18th Jul 2020, 8:27 pm | #1 |
How do you make an eight pole three way switch!
I looked a buying one, very expensive, I found an old wafer type too big, so my solution was this use two four pole three way ganged together. I wondered why I saved those cogs.
Mick. |
18th Jul 2020, 8:44 pm | #2 |
Re: How do you make an eight pole three way switch!
I like a simple solution, nice job. If I did it I would probably forget the other half goes backwards when wiring it up!
18th Jul 2020, 9:32 pm | #3 |
I have thought about that , I think I will use a small lamp as a visual indicator ,when checking the switching , Mick.
19th Jul 2020, 12:14 am | #4 |
I have about 20 brand new, made in USA for Collins receivers. You can have a couple for free. The screws holding the wafers are threaded all the way so you can cut em down to suit your requirements.
These are 24 pole 3 way, so you wont have any trouble. Joe p.s. these are new old stock, you will need a dab of additional flux to solder the contacts which are silver( plated). |
19th Jul 2020, 6:48 am | #5 |
RS used to sell a switch kit called 'MakaSwitch'. This could be configured in many ways, and any number of wafers including 'make before break'. I don't recall them being particularly expensive, and still have one I used in a CBS SQ decoder.
19th Jul 2020, 6:59 am | #6 | |
If only a Manufacturer would again take up the idea. (China please note) |
19th Jul 2020, 7:11 am | #7 |
Nifty idea Mick. The only downside I can think of is the cogs slipping on the SW shafts after a while, I presume the shafts are plaggy?
Andy.
19th Jul 2020, 8:37 am | #8 |
I don't think it will be a problem as it won't be used that often, yes the shaft is plastic, the fixing screws are allen type so I can really get some tension on them, plus the switches move quite easily.
Thanks Joe that is some switch there. It would be far too big for the space I have, I have actually got one where there are two switches per wafer, still too big. I see RS do them but I would need four wafers which would make it too big, nice to know though. Mick. Last edited by vinrads; 19th Jul 2020 at 8:46 am. |
19th Jul 2020, 10:49 am | #9 |
Aye Mick, making up wafer switch assemblies can be a sod. BC's post this morning about RS's MAKA Switch Kit reminds me that I put out a thread post back on 30th June - "Old & New Rotary Switches". With the kit a Forum chum gave me, it took ages to sort out the matching "Poles" & "Ways". I've yet to decide on what I need for my Roberts valve tester project(too busy on outdoor jobs), but if I've some surplus ones left, you'd be welcome to a made-up switch assembly. As the actress said to the Bishop, shaft length is paramount, as I'm stuck with a cabinet depth of about 3". Mind you, your cog assembly looks great, and much better than a heffing long shaft. However, Joe's Collins switch assemblies look the bee's knees. They make superior stuff, I ken, having worked on their 618's years ago.
Regards, David |
19th Jul 2020, 12:57 pm | #10 |
The Collins wafers are 3-pole 3-way so 3 wafers would be needed. Joe could measure how long a 3 wafer switch would be- it might fit...
There's room to squeeze the wafers together a bit too, by cutting down the spacers.
19th Jul 2020, 12:59 pm | #11 |
Hi Folks, the ultimate switch kit, still sometimes seen on ebay was the Plessey one.
This had bare wafers and centre sections as well as a whole variety of contact types and rotary contacts that could be cut for BBM or MBB. There were also rear contacts that could be configured to act as shorting wafers (very useful at RF) and it allowed up to 12 ways per wafer as there was an insulated stacking system for fixed contacts. It was rumoured that there was also a 24 way version of this kit available, I only have the 12 way one, complete with various mechanisms, supports and spacers. In its day it was very useful, and saves a lot of space over using a load of PO relays and a diode matrix to get a desired complex switching sequence Ed |
19th Jul 2020, 4:20 pm | #12 |
Hi Chris yes I did notice that ,it would be to much of a squeeze even cut down , I think I will stick with what I have got , thank's anyway. Mick.
19th Jul 2020, 5:28 pm | #13 |
'avin a think, with only three ways a lever and link mechanism would work with the bonus of both switches working in the same direction. A bit irrelevant as you have the solution now.
19th Jul 2020, 11:55 pm | #14 |
So if you cut down the switch, from the mounting bush to the end of the end wafer ( and securing nuts) would be 45 mm with a couple of mm to spare behind the switch. No you cant cut down the spacers between wafers as they are ceramic. Shaft length is 9mm ( 3/8" near enough) and is flatted.
Joe |
21st Jul 2020, 11:11 am | #15 |
Thankfully, my MAKA kit came with an abundance of aluminium spacers of various lengths & internal diameters. I also acquired some years back, a length each of hollow bakelite & hollow paxolin rods. Another source of insulated spacers is fibreglass fishing rod.
Regards, David |
21st Jul 2020, 11:52 am | #16 |
Where I was trained in the RN, calling gears cogs wouldn't have gone down very well!
GQRP Club 4704 - BVWS Member |
21st Jul 2020, 12:10 pm | #17 | |
23rd Jul 2020, 12:38 am | #18 |
Making up a 8p 3t switch from two RS supplied NSF 4p 3t wafers 352-222 and a shaft assembly 327-894 would cost about £35, which isn't particularly cheap!
25th Jul 2020, 12:44 pm | #19 |
Just a curved ball here...……. thinking out of the box a bit, could you use an ordinary 3way switch and a set of relays if theres room to get a board with some sub miniature relays in?
Andy |
