28th Jul 2020, 11:10 pm | #41 |
Re: ATU vs. Preamp vs. Active Antenna
First you make a different sort of pipe-bending machine:
You want three identical wheels. Each about three or four times the diameter of your tubing. Make them out of almost anything. Steel or aluminium are fine, even a hardish nylon like 66 will do. You want them wide enough to machine into them a concave profile that takes about 1/3 of the diameter of the tubing. Bore out each wheel from opposite sides to take a ball race, so you'll need six ball races. Make axles to take the ball races. Make a pair of parallel frames to take all three axles with the races/wheels assemblies between them. Two wheels will run on the bottom side of your tubing, the third wheel is above the tubing and its axle goes through slots. A moving frame holds the ends of this axle and is pulled down by a screw adjuster. You can set the moving wheel so the straight tube just passes through , touching all three wheels. Move the middle wheel down a little and push-pull your tubing to and fro. This will curve your tubing slightly. Move the wheel a little more and keep pushing-pulling until your tube takes on the curve you need. Concentrate and tighten up on areas with not enough curve. Take care to form the curve in one plane. With a bit of care you can make tubing into a full, smooth circle. Want to do a different size tube? Make three new wheels to suit the new diameter. It's actually easier than it sounds you are not forcibly bending in one go, you are increasing bend very slightly in stages. It's a bit like snake charming. the eventual carve is sneaked up on. David
29th Jul 2020, 12:58 am | #42 |
Thanks for those notes, which I shall keep on file. Maybe when the garden has gone back to sleep, I'll find time to have a go. Perhaps if I said I was repairing bicycle wheels, then I could get a Government grant
B
29th Jul 2020, 8:41 am | #43 |
''First you make a different sort of pipe-bending machine:''
Or you could just hire one from Jewsons - very cheap. |
29th Jul 2020, 9:48 am | #44 |
The ones in the hire shops are great for tight bends, but don't do it for making large radius circles. I was making a 2m dia loop of 28mm copper pipe for a transmitting loop.
It still needed one joint around the loop because of the max length I could get. Solder joints are extra losses, so I butt jointed and welded the copper. Borax as flux and 1.5mm copper wire from twin-and-earth as filler rod. File flat and polish. David
29th Jul 2020, 10:47 am | #45 |
What is the advantage of making the magnetic loop element into 25 - 28 mm thickness pipe rather than using 1 or 2 mm thin wire?
I have seen a Chinese made Active Magnetic Loop MLA-30 on eBay, and its element was 1mm thin wire.
ORAWA = Old Radios And Wire Antennas |
29th Jul 2020, 11:43 am | #46 |
Not much advantage for a receiver. Huge advantage for transmitting.
With a typical loop well under a half wavelength in size, resonated to the wanted frequency with a capacitor, the effective radiation resistance can be sub-Ohm. So you neew the losses at the wanted frequency to be less than this. Due to skin effect, pipe is most efficient. Copper is low resistance and you do need plenty of surface area. If you can only get the RF frequency loss resistance down as low as the radiation resistance, then 50% of your power heats the loop. So you want to get well below the radiation resistance. So big diameter tube, and copper-welded joint. Solder is not so good. My variable capacitor was made of plates copper welded into slots in the pipe. Serious mechanical engineering. David
29th Jul 2020, 2:13 pm | #47 |
Way back in post #7 Bazz referred to LZ1AQ:
http://www.lz1aq.signacor.com/ I bought one of his amplifier kits and made up a loop from 2.5mm cable (I think). It is cleverly fed by Cat 5 cable, one of the pairs being used for the balanced signal and others for power and a switch signal which allows selection of either the loop or a short vertical. It's amazing sometimes to switch between the two aerials. I find the system very effective in reducing RFI across a wide spectrum. LZ1AQ goes into a lot of theory on his site which I find very plausible. He comes from an academic and practical engineering background and has clearly spent a lot of time on research. He does consider the benefits of a copper pipe loop as against a simple wire and does a thorough analysis of the needs of the all important preamplifier. There are also a lot practical recommendations. All very well worth reading. Ian |
29th Jul 2020, 4:01 pm | #48 |
Firstly, I think it is best to completely separate all discussion of receiving loops and transmitting loops. The complexity of transmitting loops is so much greater, perhaps in part because of the very high voltages that come in to play?
Re LZ1AQ; yes I think his site is a "Must see" source of info. I think he published his first designs back around 2011 and now he runs his own business selling them. His 2011 design may well be an easier amplifier to build than a Wellgood. Re the material for the loop; my understanding is that is that you want to try and keep the inductive reactance of the loop to a minimum, and this is especially true as you go north of 2MHz. The reactance is directly proportional to the inductance and the inductance of a single multistranded wire is about 5 times higher than a 1" tube. The choice of material can also affect the RF resistivity. Other materials options beside tube include using the braid of "monster" coax cable. Of course, even if we separate the receiving loops from transmitting loops, there's still the issue of whether to choose resonant loops or non-resonant loops. The net is full of info...it's picking out the wheat for the chaff that's a problem. B
29th Jul 2020, 4:25 pm | #49 |
Having a Faraday screen (yes, a real Faraday one) on a receiving loop can be an advantage, if the area around it is full of e-field interference.
This can be done by having the loop made as a ring of coax. THe ends of the inner used as the loop and going to the preamp, while the braid is cut short a little at both ends and the loop of braid is NOT completed, but gets a single point connection to a local earth. David
29th Jul 2020, 8:42 pm | #50 | |
When I made my Gary Tempest inspired 'Wellgood' clone I considered making the loop from 22mm copper tube as I have a 22mm bending spring, but I didn’t fancy forking out £15.00 for a 3M length of 22mm copper tube as I had two pieces of 15mm two metres long to hand. The only advantage of 22mm tube would be that it would be more robust, but 15mm copper tube is quite robust enough. I made a simple bending jig from scrap chipboard and wooden offcuts then annealed the copper tube to make it easier to bend by heating it to cherry red with a propane blowlamp then allowing it to cool down. (The tube would have bent without annealing, but during bending it ‘work hardens’ making any slight adjustments to the shape a bit tricky). I bent two halves of the loop, pulling the bending spring through the tube with an attached steel wire a stage at a time to ensure that the tube was supported by the spring throughout its length as the bending progressed. The same process could be used to bend annealed 22mm copper tube using a bending spring, but I didn't think it would make any difference performance wise. Anyone who feels disinclined to bend a loop of copper tube could just use eight 45 degree end-feed ‘elbows’ to make an octagonal copper tube loop. I joined the two halves of the loop at the top with an end-feed soldered coupling and at the bottom end, with an acetal rod insulator that I turned to shape on my lathe. I used a piece of scrap 12mm thick white plastic chopping board on which to mount the amp and the loop, along with ‘U’ bolts to attach the loop to a 28mm diam mast. The loop is secured with two 15mm plastic pipe clips at the top and bottom as shown in the picture below. Low density polyethylene chopping boards can be cheaply bought from catering equipment suppliers. For example, 12mm thick x 300mm (12”) x 450mm (18”) £5.99 +VAT at the time of writing: https://www.nisbets.co.uk/hygiplas-s...ing-board/j252 The connections to the copper loop were via soldered tags secured with self-tapping screws into the copper tube and acetal insulator. Once assembled, set up and tested, the connections can be waterproofed with self-amalgamating tape. This two-transistor version similar in design to the Wellbrook performs just as well as the Gary Tempest 5-transistor version I built back in 2016. I erected it in the loft of my garage in May last year. It's connected to a KB valve radio. I use it most days and it performs really well. Pic 1) Loop bending jog for copper tube. Pic 2: Loop joined up. Pic 3: Acetal insulator. Pic 4: Amplifier mounted to loop. Pic 5: Loop installed in garage loft. It easily outperforms a 66ft end fed wire aerial in terms of signal strength and much lower noise level. Incidentally, I wonder if anyone has seen or bought, one of the Chinese 100kHz to 30 MHz 'MLA' ('Mega Loop Antenna') widely available on ebay from UK suppliers at prices around the £35.00 mark. EG: https://www.ebay.co.uk/itm/Ring-MLA-....c100677.m4598 The loop itself is small gauge stainless steel and is shown coiled up rather like bandsaw blades are coiled up till unpacked. Looks to be about 1 Metre diameter when unfolded. They're powered from a USB charger which isn't supplied. (They don't come with the mounting post or hardware). Not a great outlay. Lots have been sold by several sellers. The spec can be seen at the link. No claims are made about the gain compared say to a dipole, but local radiation noise suppression is stated to be 'up to 30 dB compared to 'long-haul' ['long-wire'] antennas'. To comply with forum rules, please confine any remarks about the antenna itself and obviously no discussions about the seller, who is only one of many offering the 'MLA' for sale.
30th Jul 2020, 10:29 pm | #51 | |
B
31st Jul 2020, 9:17 am | #52 |
Great info. Thank you.
Would Delta Loop element work as well as the circle shaped element? Not having to bend pipes into perfect circle, Delta shaped element would be easier to implement?
31st Jul 2020, 10:00 am | #53 |
The cross-sectional area of a loop sets how much flux it captures, the length round the periphery sets the losses.
A circle gives the best ratio. Losses are only important on transmit. For reception, all you need to worry about is not losing too much area. Circles don't have to be perfect. A circle in self-supporting pipe comes into its own on receive if mounted on a rotator of some sort. It isn't so much as peaking the wanted signal because the peaks are broad and soft, it is being able to plant a sharp null on an unwanted signal that is very useful. David
31st Jul 2020, 5:58 pm | #54 |
What can be useful here is 22mm blue PVC water pipe, intended for underground use. Builder's merchants keep huge coils of it, conveniently of ~1m diameter.
It's cheap and it weighs little, so a single loop of it gives you the structure for use with a rotator, even if you use it with no more than a single strand of wire passing through it. David; are you really sure that at higher frequencies (>2MHz) loop "thickness" i.e. wire v tube is not significant on receive? I note that in some articles on loops, the term "fat loops" has crept in . B
31st Jul 2020, 9:24 pm | #55 |
LZ1AQ looks at many of the issues of loop design here:
http://www.lz1aq.signacor.com/docs/e...arison-v10.pdf He makes the point that you only need the last word in loop construction (low inductance etc) if you have the good fortune to live in a very low noise, rural location. |
31st Jul 2020, 10:31 pm | #56 | |
However, as the magloop could be rotated, it still has potential, but I do need to squeeze everything I can from it for it to compete better against the Vee. If I recall, LZ1AQ suggests that magloops will perform better at height, which is not a universally agreed issue, though I personally suspect he's right and mine could be higher. B
16th Aug 2020, 12:57 pm | #57 |
I have bought myself a MLA30 Active Loop Antenna, and it seems working OK. But it seems working better for the old vintage receivers which are deaf such as the Lafayette HF-600. I was going to replace all the caps trying to restore its sensitivity of the HA-600, but it works great with the MLA30.
Usually the HA-600 would not receive much on all the SW bands when used with long wire in the garden, but with the MLA30 it receives very well on the SW bands. Does it mean that the HA-600 doesn't need to be recapped, and just could be used with the MLA30? On other modern radios such as Tecsun and Sangean, long wire works much better for DX and weak signals. With MLA30, I find these modern radios don't seem to be too happy - received audio gets raspy and rough at times with the MLA30. Still not done anything on the my own DIY Active Loop antenna project with the transistors while playing around with the MLA30 and trying to catch some DX signals at nights.
16th Aug 2020, 8:58 pm | #58 | |
I'm not too familiar with the HA-600, but I think it may come from the same era as my Realistic DX-160. I fully re-capped that some time ago, which proved to be a real waste of time . B
16th Aug 2020, 9:23 pm | #59 |
Different receivers are built with different antenna impedances in mind. Get it much wrong and it can seem pretty deaf
In general, broadcast and cheapish short wave receivers were designed to go with high impedance antennae like long wires. Amateur radio stuff was designed for 50 Ohm antennae for transmit, so the receiver had to be optimised for the same and it was assumed that other antennae would be handled by an ATU. Professional gear went for 50 Ohms as the default. So my amateur radio gear is somewhat off song when I just shove a wire out of a window as a temporary antenna when I'm away from home and just want to have a listen on the bands. A loop antenna with a built-in preamp could be arranged for either of these situations. David
17th Aug 2020, 11:12 am | #60 | |
But my wire ant. is in the garden, and it works well with the other radios. I hear some interesting DX signals from Cuba and South America on 4 - 5 Mhz and African BC on 6Mhz. But when connected to the HA-600, it is just silence. But when the MLA30 is connected to HA-600, it copies many signals on SW. It is still very quiet, and there is no band noise at all. So it gives impression this HA-600 is very selective and sensitive too. It even picked up signals from Korea on 9Mhz, so it works fine. But the HA-600 is from 1970s, and the caps must have gone leaky and resistive I am sure. Why it works fine with the MLA30 but not with wire made me wonder.
