Old 13th Jul 2020, 2:02 pm   #1
Sparks
Default CB 741 telephone - C3 capacitor
I've just acquired this phone and it appears one of the wire joints to the C3 capacitor is snapped. Assuming I can't repair the joint, will I need to replace the capacitor or can the phone manage without it ?
Thankyou.
Sparks is offline
Old 13th Jul 2020, 3:41 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: CB 741 telephone - C3 capacitor
According to diagram N841, C3 (0.9μF) is in series with R2 (30Ω) between T10 and terminal 2 of the induction coil, so I would assume that it is needed - unlike C1 and C2 if you are using third-wire ringing via the capacitor in the master socket.
Dave Moll is offline
Old 13th Jul 2020, 4:18 pm   #3
Sparks
Thanks Dave.
Sparks is offline
Old 13th Jul 2020, 7:43 pm   #4
Sparks
I might be able to bodge the capacitor by dropping a blob of hot solder on the spot where the pin has snapped off and soldering a new piece of solid wire on to it. I've nothing to lose by trying but I won't be able to tell if I've been successful or not. I'll have to take the board off the base but I'd have to do that anyway to fit a replacement capacitor.
One quirk with this phone is that the board seems to be about 2 to 3mm too small for the case. When the bottom screw is tightened, one side of the board sits neatly on the lip of the case but the opposite side slips just below the lip, which can affect the switch hooks. Makes me wonder if I have a 711 case instead.
Sparks is offline
Old 13th Jul 2020, 8:50 pm   #5
Dave Moll
Dave Moll's Avatar
Not related to your broken capacitor lead, but I notice some oddities in the wiring:
You have the blue wire (presumably from the ringing capacitor in the master) attached to T5/T6/T7, but you still have the internal capacitor in circuit (T6-T7 and T8-T9).
The bell lead at T4 doesn't appear to be connected to anything.
I was initially also puzzled by the green wire between T10 and T8/T9 until I realised it was bridging the gap in the loop left by the absence of a dial.
Old 13th Jul 2020, 9:01 pm   #6
Sparks
Good spot Dave. I took that picture when I first connected a line cord (just to check for basic function). I've since moved a strap or two and put a resistor between T4 and T5 so the phone is now wired as per a consumer conversion kit (minus the dial).
Sparks is offline
Old 13th Jul 2020, 9:07 pm   #7
Dave Moll
Dave Moll's Avatar
Yes, as you presumably know, both the T6-T7 and T8-T9 straps are redundant when using third-wire ringing, but only one needs to be removed to disconnect the internal capacitor. Removing both, however, means you have one more spare strap to use elsewhere!
Old 14th Jul 2020, 6:07 pm   #8
Sparks
If I should have to replace the capacitor, can anyone suggest a likely source ? Mods, please move this to the 'wanted' thread if necessary.
Sparks is offline
Old 14th Jul 2020, 7:22 pm   #9
Dave Moll
Dave Moll's Avatar
It's a pity that your 'phone appears to use a single 1.8μF for its ringing capacitor rather than the two 0.9μF capacitors in parallel that are shown in the N-diagram, otherwise you could have repurposed one of those.
If searching for a modern replacement, 1μF is probably the nearest available - which would probably be within the tolerance of the original component. Alternatively, you could use two 0.47μF capacitors in parallel.
N.B. you need a non-electrolytic capacitor.
Old 14th Jul 2020, 9:47 pm   #10
Sparks
Thanks again Dave. I know what to look for now, although I would obviously prefer a like for like replacement. BTW, what does a capacitor do anyway and why is one needed in this instance ? I'm largely clueless in this regard.
Sparks is offline
Old 14th Jul 2020, 10:28 pm   #11
russell_w_b
russell_w_b's Avatar
It's part of the receiver shunt-balance configuration for sidetone and transmission as far as I can make out, Sparks. There's an explanation on Bob's telephone page about the 706. It, and a resistor and a 1u8 capacitor are in parallel with the receiver and one of the induction-coil windings.
According to the blurb, capacitor tolerance of 15% is permitted so you could get away with a 1u cap, or, in reality, probably a 1u8.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 14th Jul 2020, 10:51 pm   #12
Sparks
Thankyou Russell. I guess 1u is 1 microfarad. What does 1u8 mean ?
Sparks is offline
Old 14th Jul 2020, 11:17 pm   #13
russell_w_b
1u8 is another way of writing 1.8 microfarads. If you're stuck for a 0.9 I might one knocking about somewhere. I'll have a look down the shed tomorrow.
Regds,
Russell W. B.
G4YLI.
Old 14th Jul 2020, 11:22 pm   #14
Sparks
Most kind Russell. Thankyou.
Sparks is offline
Old 14th Jul 2020, 11:33 pm   #15
Nickthedentist
Nickthedentist's Avatar
what about the cap from an old master socket?
Nickthedentist is offline
Old 15th Jul 2020, 8:09 am   #16
Sparks
I'll bear that in mind, Nick. Thankyou.
Sparks is offline
Old 15th Jul 2020, 4:35 pm   #17
Graham G3ZVT
Graham G3ZVT's Avatar
If the wire has sheered off flush with the base of the capacitor, see if you can whittle a little of the resin away with a sharp knife or a file, exposing a little of the wire. 0.5mm would be more than enough.
Then take a single strand of copper wire from a mains flex and wrap a single turn around the stump, and solder.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 15th Jul 2020, 6:20 pm   #18
Sparks
Thanks Rambo. The point in the capacitor where the wire has snapped is clearly visible so a repair should be doable.
Sparks is offline
Old 20th Jul 2020, 6:50 pm   #19
Sparks
Successfully repaired this afternoon. Not too fiddly either.
Sparks is offline
Old 20th Jul 2020, 7:03 pm   #20
Dave Moll
Dave Moll's Avatar
Glad you're sorted.
