Old 9th Jul 2020, 4:38 pm   #1
BigClick
BigClick's Avatar
Default Refinishing the "A" and "B" on payphone plate
I have a payphone with the A and B letters finished in white enamel on the front plate. I want to get the plate powder coated (Gloss Black) but not sure how to re-apply the A and B lettering.
Has anyone done this before?
BigClick is offline
Old 9th Jul 2020, 5:46 pm   #2
camallison
camallison's Avatar
Default Re: Refinishing the "A" and "B" on payphone plate
Water-based acrylic satin white looks good on the background you plan. Model paints from Humbrol are what I have used in a similar application. I tinted the white to get an off colour white that suited my purpose. I tiny touch of yellow acrylic satin did the trick.
Paint number 130 is the one I used. Ensure you use the water-based acrylic as I found their enamel paint chipped too easily whereas the acrylic is a closer match to the original A & B paintwork.
Colin
camallison is offline
Old 9th Jul 2020, 8:14 pm   #3
BigClick
BigClick's Avatar
Colin
Thank you Colin, did you use tape guides to do the numbering or just let it settle in the indentation?
BigClick is offline
Old 10th Jul 2020, 10:48 am   #4
Pellseinydd
Have you seen eBay item 313122610023 'GPO A B Coin Box decal stickers' ? Looks like quick neat easy way to achieve your aim.
I have no connection with the seller!
Pellseinydd is offline
Old 11th Jul 2020, 8:18 am   #5
camallison
camallison's Avatar
Colin
I very carefully (steady hand) filled the indentation, ensuring the surface was grease free first.
Colin
Old 11th Jul 2020, 5:11 pm   #6
To fill in indentations I have used a bow pen, worked quite well, now I use the eye end of a needle, it does take more fills but doesn't shed loads of paint all at once.
Old 12th Jul 2020, 2:56 pm   #7
BigClick
BigClick's Avatar
The lettering is quite wide, do you mean outline it with a bow pen and fill in with a brush?
BigClick is offline
Old 12th Jul 2020, 3:09 pm   #8
I use the same tool for all parts, make a bit of a puddle and then move to the outsides. Have a rag damp with solvent (water for acrylic, white spirit for enamel) at hand for the odd mistake. Giving the thing a wipe with said rag first helps with flowing the paint.
Once you get the hang of it it is good fun.
Old 13th Jul 2020, 6:37 pm   #9
BigClick
BigClick's Avatar
I will give it a go next time I am on the tools
Thank you
BigClick is offline
