20th Jul 2020, 11:31 am | #1 |
Audio Research Reference 2 Pre Amp Dead 1CH
My mate with more money than sense has one of these pre-amps, it cost him £3000 second hand!!!!!!!!
He was always fiddling plugging different valves in to try for a "sweeter" sound, one day he unplugged a valve without first turning it off. There was a loud thump in the speakers eeeek. He turned it off, replaced the valve, turned it on and was rewarded with one channel dead suprisingly not the channel he removed the valve from? It then came to me. I am at a loss how the electronic volume control operates. I get signal all the way up to pin 10 on U4 then i think it should emerge from pin 11 which it doesn't, I just get a voltage according to the volume control setting from 0 to 5 volts, comparing with the other channel it has only signal on it's pin 10 no voltage. I have replaced U4 & U5 seperately, U4 is a bit pricey so I wonder if the old U5 blew it up again ? I don't want to buy another one at £16 a pop only to blow it again so I wondered if anyone has any experience of using these digital potentiomers, are they as fragile as they seem and any othere ideas that might help me. I have uploaded a pdf of the relevant page in the manual but hi-fi engine has the full manual. Attached Thumbnails
https://www.facebook.com/gntrading |
20th Jul 2020, 12:11 pm | #2 |
Re: Audio Research Reference 2 Pre Amp Dead 1CH
Are the reels of sellotape around the valves for a reason.....
Regards |
20th Jul 2020, 12:13 pm | #3 |
Anti-microphony rings...
20th Jul 2020, 12:40 pm | #4 |
Think of them simply as a stepped pot.
Vhigh at the top Vlow at the bottom Vwiper from the selected tap. Serial data fed into U/D, CS and INC select the tap. There are TWO of these digipots stacked one on top of the other and U5 gets to choose whether to pass on the voltage from the top tap or the bottom tap to get a bit more range and resolution (It doubles the number of taps available so it really does increase resolution by one bit!) More of those damned current source FETs And DC coupling in valve stages But why bother with valves after using cheapie solid state analogue switches? Sorry, but it's a hilarious design. David
20th Jul 2020, 1:18 pm | #5 |
Like David says, there are 2 stacked pots of 100K and 10K.
Ditto for the -ve input side of the balanced inputs. I assume you are tracking an input signal to pin 10 / U3 ? You should then see ~10% of this pin 9 / U3 and pin 10 / U4. Pin 11 / U3 should be between 10% and 100% depending on the volume control (verify, A). Pin 11 / U4 should be between 0% and 10% depending on the volume control (verify B). If A is changing with the volume control but B is not, then U4 may be faulty. If NEITHER is changing then the micro-control (driving 2/3/4) MAY be dead. You should see some digital activity on pin 2/3/4 as you alter the volume control. dc |
20th Jul 2020, 1:38 pm | #6 |
It has been suggested quite seriously that the reported sound quality of hi fi gear is most directly related to its price. If I'd dropped three grand on something like this (as if!), I'd have hoped the manufacturer had got it right.
20th Jul 2020, 1:41 pm | #7 |
From an engineering point of view, a single 5534 op-amp would put it in its place
20th Jul 2020, 2:10 pm | #8 | |
But, no, if you look a the diagrams, there are a number of silly things done just to be different, just to be something the marketing people can point at. Do they make it better? No. Do they make it worse? Yes, in several respects, not least repairablity. Designing electronics by fashion is a very poor second to using science and mathematics. David
20th Jul 2020, 2:20 pm | #9 | |
It also used digital pots, stepped as David has said. I never did find out what had caused the original problem, although I suspect that some conductive debris may have dropped in through ther vent slots on the top of the pre and traniently shorted the valves' HT rail to the -15V rail which powered the chips (both rails ran on top of a double-sided pcb so qwere vulnerable to falling objects). It turned out that whatever the fault was had blown everything - all 8 vol control chips were, to a greater or lesser extent, toast. AR had carefully matched them to get very high-accuracy tracking of the controls. They had sets of replacement chips for sale but these were expensive. So I built a jig, bought some chips from eBay (at least one type was obsolete), and matched up a couple of sets myself. It was a faff, but it worked fine in the end. Whatever the original fault was it hasn't, as far as I'm aware, recurred. EDIT: Dave has raised the possibility of the microcontroller being damaged. Your mate had better hope that it hasn't been. It would be worth scoping the control signals (make sure they're not being shorted by blown circuitry in the vol controls) to check they're OK before investing time and effort in the vol control chips. Cheers, GJ
http://www.ampregen.com |
20th Jul 2020, 2:43 pm | #10 |
Just to check in another possibility, this is a volatile memory type with pseudo log resistor chain.
It is supposed to come on at the 10% tap before data gets loaded to it, but this could be rather a short period if the CPU is quick off the mark. I checked because U've used the non-volatile Maxim digipots. They are EEPROM based and the EEVPROM part has a wear-out mechanism, they are only good for so many re-writes. EEPROM wear-out is why odometers are starting to fail on high mileage cars... they've been written to too many times and their lives used up. It's something to check when you see a digipot used as anything other than a preset. I see it's just a 2-slope approx to logarithmic, like the cheapest crappy panel pots. For use in something that price, I'd want something better tempered. "The well-tempered volume pot"? better for listening to not just Bach. As said, see if volume changes have any effect along the signal flow path. Follow the signal and find where it stops. Check for activity on the digital programming lines. David
20th Jul 2020, 3:37 pm | #11 |
Hmm. I always wondered what the schematic of one of their Reference Series preamps looked like. Now I know.
Another possibility is that the hot valve-swapping could have seen off one of the unobtainium selected mosfets. I'll grab the full manual. Craig |
20th Jul 2020, 3:49 pm | #12 |
Come to think of it, it is insane that a product cannot cope with a valve being unplugged with the product powered. Valves age and their characteristics change, heaters go open circuit, and heater cathode shorts are not unknown.
Craig |
20th Jul 2020, 3:58 pm | #13 | |
EDIT: With pot selection the matching can be exemplary too which, given that there is one pot-pair for the signal+ side of each balanced channel and another one for the signal- side, actually does matter. That would be tough to achieve with analogue pots. Cheers, GJ
http://www.ampregen.com Last edited by GrimJosef; 20th Jul 2020 at 4:07 pm. |
20th Jul 2020, 4:53 pm | #14 |
Yes, of course the step at which the slope changes will be well-defined, so some correction will be possible, but quantised to the step size, of course.
I'm just a little disappointed that Maxim didn't scale their resistors properly for a true log set of steps. My preamp in the lounge uses a silver stud fader with individual 1% metal film resistors in feedback around an NE5534, with resistor values calculated to give equal steps. This seems to give the best of most worlds. A well-defined law, low noise resistors and the benefit of the active gain control in handling noise floor and compression ceiling. Anywy in the preamp schematic for the unit under discussion, the analogue switches and the digipots do all the work, the valves are just for set-dressing. Has the signal been through a valve? Yep! Tick! David
20th Jul 2020, 5:42 pm | #15 |
This amplifier input stage looks like something I knocked-up in a full differential amplifier some years ago.
A pair of 'long tailed pairs', with common-ed emitter resistors, where feedback is applied to one LTP and the input applied to the other (its a standard mixer arrangement with a tiny twist). I used medium voltage BJT's throughout so it cost a little less than $10k, more like $10 It seemed to be quite difficult to get stable but I did see ~100V p-p before it got really ugly. Did they miss a neat way of altering one of the tail currents (or an additional LTP) to get an electronic volume control without having to match 4x switch networks and without the signal going through all those ladder networks and FET switches ? dc |
20th Jul 2020, 7:09 pm | #16 |
A transconductance multiplier, like the Gilbert cell? It's difficult getting those very linear. There is an improved variable gain amplifier based on it, the X-Amp from Analog devices (Barrie Gilbert works for them)
But the ADI part is several dollars, maybe ten times the cost of the Maxim part. The cost of the preamp would have to go up. They certainly wouldn't be able to keep it under $10k. But seriously, a switched potentiometer network or ladder network would be the way to go. Switches can be made a good bit more linear than variable gain amplifiers. Out of the box alternatives would be converting to RF, using PIN diode attenuators and then converting back to baseband, maybe that's in the domain of $100k preamps? It's always nice to be ahead of the game with the next trick up your sleeve. David
20th Jul 2020, 8:48 pm | #17 |
Thanks for all the comments I think I have a better idea of what they do and can test further. The digital bits seem to be working ok as I get bursts of data on the relevant pins when the volume control is operated.
I am hoping to get it back on the bench wednesday, I have a jukebox to finish off tomorrow so will try more tests and get back to you. I assume that maybe the output side of one of the chips may have a short and that why I get a variable voltage on the output.
20th Jul 2020, 10:45 pm | #18 | |
Craig |
20th Jul 2020, 11:01 pm | #19 |
I must have missed that piece of news. Very sad. So good an inventive designer that ADI opened a division near him. It's quite a number of years since I last saw James Bryant as well.
20th Jul 2020, 11:32 pm | #20 | |
I suppose it's no surprise that modern designers seem to assume a microprocessor-based control system will be the default, and once that decision's been made chip-based volume control becomes the easy off-the-shelf option. I'm told the chips have come on quite a long way since the noughties, when the pre I worked on was designed, and these days there would be no need to pair them up to get the required number of steps and 'taper'. Cheers, GJ
