26th Jul 2020, 6:26 pm | #1 |
Encapsulating output tx's
Just a thought before I paint these , I have fitted two EL84 push pull output tx's in aluminium boxes to make them look pretty , question ! the wires may be crossing each other primary side sec should be ok , thought's please Mick.
26th Jul 2020, 7:06 pm | #2 |
Re: Encapsulating output tx's
No problem at all (as long as the insulation holds up!). All the wires carry the same signal so crossover isn't an issue.
26th Jul 2020, 7:33 pm | #3 |
Thank's that's good news , a picture of the tx's before painting , they were made of 3" box section the top was glued on using araldite the corners rounded off , they will be satin black. "nice " Mick.
5th Aug 2020, 1:44 pm | #4 |
That's a great way to finish off a TX, I was thinking of folding something up but this looks better.
5th Aug 2020, 5:37 pm | #5 |
Hi I have not fitted them yet so here is a picture of them painted, good luck with yours, Mick.
5th Aug 2020, 6:27 pm | #6 |
They look great!
Martin BVWS member GQRP Club |
6th Aug 2020, 5:43 pm | #7 |
That's a brilliant idea Mick, I built a 300B SET amp a couple of years back and couldn't really find decent enclosures that fitted the Hammond transformers and looked right (plus they were pretty expensive). Also I rather underestimated the weight of the finished amp meaning it was easy to slightly twist the chassis when moving unless supported equally all round.
This has inspired me to revisit the project and start some metal bashing, so thanks!
Pete BVWS Member |
6th Aug 2020, 5:59 pm | #8 |
Hi Pete ,good for you for revisiting the project , I found the ali box section on E Bay , good luck with your project. Mick.
7th Aug 2020, 7:20 pm | #9 |
Hi Mick,
Any reason why you did not bother potting these items; just curious? Joe |
7th Aug 2020, 7:43 pm | #10 |
Hi Joe , the transformers were ex equipment , I had to have one rewound , if the other one packed up in the near future ,I can easily remove it and replace , no other reason , Mick.
