15th Apr 2020, 12:48 pm | #1 |
Mullard 5-20 high DC Voltages
First post here, so here goes.
Having built myself a single test unit using a wooden chassis. I am in the testing phase and have hit a stumbling block. The amp works and sounds great with no sign of hum or any nasty noises, however the DC voltages I am measuring are approximately 20V high. What makes no sense is the AC voltages out of the secondaries of the mains transformer are measuring low as I'm using the 250V primary tap and my mains voltage seems to sit between 235 and 240V. The information on the build: Built as a standard amp following the component values laid out in the mullard book. (The pages are available here http://www.r-type.org/articles/art-003d.htm) The only tweaks made to the design so far:
These are the main bits used to build it: Sowter UP21s output transformers (6.6K + 43% UL taps, 16, 8 & 4 ohm secondary taps) VVT VTL12158-1440 Chokes (10H 180mA, measured 117.5 ohm resistance) Primary Windings mains transformers (410V – 0 – 410V @ 180mA, 6.3V @ 4A Centre tapped, 6.3V @ 2.5A Centre tapped, 5V @ 3A) Tung-Sol EL34B Sovtek 5AR4 NOS GE 6267 NOS GE 5751 Testing voltages with no input signal sat idle. (using Fluke 28II DMM) Mains voltage - 237.6Vac HT voltage - 398.5Vac (directly measured off the 410-0-410 winding) C15 - 481Vdc C12 - 465Vdc C5 - 431Vdc C4 - 172Vdc V4 Anode - 457Vdc V4 G1 - 0.9Vdc V4 G2 - 454Vdc V4 G3/Cathode - 32.7Vdc Heater - 5.74Vac V3 Anode - 455Vdc V3 G1 - 0.6Vdc V3 G2 - 454Vdc V3 G3/Cathode - 32.2Vdc Heater - 5.76Vac V2 Anode 1 - 317Vdc V2 Anode 2 - 317Vdc V2 G1 - 83.5Vdc V2 G2 - 91.6Vdc V2 Cathode 1&2 - 96Vdc V1 Anode - 91.7Vdc V1 G1 - 0 (no input) V1 G2 - 114.5Vdc V1 G3/Cathode - 2.18Vdc Heater - 5.9Vac Rect pin 8 - 478Vdc Rect pin 8 - 5.4Vac (to GND) Rect pin 2 - 7.2Vac (to GND) Other measurements I made whilst it was running: 14.5Vrms output is about the limit before it seems to begin to oscillate. (1KHz sine wave showing ringing around the edges of the peaks/troughs). The waveform doesn't flatten off top/bottom like I would have expected, it keeps rising with the ringing around the edges. I added 30pF to the feedback capacitance as a test, making C9 360pF. The ringing on appears unchanged. Output level appears to rise below 9Hz and above 42KHz. (forgot to make a note the output power during that test) This is the scope trace with 1KHz square wave input. https://***********************/65535/...250c88f7_h.jpg This is 10KHz. I've tried added an additional 30pF cap to C8 but it doesn't appear to have made any difference. https://***********************/65535/...aba07cda_h.jpg The issue I've noticed is the very slight signs of red plating on the EL34's. Seen here in this picture with a slight glow on the right side of the anodes of both near where they are welded together. https://***********************/65535/...fea242e4_h.jpg This is the component layout underneath. https://***********************/65535/...5f8f253a_h.jpg Basically, I'm trying to figure out how I can have lower AC voltage going into the valve rectifier than the book figure by ~12V yet end up with 20V higher than the book figure coming out of the other side? Any pointers would be very welcome. |
15th Apr 2020, 2:38 pm | #2 |
Re: Mullard 5-20 high DC Voltages
Not sure if it helps but don't forget that the voltages in the Mullard book are measured with an AVO 8, 20K ohm per volt. If you are using a modern dvm it will not load the point being measured in the same way.
Peter |
15th Apr 2020, 2:49 pm | #3 |
Increasing the value of the reservoir capacitor will increase the DC voltage across it.
Lawrence. |
15th Apr 2020, 4:49 pm | #4 |
And the 5-20 was designed to drive a tuner and pre-amp of up to 40mA.
15th Apr 2020, 5:18 pm | #5 |
As well as the points mentioned above, there are a few other things that could cumulatively bump up HT- if the mains transformer HT windings and/or smoothing choke have lower resistance than the originals, if the installed 5AR4 has a lower forward voltage than expected from an original Mullard GZ34 (rectifiers were incrementally improved over time as regards aspects like cathode coatings and electrode clearance tolerance) and if the output valves in particular are drawing less current than original spec.- at least the cathode voltages are close to each other and knowing these and cathode resistance will give current drawn.
15th Apr 2020, 5:22 pm | #6 |
14.5V rms into 8R is about 26W so no lack of grunt.
The ringing/oscillation on overdrive could be worth worrying about. How does it look fed with a square wave which doesn't overdrive it? If you're worried about 20V extra HT (only about +5%) add a watty resistor between the rectifier cathode and the reservoir capacitor and tweak to get the voltage you want. Heater volts all seem to be lowish- what are they back at the transformer? Is the heater wiring a bit on the thin side?
15th Apr 2020, 6:09 pm | #7 |
Hi
Nice job. What value did you use for R26 and R27? I can not see them in the picture? "The power supply is conventional and uses a Mullard indirectly-heated, full-wave rectifier, type GZ34, in conjunction with a capacitive input filter. The values of the limiting resistors R26 and R27 will depend on the winding resistances of the mains transformer used. Their purpose, when required, is normally one of voltage control only."
BVWS member. |
15th Apr 2020, 7:01 pm | #8 | ||||
https://***********************/65535/...29cc4092_b.jpg https://***********************/65535/...ca4d7ddf_b.jpg The heater voltages are low as I'm using the 250V primary instead of the 240V in order to get the lowest voltages out. Thought it the safest choice since I don't have a variac. My mains voltage is usually between 230-240V. Quote:
I think the 5AR4 having a much lower voltage drop than expected is the only thing I can think of that would truly explain what I'm seeing A thought I had considered was to replace the cathode bias resistors with 560 ohms to help reduce the current. I would prefer to avoid roasting the EL34's as they are around £100 for 4 so eking out a longer life would be preferable. |
15th Apr 2020, 8:02 pm | #9 |
Hi
I would leave the smoothing cap as it is, put transformer to 240V tap, experiment with R26 and R27 until you get the voltages you are after. This will reduce the work the EL34s are doing a bit, it does look like one is just starting to glow. The ringing clearly should not be there, if you follow the signal through the amp with the scope you should be able to work out which stage it is coming from. Make sure you don't zap the scope with the high voltages present, a high voltage cap on the input will protect it from DC. Richard
BVWS member. |
15th Apr 2020, 11:03 pm | #10 |
I would have thought that any amplifier that has a propagation delay and negative feedback is inevitably going to ring slightly if you hit it with a very fast rising edge.
The ringing is around 80KHz and decays quite quickly so is completely inaudible and the reality is that any audio signal source is not going to deliver transients like this. Might be interesting to see how other 5-20 builds behave before trying to fix it. PS: C1/R3 rolls off the HF open loop gain Last edited by PJL; 15th Apr 2020 at 11:18 pm. |
15th Apr 2020, 11:27 pm | #11 |
I've always thought that high frequency ringing is almost a standard feature of valve ampifiers due to the inherent resonant characteristics of output transformers. Doesn't necessarily matter much as long as it's inaudible. Happy to be corrected if I'm wrong.
Alan |
16th Apr 2020, 12:16 am | #12 |
It looks fairly tame, maybe a bit bouncier than ideal, but there does seem to be a slight discontinuity in the 10kHz case as the ring starts. This might suggest that the beast is only conditionally stable at some high frequency which could be the root cause of the oscillation seen when you overdrive it and the loop gain falls off.
It may not matter in practice but it would be interesting to nail it! An open loop bode plot from the feedback injection point to the LS output would be interesting. A 1-2-5 plot (3 frequencies per decade) up to the gain crossover point should be detailed enough. Have fun! At least it's not a 1200Amp DC PSU that's honking......
16th Apr 2020, 7:59 am | #13 |
The red plating on the valve there is odd, considering your DC measurements aren't far off. What do get on the scope, no IP, IP grounded? What AC do you get at C12/ EL34 anodes? Ground the grids of the EL34's, do you still get red plating? Disconnect the NFB, still red plating?
Some pics of the underside of your amp would be nice, could reveal something. Andy.
16th Apr 2020, 9:34 am | #14 |
16th Apr 2020, 10:44 am | #15 |
Not experienced with valve amps but surely it’s good practice to put an LPF (simple RC) on the input of an amp to limit the input rise times, especially in test scenarios ? Normal programme material will be of limited bandwidth as has been said.
16th Apr 2020, 3:52 pm | #16 | |
This album contains all of the photos of the project. (including some of the mistakes along the way) https://www.***********/photos/399591...57713410461998 Based on my bias sums using this calculator () I am running the EL34's at: Total Cathode Current = 68.1 DC milliamps = Voltage Across Cathode Resistor / Cathode Resistor. Total Anode Current = 64.4 DC milliamps = Cathode Current minus approximate screen current of 5.5%. Anode Current per Valve = 64.4 DC milliamps = Total Anode Current / Number of Valves. Anode Dissipation per Valve = 27.6 watts = Anode Current per Valve x Anode Voltage. Anode Dissipation per Valve % = 110.4% Anode Dissipation per Valve % = Anode Dissipation per Valve / Valve Max Rated Dissipation. So far between suggestions and ideas from others I have a list of potential options: 1. Run with it and increase the cathode resistors to drop the bias. Advantage being no additional heat to deal with. Disadvantage being more likely crossover distortion from class B operation. 2. Change rectifier to a 5U4GB. Looses the soft start and the first filter can't exceed 40uF. Adding a CL90 or CL150 NTC solves the soft start issue. 3. Use the dropping resistors R26/R27 suggested in the mullard book. Disadvantage is the sag they introduce and the heat they generate. 4. Use a zener diode to drop the voltage. 5. Use a mosfet to drop the voltage. |
16th Apr 2020, 3:54 pm | #17 |
Hi!
I am in total agreement with the need for additional series rectifier limiter resistors, begin with 2 X 220 ohm metal–clad about 10W per anode! Second, I most strongly advise the use of anode, screen–grid and grid "stopping" resistors for the EL34 output valves, they have sufficient mutual–conductance (11mA/V!) to need all three really! Anode resistors 47 ohms, screen–grid resistors 100 ohm, grid stoppers 1k, all 1W metal power–oxide type! Note that "stopper" resistors must be connected to the valveholder tags with the shortest possible lead lengths for them to be effective – not more than 5–6mm lead length from the body before wiring to the tags! I am also of the opinion that modern valves are not as robust as the original Mullard designs, this is another reason why it's best to reduce the h.t. line voltage by about 5% below the figure quoted on Mullard's original plans! If you try the suggestions quoted here the valves should not be showing any signs of anode glow – if they do then I'd suggest they're sub–standard or defective! With the years I spent on valve–operated gear, the only "glowing anodes" I had were TV line–output valves being run with low or no drive! Chris Williams
16th Apr 2020, 4:21 pm | #18 |
Out of interest, I've always wondered why the trend for two series-resistors, one in each rectifier anode lead, came to be a thing.
You can achieve the same result with one resistor on the rectifier-cathode-to-reservoir-capacitor connection or - my favourite - from the transformer HT centre-tap to ground. (it's my preferred option because it means the resistor is not sitting at high voltage so is incapable of 'biting' you!) |
16th Apr 2020, 4:33 pm | #19 |
Mullard always quoted a minimum resistance per anode for their rectifiers (Rlim min in the handbook), so if your power transformer didn't meet this spec you added small Rs to bring it up to spec.
e.g. EZ80 (Rlim min) = 300R, EZ81 = 230R, GZ34 = 150R John |
16th Apr 2020, 5:31 pm | #20 |
Hi!
The reason resistors were always added in pairs in the anode side of rectifiers was simply practical – using one resistor in the centre–tap lead of the h.t. secondary of the transformer means it has to be considerably larger in wattage rating for a given value, because the reservoir capacitor's ripple current, as well as the h.t. current, has to flow through it, and also it was usually physically easier (particularly with octal–base rectifier valves where unused pins are omitted from the base in many cases) to suspend smaller wattage components in the under–chassis wiring! Now that high–wattage metal–clad resistors that can be screwed direct to metalwork are available, it's now only a matter of personal choice! Chris Williams
