25th Jun 2020, 5:14 pm | #1 |
"I never got it to work", the story of a £15 PRC320
A few years back, at the Cobham/FRARS rally, I spotted a battered and looked-like-it-had-been-stored-in-a-chicken-shed PRC320 in a bin under one of the fleamarket-stalls. Casually enquiring of the seller he told me "I never got it to work". Now that either means he
[1]lost patience and gave up after a couple of hours of not-understanding-the-instructions, [2]spent an entire weekend of soldering in replacement parts at random and most of the PCBs are missing tracks, or [3]robbed it of most of the interchangeable modules so what's on-sale is an empty shell. We talked. I bought it for £15. it could always provide knobs/meters etc for my other PRC320. Then "events" happened and it sat on a shelf for five years. ("Lockdown" time, and I was bored. In normal-times I'd have access to the entire test/instrumentation lab of my ex-company, but that's not accessible now, so this would be a "kitchen-table" refurb). Job One: Clean off the crud. Going-over it with a paintbrush-dipped-in-white-spirit, followed by a gentle jet-wash, cleared off the grosser crud. [Thankfully the PRC320 is Royal-Marines-grade waterproof]. Then, after leaving it out in the sun for a day, I hooked it up to power/audio-gear/an antenna. It was deaf. Really deaf. Wiggling a screwdriver into the antenna socket produced only a hint of a crackle. And even with the gain-control fully-to-the-right there was much less than the usual 'sharsh' background noise. But thankfully it didn't produce the PRC320 synthesizer wail-of-unlock on any band. There was hope! Sticking a dummy-load on the antenna terminals and activating the PTT - lots of relay-chatter and strange audio-squeals! Interestingly, sometimes after this the 'sharsh' level would increase to what I'd expect from a healthy PRC320. More hope! So I split the case [all those Allen-head setscrews...] Inside I found all the modules present (phew!) but module-5, the switched-mode inverter, looked to have been meddled-with. So out it came. Several of the TO5-cased transistors had been replaced, but - paradoxically - the 130V-rated tantalums (the usual failure here - they are expected to run at 125V) were original. Having nothing better to do, I went *really* closely over the entire pair of boards with my magnifier - and - ["Hunting High and Low" - A-ha!] one of the original TO5-metal-can ICs had been replaced by a 6-pin DIL chip on a 'piggy-back' board. This looked rather professional, unlikely to have been done by an amateur. But between two of the leadouts was a tiny solder-bridge. I poked it and it broke away. Next - a 'Kitchen Table' test-rig using resistors to simulate the expected transmit/receive loads on the different power-rails. Everything looked good! But before reassembling the module I swapped-out those troublesome 130V Tanties with modern 105C 160V-rated electrolytics. Refitting Module-5, decent audio-level of 'sharsh' and no more relay-chatter-and-squeals when I hit transmit. But still deaf-as-a-post 90% of the time and 'odd' RF-power-out indications. Cut-to-the-chase: the PRC320 has a two-BNC-connectors-on-a-metal-tube link between its RF I/O and its built-in ATU, the idea being that for manpack/mobile operations you use this to link to the internal ATU but if you want to connect a proper dipole antenna or use the 320 as a driver for a linear-amp in a base-station you unplug the link and have direct access to the RF I/O. In my case the sliding 'trombone' section of the link was full of gruesome corrosion: disassembling it (spring out the plastic circlip) and cleaning using a fibreglass-tipped PCB-brush with lots of aerosol car-brake-cleaner followed by a squirt of Servisol - refitting it to the 320 gave me good receive and no odd transmit-shutdowns. So, reassemble everything into the case [I only fitted four of the Allen-screws ftont and rear] and then an on-air test. Yes, it's good-to-go! On 28MHz I was happily working stations in Austria, Germany and Poland. Not bad for £15! [Photo shows the 320 in my kitchen - yes this was a real 'kitchen worktop' rebuild!"] Last edited by G6Tanuki; 25th Jun 2020 at 5:31 pm. |
25th Jun 2020, 8:23 pm | #2 |
Re: "I never got it to work", the story of a £15 PRC320
Great bit of fault-chasing there and a rewarding outcome- it's funny how things can be an ill wind sometimes, a stretch of un-hasselled time can work wonders for insight and clear-mindedness. I quite like broken things with someone's "I haven't got the time...." narrative behind it- it often translates as "I've been distracted by something else and haven't bothered with it" or "TBH, I haven't a clue but pride won't let me admit it, so I've left it well alone"- either way, it often means un-molested and a straightforward fix.
Fingers crossed it keeps ackling! |
27th Jun 2020, 7:26 pm | #3 |
It was kinda methodical - the sort of follow-the-trail-even-if-it-does-not-seem-to-lead-anywhere stuff I tought my techs..
"Why did they do this?" was always a fun game. The PRC320 in question continues to work well, though I still don't understand its "AM" behaviour. Officially it's supposed to run a sort-of 'controlled carrier' AM, where the basic carrier-level is varied with a tine-constant of several seconds to follow the audio. Talk, and the carrier-level rises quickly; stop-talking and the carrier drops-back to save battery-power [plenty of 1950s/1960s ham-radio gear used the same approach] What seems odd on this particular PRC320 is that yes, talking on 'High Power' AM the carrier slides to follow the audio - but then when I stop talking it ramps-up the carrier to something like 50 Watts, before after a few seconds throttling it back to a more-sensible 'idling 10 Watts DC input'. I'm not complaining though: working on 80/160M AM I'm regularly complemented on my audio-quality. |
27th Jun 2020, 8:43 pm | #4 |
A courageous man indeed.
Andy G1HBE. |
27th Jun 2020, 9:36 pm | #5 |
In the days when I needed-to-work, I was the guy to who the 1st/2md/4rd/4th-level techs handed the "this problem is truly insoluble!" jobs.
And was happy to fold the problem back on them, pointing-out the signs and symptoms they'd missed, and - sometimes - after a walkthrough - offering them the opportunity to put their name rather than mine on the problem-resolution ticket. "You've not failed to diagnose the problem, you've just not been provided with sufficient information or understanding". I was always happy to see my techies go on to bigger and better things. And the juniors understood that if they approached me with a _real_ problem (rather than wanting me to fix things for them so they could slope-off early on a friday) I'd help them to understand their problem and guide them towards a solution in a way that made it a teaching-experience. [only one exception to this: when I fired an entire software-development team because they refused to provide me with their code so I could do a line-by-line walkthrough. Part of mme thinks that by doing this I may have prevented a significant aviation-disaster] |
1st Jul 2020, 12:30 pm | #6 | |
1st Jul 2020, 7:40 pm | #7 | |
[NOAA didn't like me for what I did] |
