas and I had a go at the R.F. / I.F. fault and got absolutely nowhere but I’ve got a few ideas lined up for that. All the work that we put in over the course of a Saturday has helped immensely though in understanding the layout of the circuit etc. The flickering brightness is a proving to be a bit elusive but I’ll get to that eventually. Anyway, the set is coming along again and hopefully it won’t be too long before it’s fit for taking down to Devon and putting in the museum. As soon as there is any more news I’ll post it up here. Thanks everyone (and thank you to Des, Danny, Trev, Paul, Lee and Tas for the previous kind comments that I rudely never replied to). Kind regards. From Mike.
G7TRF Last edited by Mikey405; 24th May 2011 at 8:11 pm. |
24th May 2011, 8:15 pm | #89 |
That is looking nice!
24th May 2011, 8:24 pm | #90 |
Looks lovely .Im amazed at the cabinet condition too. Its a really amazing survival!
25th May 2011, 12:20 am | #91 |
Wow Mike, that’s looking stunning, hats off to you for battling with the peculiarities of the circuit and the awkwardness of the chassis to work on.
It’s a credit to your skills. |
25th May 2011, 4:06 am | #92 |
Great effort on this one Mike, and I'm guessing this is a rare set too. I would love too see an old valve colour set in the flesh one day... Nice to see it being preserved. Cheers Glen
25th May 2011, 7:54 am | #93 |
Thanks everyone. I'll just keep blundering on until it's working. Thanks Tone for your somewhat enthusiastic praise - Completely undeserved of course - it's only when other people prod me into doing anything and help me out with stuff that the thing gets fixed.
G7TRF |
25th May 2011, 8:04 am | #94 |
Do you know anything of the history of the set? Presumably used for UK colour trials in the early to mid 1960s. But by whom?
Great results so far. I wonder if the heavy lifting department could get it to NVCF at AP in November. |
26th May 2011, 5:04 pm | #95 |
It's hardly blundering on Mike. You're going great guns mate. It's really starting to look very good.
PS: I see you managed to find your Sylvia Peters slide
All the very best, Tas Last edited by Tazman1966; 26th May 2011 at 5:05 pm. Reason: Added a PS |
26th May 2011, 7:32 pm | #96 |
Looking really good nice one Mike.
Simon BVWS member |
26th May 2011, 9:56 pm | #97 |
Nice set, not many about. Nice repair and that slide looks great.
Jeff - could the heavy lifting mob pass it to Bolton after 13th November...? Cheers, Steve P.
26th May 2011, 10:23 pm | #98 |
Fantastic work Mike, that set really is a rare peach! Well done me old mate.
Lee |
26th May 2011, 10:27 pm | #99 |
Great progress, well done that man
I am following this thread with great interest, can't wait for the end result! Mark |
18th Jun 2011, 8:43 pm | #100 |
Hey everyone.
Well a bit more progress made in the I.F. (R.F.) department. My mate Tone came round today and after a lot of fruitless searching and head-scratching, we eventually discovered that the AGC line, once inside the VHF tuner, was not changing, even though there was a swing of about 60V outside the tuner. On opening the tuner up and replacing the usual Hunts capacitor and another 470K resistor, we discovered that a 3.3M resistor had changed in value to 15 Ohms. An almost unbelievable change in value, but attached are the photos to prove it! Anyway, we now have a lot more output from the I.F. stages and even a reasonably clear (but very soft) picture through the aerial socket. It does look as though the I.F. may have perhaps been twiddled though because the fault we have now looks quite I.F.-ish and one or two of the coils look like they've been "got at" although nothing is actually broken. The video cuts off at about 3.5-4MHz and there is virtually no chroma getting to the decoder on an aerial signal. Perhaps somebody has tried to cure the V.H.F. tuner fault by twiddling the I.F. - but that's for another day - maybe even tomorrow. So, can anyone beat the 3.3M down to 15Ohm resistor for a more wildly out of tolerance component? Thanks all, and thank you all for your previous kind (but mostly undeserved) comments. Kind regards. From Mike.
G7TRF |
