4th Sep 2016, 10:26 pm | #1 |
1964 R.C.A. Round tube color TV back to life
Mikey 405 asked me to look after the old girl so davidh 1041 and myself picked it up.
These sets were sold for about £350! in the early 1960s by R.C.A.when they were pushing N.T.S.C. for the UK. They were standard U.S. sets modified to 240 Volt system I 625 line N.T.S.C 4.43 MHz when P.A.L. came into use you could for a fee send it back to R.C.A. to be modified to P.A.L. or do it your self. This TV had been modified to P.A.L. / N.T.S.C. The set is in very good condition but had very bad cataract. The tube is a 21FJP22 twin panel tube and the glue fails and goes opaque. The Tube and valves had the date code for 1964. The set had a lot of dust inside as we all like to see. To wake it up I slowly put volts on the H.T. supply then after that slowly put mains into the set at that point. 26 valves (tubes) started to heat up. I now had sound and light on the screen I tuned it in and had good sound the picture was black and white in the centre of the screen which was not opaque when the colour was turned up the colour was all wrong the set was switched to PAL so something was not working. Since the colour was locked it seemed the PAL mod was not working. I have no diagram for the mod so had to trace it out. It has two valves I found most of the resistors were out of spec and 2 capacitors were leaky I changed them also the two valves and still not working. The mod had had a lot of work on it in the past so I do not know what the circuit was and if it had worked! Plan two feed in 625 line 4.43Mz NTSC and see if it works and I had a diagram for that part of the set. I have a RGB to PAL 4.43Mz converter which I converted to work on NTSC 4.43Mz. this was fed in I now had a good COLOR picture so the PAL mod was the problem. I will look at this later as it is now working in colour and the cataract needs to be fixed. Yesterday Mikey 405 and Davidh 1041 came over to help with the cataract the TV was dismantled and the 21FJP22 removed as can be seen the safety screen and glue almost fell off I had a faulty 21FBP22 which is not a twin panel tube so has a separate safety glass and rubber gasket which was removed cleaned and fitted to the 21FJP22 . The CRT was refitted and the RCA reassembled and when turned on we now could see a full picture. The TV is now working but some things need to be corrected the height shrinks as it heats up, horizontal hold is not good, PAL ident not working and UHF tuner is low gain I had to use a Bush tuner. Keith |
4th Sep 2016, 10:35 pm | #2 |
Re: 1964 R.C.A. Round tube color TV back to life
More pics
Keith |
4th Sep 2016, 10:43 pm | #3 |
I studied for my City & Guides Radio & TV Servicing Cert at Southgate Technical in North London. A sixth year was added to the course to cover Colour TV Servicing and I took it in its first year.
The practical part of the course used those RCA sets as they were all that was available at the time. If I remember correctly they were simple PAL (no delay line). |
4th Sep 2016, 11:27 pm | #4 |
I very much enjoyed the parts of this that I understood to some degree Keith but I couldn't guess what a "cataract" was in this context. I googled above to find that its a deterioration in the resin bond re the face plate. Well you live and learn thanks!
Dave W |
5th Sep 2016, 1:37 pm | #5 |
I recognise this set! Had several valves missing. If only the internet and forums like this were around I would've been able to have got it going.
So pleased to see the set up and running. Well done. Brian |
5th Sep 2016, 3:04 pm | #6 |
I'm fairly sure there was one of these at the ITA Burnhope site in the early '80s.
Is this perhaps the same one? |
5th Sep 2016, 4:28 pm | #7 |
what an interesting set. Now I may know why the Korting / Decca Colour Tv pattern generator I have has an ntsc / pal switch ( and yes it gives you ntsc 625 line ). regards Peter B |
5th Sep 2016, 6:05 pm | #8 |
A 'proper' colour television receiver. Well done. John.
5th Sep 2016, 7:54 pm | #9 |
Compared to the first UK SS CTV's, that chassis looks quite compact to say it's early 1960's.
5th Sep 2016, 8:20 pm | #10 |
So the old girl lives! Excellent news. Well done to you all.
All the very best, Tas |
7th Sep 2016, 1:01 am | #11 |
Yes indeed!
Classic TV Show Theme Tunes |
7th Sep 2016, 12:24 pm | #12 |
Truly excellent to see a picture on this old set, well done to you all!
Lee |
7th Sep 2016, 2:34 pm | #13 |
Great stuff.
I never knew these RCA PAL sets existed or that RCA attempted to force NTSC on us. Great pictures. Do you think the 3rd picture in your first post looks like Eddie Izzard being attacked by a blue sponge cloth? Cheers Andy
www.youtube.com/user/andyvalve100 |
7th Sep 2016, 3:17 pm | #14 |
Fantastic work, guys. It's great to see these old sets being nurtured back to life.
I remember seeing sets of this type around Lime Grove Studios when I was at the BBC. The experimental colour studio was very close to Telecine where I worked. It would have been lovely to get one as they were being thrown out as I'm sure happened. Later, the huge RBM sets in Imlock cabinets ruled the roost but that was well into the PAL days. |
7th Sep 2016, 4:03 pm | #15 |
Absolutely brilliant to see one of these sets survive - not only survive but now restored to working order. It would, however, be somewhat misleading to suggest that RCA tried to force NTSC on anybody - NTSC was simply the only viable show in town when Europe first looked at colour systems and was the preferred choice of the BBC - hence the importation of NTSC sets from RCA.
This set started life as an RCA CTC16 (525 line NTSC 3.58MHz), was converted to 625 line NTSC 4.429MHz (the BBC preference) and later to 625 line PAL 4.43MHz when that system was finally adopted. There is a case for leaving it in its current state ie 625 line NTSC but it would be interesting to get the PAL mod working (and documented) - either way a very significant addition to the very limited cohort of colour oldies Regards to all and well done to those involved in the preservation and restoration John |
7th Sep 2016, 9:31 pm | #16 |
7th Sep 2016, 9:40 pm | #17 |
8th Sep 2016, 8:02 am | #18 |
That's the one. They were so imposing and the set-up controls were easy to get at but not easy to set up if you see what I mean!
8th Sep 2016, 11:02 am | #19 |
Marvellous to see this RCA set back in action, great effort and you have my respect in doing it. Really it is an historic item; sadly early electronic items seem not to be much prized by a society which depends upon, and is so besotted by electronics.
On a just an aesthetic note I've always rather liked the shape of the masked off round CRT; I know half the picture is missing off the corners, but they look like 'proper' TVs. I suppose in the same way level-crossings still show the picture of a steam loco and artwork often shows the outline of a '162' at the side of a landline telephone number. |
8th Sep 2016, 5:45 pm | #20 |
It will be great if you are able to get the PAL modification working. Is it a simple PAL decoder as I suggested in post #3 ?
